Our Bosch 16H Hydropower shuts off 30 secs to a minute after heating has started. We have used a variety of settings and only when we have the lower dial on minimum (fully anticlock) and the slider above it in the centre position does it stop the shutting off. Trouble is this setting is not hot enough for a winter bath. Can you help?
  • Anonymous Oct 20, 2008
    The same happens with mine, I think its the water flow hydro power that causes the trouble. very frustrating.
Hi John
The manual is very limited in information it said to check there is
  • high water flow going through your system
  • and check your gas settings is correct!
  • The slide adjustment is your gas flow, which regulates your temperature
  • I have also increase the the gas regulator, which increases the gas flow
I have also been told its not a good idea to have a water saving head on your shower as this restrict the water out put.
Posted on Apr 27, 2009
Need help with Bosch hydropower 13h tankless hot water system
when you turn on the hot water tap there is a pressure switch in the line that sends a signal to a gas solenoid to pass the gas and at the same time to the pizo to start the flame
I would have that pressure switched checked as it may be sticking ( internal contamination) or have dirty corroded points
as gas is involved I would suggest a gas technician do the jib
when you turn off the tap, that pressure switch is shut off so the gas is turned off at the solenoid and the pizo is stopped.
May 21, 2015 | Bosch Water Heaters
Bosch hmb5050 shut down after 30 seconds
It may be turning off because it is not heating, does it have the lights inside and the turntable both working?
Dec 10, 2012 | Bosch Microwave Ovens
Bosch WTL5200 silver edition not getting hot enough to dry clothes
Check ur venting inside and outside the machine. the lint basket? is the air blowing out the back without any restrictions? then check ur thermostats with a multi meter for continuity, may also want to check ur moister sensor, if its mis reading the dryness it will shut off heat early
Jul 16, 2012 | Bosch Dryers
I have a 16h Bosh hydropower hot water heater . The unit suddenly has no spark .I have taken off the little generater cap and thouroughly cleaned it and the internal turbine . With no improvement . All...
sounds like the generator has packed up. check water flow and clean any filters on the water line. you will need a service agent to check milli volts on generator and power pack
Dec 15, 2010 | Bosch 1600H-LP Liquid Propane AquaStar...
Hot water goes cold
Did you find a solution because I am experiencing the same problem, but only since i change to a new shower head?
Regards
Christine
Feb 07, 2010 | Bosch Cooktops
I have a 2nd hand Bosch HydroPower LPG hot water system and am trying to find a manual. do you have one or is it pretty straighforwward in terms of installation? Mike
I have just dug my manual out (16H) because mine is faulty. email me and I will photocopy it at work this week and email it back to you.
Installation should be pretty straightforward and the manual's not that in depth. There are however some sections on adjusting the gas and the like that you might want to read over.
mchankey at gmail.com
regards
Mark
Dec 04, 2008 | Bosch & Tankless LP Hot Water Heater
Bosch Hydropower 16H instantaneous gas hot water unit not firing??
we had this problem and no plumbers were able to fix it. Finally we got someone from Bosch around and they found part of the ignitor had been installed upside down, since then no problems at all.
Jul 13, 2008 | Heating & Cooling
Heating & Cooling Logo
1,262 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
