Question about Hoover Vacuums
There is no steam isnt it suposed to steam clean?
  • vacs Jul 16, 2008
    it had water there is no heater to make it into steam
Here are some suggestions:
  1. Steam Cleaners must have water to work. Insert water in the water container,
Posted on Jul 03, 2008
Model sk410. how do I disassemble it?
Shark Steam & Spray Mop: How to Assemble - YouTube
? 1:27
https://www.youtube.com/watch?v=iH2NVXVA4-U
Sep 6, 2013 - Uploaded by Shark Cleaning
Assembling the Shark Steam & Spray Mop is easy. You'll ...Shark Steam & Spray Pro Mop: Using Steam and Spray Mode - Duration: 5:34. ... Shark Steam & Spray: How Do I Use My Mop In Steam Only Mode - Duration: 3:45.
Shark Steam & Spray Pro Mop: How to Assemble - YouTube
? 1:31
https://www.youtube.com/watch?v=I3thGlk2GdU
Assembling the Shark Steam & Spray Pro Mop is a breeze. ...Shark Steam & Spray: How Do I Use My Mop In Steam Only Mode - Duration: ...
Shark steam mop S3601 disassembly. - YouTube
? 3:38
https://www.youtube.com/watch?v=zq07GHhbJkI
Jan 07, 2016 | Shark Professional Steam and Spray Mop
Steam isnt coming out of my iron as it should be any ideas thank you
It may be bunged up with cal or bits. Fill the iron then heat it up to full heat, unplug. Then over a sink discharge the steam from the bottom in one go. Or buy a special cleaner.
Mar 24, 2011 | Vacuums
I have a swan steam generator model s14021 and its all working but when you press button to get steam water pours out!
Dont know the model ,but steam is water and if water pours out than the steam heat portion isnt getting hot . Probably a heating element out
Feb 17, 2011 | Vacuums
It doesn't heat. the light is on and it steamed once then quit.
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it may not be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the
Shark Manuals that you need.
heatman101
Feb 14, 2011 | Euro-Pro Shark Steam Mop - Gray/ Purple...
How to hook up tool to clean upholstery
Keep your upholstered furniture looking fresh by vacuuming it regularly with the upholstery tool attached to your vacuum's hose. Prevent the fabric from fading (or at least delay this) by keeping your furniture out of direct sunlight -- close blinds, shades or curtains when the sun shines most directly through windows closest to the upholstery. And remove stains by blotting them with a dry cleaning solvent. Before steam cleaning your upholstered furniture, read the piece's cleaning code label to determine whether or not it is safe to do so. Then rent or buy a steam cleaner (also called an extractor) and follow the directions below.
  1. Rent a steam cleaner or purchase one; buy steam cleaner solution.
  2. Step 2 Vacuum the upholstery on the furniture you wish to steam clean; use the upholstery attachment to most effectively **** up loose debris.
  3. Step 3 Test the steam-cleaner solution on the upholstery in an inconspicuous place to ensure the color won't be steamed out or drastically altered.
  4. Step 4 Attempt to remove any stains with a stain removal or dry cleaning solution. Follow the directions that come with the product you choose for the best results, and allow the stain remover to dry before you begin steam cleaning.
  5. Step 5 Remove cushions and, if necessary, arm covers.
  6. Step 6 Gently apply the steaming water and cleaning solution in straight lines across the upholstery one section at a time.
  7. Step 7 Use the cleaning extension on the steam cleaner to **** up as much water as possible. The dirt will come out with the water.
  8. Step 8 Clean one side each cushion (then allow it to dry) before cleaning the other side. If the cushions are permanently attached to the furniture, clean them last.
  9. Step 9 Allow the furniture to dry completely before repeating the steam-cleaning process or replacing the cushions.
Jun 19, 2010 | Hoover F7425-900 SteamVac V2 Widepath...
Steaming very little. The mop used to have strong bursts of steam, but now will steam very little. I use distilled water in the tank. Should I clean it with vinegar and water?
It will not hurt it to try and clean it...
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it maynot be getting steam to the head...
Here also is a link to get any of the Shark Manuals that you need.
heatman101
Dec 15, 2009 | Euro-Pro Shark Steam Mop - Gray/ Purple...
I believe the steam may be trapped in steamer, as it isnt steaming up like usual, just acts like a wet mop. Is is clogged? Maybe because I didn't use distilled wwater?
heatman101
lo
Oct 06, 2009 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Hoover steam carpet cleaner
does the trigger feel like it is doing anything? if not you may find that your handle lever guard is broke and needs to be replaced. this is the plastic piece at the top of your handle and can be removed by taking out the screw. if this isnt it let me know.
Sep 23, 2008 | Hoover SteamVac F5914-900 SpinScrub...
Vacuums Logo
41 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
