Question about Philips Magnavox 27MS343S 27" TV
No picture on magnavox 20MF231W TV
The sound works, but no picture. When I turn on the TV the screen is white.
  • 1 more comment
  • kateb75 Jul 03, 2008
    I don't recall popping, but it's possible.
    If the main power module is bad, I don't suppose it would be worth fixing, would it?
  • kateb75 Jul 09, 2008
    There are no lines of any sort on the screen, just a bright white light with perfect sound. I think there was some popping. What is a flyback?
    President:
  • 357 Answers
Hi there
You should try to replace the electrolytic capacitors found at the back of your TV near the power supply. I replaced 2 of them in my TV but it still didn't work, then after about 15 or so later, i got it to work.
This is what they look like:
To replace the electrolytic capacitors, you will need to remove the housing from your television.
Thank you for using FixYa. Have a nice day and please remember to rate this solution as FixYa!
If you need more help on this, just ask me.
Kind regards
Dustin Ellse(BearWeb)
Posted on Jul 03, 2008
    President:
  • 1,257 Answers
Look in the area of the large signal board that will be the one with the flyback and power supply and deflection circuits on it to your right flybacks are known to fail on these models as well as a high voltage leak
was the set popping from time to time ?
  • 2 more comments
  • Deeps . Jul 03, 2008
    this sounds like the main power module in the tv has gone bad.
    bad power supply for the picture tube can cause this problem.so it can be.
    I am still finding solution for your problem..reply with a comment for more help
    Please don't forget to rate this solution
    Good Luck
    You find no picture at all or is there any blue screen or black n white lines on the display
  • Deeps . Jul 04, 2008
    if here is perfect audio but a white screen with horizontal lines.then on the CRT circuit board(picture tube), you will find resistor. The location of the resistor is printed on the
    bottom of the ckt board. replace with new resistor. This will solve your problem.
My 1996 Magnavox 25" TV won't work
It sounds that the tuner to your TV is faulty. A detail check is necessary to confirm. Seek expert tech support.
Jun 20, 2012 | Philips Magnavox 13MT143S 13" TV
Tik tik sund from philips tv
when i turn on my philips 20 in flat tv i have no picture, just black screen with a tik tik sound
May 11, 2010 | Philips Magnavox 27MS343S 27" TV
My magnavox tv has sound but only a white line
You have a bad ground or even a bad vertical IC. Have a tv tech pull the board out and inspect. It could be bad grounds and resoldering them may restore the picture. Also remember to check all capacitors in the immediate area of this IC, bad caps will heat up the vertical IC, and cause bad grounds. Replace the caps and Vertical IC as needed. Should be a standard fix in this case. Thanks for asking!
Apr 25, 2010 | Televison & Video
Magnavox 20MT4405/17 Error and remote control problem
what you describe sounds like you have a short inside the safe bet is take it to a repair shop.
Oct 05, 2009 | Philips Magnavox 20MS233S 20" TV
My 32MF23ID has a white screen (no picture or sound)
Hi friend.
its nothing but colour wheel problem........check it
thank u...........
May 03, 2009 | Philips Magnavox 27MS343S 27" TV
Sound but no picture
GE TV CTC 203 the oicture is very cloudy
Dec 14, 2008 | Televison & Video
Blue Screen with thin horizontal white lines
THI IS THE INTERNAL CIRCUTRY FAULT BEST YOU
call the service person and dont try to open it other than in side of TV SET HAVING Hazard of electrical shock be handle most care fully .
and check video board and all.
Oct 19, 2008 | Philips Magnavox 20MS233S 20" TV
Magnavox with a white screen, sound, volume and channels working
dont put in back the vertical prossesor ic get a new one and solder it in see what it does.good luck.
Aug 19, 2008 | Philips Magnavox 27MS343S 27" TV
Philips magnavox 32" TS3260C1
Sounds like retrace lines. Leaky caps or worse can cause this.. Are you getting any vertical foldover at the top of the screen?
Jan 18, 2008 | Philips Magnavox 27MS343S 27" TV
Philips Magnavox 27MS343S 27" TV Logo
81 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Brian Sullivan
Brian Sullivan
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
