Question about Sanyo SR-361 Compact Refrigerator
Sanyo sr 360 refrigerator
Given to me said it worked, i plugged it in it sparked , saw plug need to be replaced had appliance place replace plug. doesnt work.
what can it be
thanks
jeff
Joe_Rex
  • 114 Answers
SOURCE: SR-172W not cooling
MOST CASES ... THEY ARE NOT LOW ON 134A . TO TELL ... YOU NEED ONLY START THE COMPRESSOR AND HOLD YOUR HAND ON THE SMALLEST COPPER-LINE ... IF IT GETS REAL HOT 110-130 DEGRESS YOU HAVE A CHARGE. IF YOU MOVED THIS FRIG. AT ALL LATELY MAKE SURE YOU LET IT STAND UPRIGHT UNPLUGGED !!! FOR EIGHT HOURS. YOU CAN ALSO SPEED THINGS UP BY: HEATING WITH A BLOWDRIER BOTH THE COLD PLATE INSIDE AND THE BOTTOM OF THE COMPRESSOR ... THIS BOILS ANY REFRIGERANT OUT OF THE OIL AND LETS THE OIL RETURN TO THE COMPRESSORS OIL RESEVOIR THAT IS AT THE BOTTOM OF THE COMPRESSOR. THESE SMALL FRIGS ARE GREAT ... BUT FRAGILE TO MOVE AND DEFROST. OIL CAN GET TRAPED IN THE COLD PLATE AND NEDDS TO BE HEATED OUT OF THERE AND SOME UNFORTUNATELY USE METAL OBJECTS TO DE-ICE. A LOW CHARGE WILL NOT FROST THE COLD PLATE (EVAPORATOR)EVENLY AS IT SHOULD. LOW CHARGES (AFTER YOU HAVE DONE THE ABOVE) ... WILL ICE UP IN JUST A SMALL SECTION WERE THE PIPES AND CAP-TUBE GO INTO THE COLD PLATE. THESE DONT LEAK UNLESS SOMEONE TOOK A ICE-PICK OR EQUALLY AS DEVESTATING TOOL TO DEFROPST IT. ONLY WAY TO DEFROST QUICK IS WITH HAIR DRIER ...DO NOT PROP-IT UP IN THERE AND WALK AWAY .. YOU CAN MELT OR WARP INSIDE PLASTIC HOUSING !!!!! THEY ALL NEED MANUAL DEFROSTING THE MINUTE ICE STARTS ACCUMILATING. OR BUY A APPLIANCE GRADE HIGH AMP (10 AMP) PLUG IN TIMMER AND SET TO GO OFF AT 3AM AND COME ON AT 4PM ... ONLY 1 HR. IF THERE IS A VISABLE HOLE IN THE EVAPORATOR COLD PLATE ... IT IS ALUMINUM AND FORGET ABOUT EXOPY KITS TO REPAIR THEY ONLY LAST A YEAR IF THAT. IF YOU CALL TO HAVE IT REPAIRED RIGHT WITH SOLDER ... USUALLY A REPAIR LIKE THAT WILL NOT BE WARRANTIED AND PROBUBLY COST MORE THAN TO BUY A NEW ONE. GOOD LUCK.
Posted on May 07, 2007
  • 100 Answers
SOURCE: I broke all glass shelf of refrigerator. Where can I get them all? T T
you must contact www.us.sanyo.com
Posted on Oct 30, 2007
docjohn174
  • 943 Answers
SOURCE: Sanyo Eclipse refrigerator (Model# SR-4433S)Has
HI thanks for the question. if theres a puncture in the coils . scrap it way too expensive. sorry.
Posted on Oct 16, 2008
SOURCE: Where to buy Sanyo SR-366 parts? I need a freezer door.
I will probably have one, I'll look to see if it can easily be removed.
Posted on Mar 25, 2009
SOURCE: Sanyo counterhigh refrigerator model SR-4911.
remove shelves and insert keg.
Posted on Feb 03, 2010
How do i properly relocate my sanyo mini fridge from one place to another?
No, if you let it sit upright for 24 hours it should be ok. What problem are you having?
Dec 07, 2012 | Sanyo SR-366W Undercounter...
I need one shelf for sanyo sr 3660s
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
Here is one site that I recommend http://ping.fm/zJDAM
heatman101
Apr 23, 2011 | Sanyo SR-3660S Compact Refrigerator
Ts 360 no spark
The problem could be with the kill wire grounding out on the housing or the ignition coil could have gone out. Take out the spark plug and dis connect the kill wires off of the coil. NOTE: If you do not take out the spark plug to test for a spark then you run the risk of the unit starting up and not being able to shut it off. With the spark plug out of the engine and the kill wires dis connected. Put the spark plug boot on the spark plug and rest the spark plug on the engine (anywhere there is bare metal from the cylinder is O.K.) pull on the recoil starter and see if there is any spark present. If there is still NO spark present then you need to replace the coil. If there IS spark then you need to replace the kill wires with a new set.
Mar 29, 2011 | Stihl Chainsaw Cutoff Saw Flywheel 08 S...
My Sanyo refrigerator (model SR-4431S) isn't cooling like before and certainly will not make ice... While scraping ice from the freezer compartment up top, I accidentally made a small puncture in the back...
Hi!
Before you can refill the system, you need to have the leak fixed. They have to evacuate the system, weld shut the leak, vacuum the system for 30 min. and refill refrigerant to proper level. This is a job that by Federal Law has to be performed by an HVAC Certified Technician. Take the unit to an appliance repair shop for repair, this way you'll save on the service call.
A HELPFUL - 4 THUMBS - Rating and a TESTIMONIAL would be greatly appreciated if you are satisfied with this FREE solution. Thank you for using FixYa.
Oct 22, 2010 | Sanyo SR-4310 Compact Refrigerator
What kind of bulb I should use for sanyo refrigerator SR 4433S ?
purchase an appliance bulb they are available at any hardware store. Ask an eployee in the appliance department and they will be glad to help
Dave
Mar 18, 2010 | Sanyo 4.4 cu. ft Counter-High...
Sanyo SR-3660 Mini fridge doesn't run
How long was it in storage?
A fridge doesn't like to be laid down then stood up and plugged in. Reset the overload circuit.
Aug 07, 2009 | Refrigerators
Sanyo 4.9cu.ft. compact refrigerator heats rather than cools
I'd already picked up a replacement (B&D 2.7cf) before I found the website and asked the question,,,, hoped for a quick fix answer and I'd be able to return the B&D.... oh well. With 'designed' obsolescence and 'disposable' appliances, Robert L's answer confirmed my 'fears'.
Now I'm trying to find someone locally (Conroe, TX) who would like to 'recycle' the Sanyo (everything but the compressor/motor is in great shape - door, glass shelves, etc. maybe even the coolant which I don't want to 'dump' in a landfill.
Jul 23, 2009 | Sanyo Refrigerators
Apr 03, 2008 | Sanyo SR-366 Compact Refrigerator
Freezer compartment on Sanyo SR-3660S
Nope. That's about $800 bucks in damage that only a licensed professional CFC tech could "possibly" repair with very specialized equipment. I'm afraid that was a fatal blow to your refrigerator.
Feb 04, 2007 | Sanyo SR-3770S Compact Refrigerator
Sanyo SR-361 Compact Refrigerator Logo
160 people viewed this question
Top Sanyo Refrigerators Experts
John Tripp
John Tripp
christian nielsen
Are you a Sanyo Refrigerator Expert? Answer questions, earn points and help others
