Question about Dryers
Danby dcd5505 dryer belt replacing
How do you replace the belt, what has to come off to get the new belt on.
    Scholar:
  • 170 Answers
Remove the bottom and/or front panel. The top panel will need to come off as well. The belt should go around the drum that holds the clothes and a drive wheel at the bottom of the machine.
Posted on Jul 07, 2008
2 Suggested Answers
captaynkyrk
  • 170 Answers
SOURCE: danby dcd5505 dryer
remove the front panel(s) and the top panel. the belt will go around the drum to a drive wheel at the bottom. the belt turns the drum. You will have to route the belt around the drum and go either in front of or behind the drum to get the belt installed correctly.
Belt replacement
The part number is normally on the belt. You might be able to find an exploded view of your dryer on the internet, perhaps in an online manual, with the part number listed. Once you have the number you can google the number of go directly to the manufacturer.
I have found a number of parts this way.
Oct 29, 2013 | Danby DCD5505W Electric Dryer
How replace belt danby electric dryer dcd5505w
Remove the retaining screws off from the front panel. Remove the two wires connected to the door switch(the wires can go back on either way).Pull the front panel away from the drum. Look down to the bottom right corner facing the front of the unit and locate the tensioner and drive pulleys. If the old belt is still intact(which is usually not the case) remember the routing order of the belt. Slide the new belt onto the drum keeping in mind which side goes to the drum. The ribbed side should face outward.Next you want to curl the belt over the tensioner(providing the tensioner is still in it's slot) and then over the drive pulley. Replace the front panel and the door switch wires. You're good to go. Thank you, Dana
Oct 06, 2009 | Danby DCD5505W Electric Dryer
My Danby dryer dcd5505w hums but wont tumble. I opened it up and pushed it and it ran for a bit and stopped. I pushed it again and it ran for about 3 minutes before stopping. The motor is okay and so is...
the motor is most likely the cause. once it starts to hum, it's not spinning :( bad brushes inside. replace the motor or get new dryer, sorry :(
Joe
Aug 26, 2009 | Danby Dryers
Dryer runs but wont tumble
Try checking to see if the dryer belt is broken, the dryer belt wraps around the drum and goes to a motor at the bottom of the dryer that turns the drum, if so you can usually get a replacement belt from the maker of your dryer by visiting there website.
Mar 11, 2009 | Danby DCD5505W Electric Dryer
Danby Dryer DCD5505 starts and stops continuosly
ITS COMPLETELY NORMAL!!! THATS HOW IT WORKS.
Oct 23, 2008 | Danby DCD5505W Electric Dryer
Where can I buy the dryer belt?
I bought my dryer belt dirrectly from Danby. They first gave me the name of a company to get it from, when I called them, I was told they no longer handled Danby. So I called Danby back, the woman I talked with was very helpful. She ordered the belt and sent instructions on how to change the belt out myself, and said if I had any problems with the installation, give them a call. It took me about two and a half hourse to replace the belt. But if I had to do it again I think I could do it in 30 to 45 min. By the way I'm a 60yr old woman.
Sep 29, 2008 | Danby DCD5505W Electric Dryer
Danby dcd5505 dryer
Jul 03, 2008 | Dryers
Replacing bryer belt
Please CLICK HERE this will fix your problem.All the instructions are given step by step with the diagrams.
Jul 03, 2008 | Danby DCD5505W Electric Dryer
Danby DCD5505-w1 Tripping Internal Breaker "Limit Switch"
Sounds like you may have a lint clog somewhere either in the dryer, or if if you have it vented in the vent. The limit switch is tripping due to an overheat situation. The dryer must have proper airflow to function properly.
Apr 12, 2008 | Danby DCD5505W Electric Dryer
Part Number DB-6060532 available at marcone.com
Mar 18, 2008 | Danby DCD5505W Electric Dryer
Dryers Logo
167 people viewed this question
Top Dryers Experts
