Question about E-Machines etower 500ix PC Desktop
Boot record for floppy drive
I dont have the floppy drive in the tower , what can I do or should do ?
Can I run the tower with out it
  • E-Machines Master
  • 1,314 Answers
Yes. Most new computers today don't come with a floppy drive as they are pretty much obsolete. If you need a floppy drive because you have a bunch of floppies around with important stuff on them, you can purchase an external usb floppy drive for around $20 or so.
Posted on Jul 03, 2008
My Dell optiplex 210L boots up into a menu that says floppy seek failure strike f1 to continue f2 to run utility
You took your battery out and your computer lost all memory of what components it has installed. Hit F2 to get into the System Bios Setup. Look for your Disk drives and you will see your floopy disk drive there also. You should set the Floppy to Not Installed or None. It is probably set to Auto or 1.44.
Mar 18, 2012 | Dell OptiPlex 210L PC Desktop
Master Boot Record
MBR Short for <i><b>M</b>aster <b>B</b>oot <b>R</b>ecord,</i> a small <a href="">program</a> that is executed when a computer <a href="">boots up</a>. Typically, the MBR resides on the first <a href="">sector</a> of the <a href="">hard disk</a>. The program begins the boot process by looking up the partition table to determine which <a href="">partition</a> to use for booting. It then transfers program control to the <i>boot sector</i> of that partition, which continues the boot process. In <a href="">DOS</a> and <a href="">Windows</a> systems, you can create the MBR with the FDISK /MBR command. <br /> An <i>MBR virus</i> is a common type of <a href="">virus</a> that replaces the MBR with its own code. Since the MBR executes every time a computer is started, this type of virus is extremely dangerous. MBR viruses normally enter a system through a <a href="">floppy disk</a> that is installed in the <a href="">floppy drive</a> when the computer is started up. Even if the floppy disk is not <a href="">bootable</a>, it can infect the MBR. <br />
on Dec 22, 2010 | Computers & Internet
When a compaq armada m700 laptop is showing non-system disk or disk error replace and strike any key when ready
this usually happens when the computer is trying to boot from a disk that isn't a valid boot disk.
if you have a floppy drive plugged into the multibay and a floppy in the drive, try removing the floppy.
if there is no floppy involved, try to boot from your system recovery disks, as it's likely that the boot record on the hard drive will need repaired. your system recovery disks should walk you through the process.
Nov 03, 2011 | Compaq Armada M700 Notebook
Intermittent floppy disk drive for Husqvarna Viking Designer 1
These 3.5-inch floppy disk drives are never produced by the manufacturer of the device, but by one of a few floppy disk drive manufacturers (usually Sony) and as such, should your disk drive start to fail, you may be able to disassemble the case of the Viking Designer 1, remove the floppy drive, and insert another standard floppy salvaged from a tower-type PC, thus fixing the problem.
Since 3.5-in. floppy drives are becoming more and more scarce in modern computers (in favor of CD-RW drives) you may have a obsolete tower computer (remember Windows 98?) in your basement (or your friend's basement/yard sale/flea market/ that could supply a useable FDD (floppy disk drive).
Oct 04, 2011 | Husqvarna Designer I
My dell dimension 9200 is booting and then giving me a Floppy Diskette Seek Failure message. What is causing this to appear and not boot windows 7?
Hi. You computer seems to be booting up using the floppy disk and your floppy disk drive might not be connected properly, not working or not even there. Press F2 to run the setup utility and disable the floppy seek in the bios. It will most likely be in the "Advanced CMOS setup" area, or the 2nd screen depending on your bios. look for "Seek floppy drive at boot?" or, "Disable floppy seek at boot?" or something like that. When you find it, make sure it's not enabled for the seek. Save the change on exiting. :-)
Jun 05, 2011 | Dell Dimension 9200 PC Desktop
Did not receive any instructions with the floppy USB external
I would expect that you simply plug the usb cable flat end into the usb port of your computer after Windows has been booted in.
The floppy drive should self install if you are having a current windows xp on your pc. You will see A: drive when you click on My Computer.
Hope this helps. Please rate the solution.
Jun 16, 2010 | Sabrent External Floppy Drive
Need to find the NTLDR on my emachine I tried the recovery disk option to reset the reboot option - and was still unable to correct the problem. Are you aware of another solution? Thank You
A couple of things.
If the system has a floppy diskette drive, ensure that no diskette is in the drive. (I know it sounds simple but ...)
If no floppy drive issue, then run diagnostics on the hard drive. The drive may be failing.
Last you can try booting to the XP CD enter recovery console, and run the command: CHKDSK /R, then reboot.
My impression, if no floppy drive issue, then failing hdd
Jul 02, 2009 | E-Machines eMachines Desktop PC
I have a HP 8595c computer. I put a DVD in and it froze. I restarted the computer and now it won't boot up proberly. I get this message. "Non-System disk or disk error Replace and strike any key...
Non-System Disk or Disk Error results when the Basic Input/Output System (BIOS) cannot find the boot sector or the master boot record is missing or damaged; i.e. the device does not have bootable media. The BIOS searches drives in the order usually specified in the CMOS Setup. This order is often, but not always, A: (floppy drive), C: (first partition on the hard disk)… The error will occur during startup if the CMOS is set so the BIOS seeks the floppy drive first and a non-bootable (or blank) floppy is in (was left in) the floppy drive. Other causes include:
No bootable partition on a hard disk drive
  • A defective hard disk drive
  • The CMOS drive settings (parameters) are not correct for the boot device
  • Defective floppy
  • Defective floppy drive
  • A virus
  • Jul 21, 2008 | Computers & Internet
    I have a packard bell imedia 5064. old i know.on boot up it goes no further than black screen with white text. i have a red recovery floppy disk but it does not seem to work. i dont know if i'm using it...
    are you running the original os? if not the recovery floppy wont work.
    try just using a boot disk first see if that can start your pc it kinda sounds like your mbr is crouppted if the boot disk works run fdisk /mbr
    that should restore your boot record
    May 13, 2008 | Computers & Internet
    Cd drive changing
    Your computer cannot find The Hard-drive Or operating System.
    Your Primary Hard Drive, is reporting an error.
    Try changing the Jumper setting on this From Master To slave.
    ( jumper is amall plastic Block ) on back of drive.
    Then set your CD/DVD To Master.
    Mike @ Compurepair.
    Mar 14, 2008 | Audio Players & Recorders
    E-Machines etower 500ix PC Desktop Logo
    74 people viewed this question
    Top E-Machines Computers & Internet Experts
    Alun Cox
    Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
