Question about Yamaha Audio Players & Recorders
Model yamaha RX V800 the volume button when turned clock-wise....lowers volume....and visa versa....what the heck is the problem.....frustrated,,,Mik'ie :-(
I bought my RXV800 in late 2001. This amplifier is absolutely fabulous and I understand others -like me- being unhappy when it starts to fail. I have the volume control issue as well, it started to work normal for at least 5 years, then there was a period of 1 year that the volume neither went up or down when you turn the volume control and then finally a 3rd phase was that it more or less works reverse.
It is solvable and I repaired it myself for $ 0,0. The only requirement is that you are a bit handy. You need to open the box and find yourself a way to the volume control (and you know where this sits of course) because this is the one that needs to be repaired. This is 35 screws away from you in total but this sounds a lot worse than it is !
It is indeed the volume control that needs to be repaired. In an analog amplifier this component would contain a resistor (potentiometer) but hey this is a digital volume control and looks from the outside the same but isn't at all. You need to take this volume control with 5 contacts of its print with a soldering iron. Open this potentiometer lookalike and clean it with some absorbing paper. The issue is that there is a kind of oil/grease from the shaft (which is there in order to turn smoothly) which has leaked into the area of the contacts in the middle. Just clean it and turn 50 times with it in order to spread the remaining oil/grease if there would be any. Close it again, solder it onto its print and switch on the unit... you will see that it is repaired... not for 1% or 10% but for the full 100%.
Hope this helps !
Regards,
Dirk
Posted on Oct 07, 2008
Yamaha RX-V800 shuts down when any control button is pressed
What if you DON'T use the remote? Does it shut down when just using it?
If SO, you have a bigger problem.
If NOT, it sounds like the remote is hosed - sending a code to shut off.
Do you have another remote of any brand that you could set to do something simple, like change volume? Don't train it from the original, though, or it would do the same thing.
Feb 13, 2010 | Yamaha RX-V800 Receiver
Yamaha RX-V800 volume control
i would say that the component that controls the sound level (called a potentionmeter) or (varible resistor) is either broken or faulty....you will need to remove the cover and inspect the area around the volume control just to make sure it is not broken or that any wiring has just become dry jointed....if all is good then what i would suggest to do is to find out the value of the pot...normally there around 10-50K then youll need to get a replacement...if this still dosen't fix it or your confident enough to look or fix it yourself i would take it to a local electronics repair shop....remeber to disconnect unit from power before removing cover hope this helps,ben
Jan 09, 2010 | Audio Players & Recorders
Remote does not move volume knob
Unplug the receiver for a minute then plug it back in. This resets the controls. If you still have a problem, post a comment and I will help you troubleshoot further. Hope this helps
Jun 25, 2009 | Yamaha RX-V800 Receiver
Need yamaha codes to program into uverse tv ir remote
(I have the RX-V659). Because the Yamaha remote has TWO SEPARATE buttons - power ON and power OFF (standby). This problem can't be fixed. There's a code to choose power ON and another code for power OFF. But one button can't be two buttons. Bad engineering\ design by Yamaha in my opinion
Jan 09, 2009 | Yamaha RX-V800 Receiver
Yamaha RX-V800 volume knob on receiver not working.
It sounds like the volume control pod has gone bad and needs replaced (The knob shaft connects to the pod main body and the inside of the volume pod is what controls the rate of volume,If the inside becomes worn ,broken or dirty the volume will become erratic) Replace volume pod ! ..You may try cleaning by taking off the volume knob and getting a can of pressure air and blowing the dust out!
Please rate response!!
Jan 06, 2009 | Yamaha RX-V800 Receiver
Yamaha RX-V800 Remote Control
email me .... redrivera0314@yahoo.com... ill send
you a copy of the codebook page... but let me try and locate it first, i have the same unit before. Yamaha code books are the same also to other models.
Reden
Mar 17, 2008 | Yamaha RX-V800 Receiver
Yamaha RX-V 800
give me more details of trouble... let me give you advise if it can be done. 800 does not have industry standard parts mostly by yamaha only or made to order by yamaha. I have the same unit before, i have the manual too.
i use to work with yamaha service saudi arabia 6 years
Feb 24, 2008 | Yamaha RX-V800 Receiver
Yamaha rx-v800 remote control's damaged
it can be accessed via the main unit controls but you need to go through your manuals. Maybe you can get your remote repaired still... maybe not badly damaged caused by corrosion.
Feb 04, 2008 | Yamaha RX-V800 Receiver
Problem in yamaha rx v800
Hello!!! Are you electronic technician? You should see the transistors Q22A, Q22C, Q19C e Q19A and its drivers on Main Board. All the best, Rasgador
Aug 03, 2007 | Yamaha RX-V800 Receiver
143 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
