Question about Adcraft DF-6L/2 Deep Fryer
Adcraft double deep fryer
My deep fryer element will not heat up even after hitting reset button. Any advise
My Adcraft deep fryer needs 2 switch 2 thermostat where do i get parts .I was using it and fire came from it it stop work the thermostat not working
Posted on Jan 20, 2012
Its safety switch not functioning
Posted on Jan 27, 2009
How can i fix my savourex pro line deep fryer?
If the reset button is not tripped, it is likely that a wiring connector has failed or the on-off button is defective.
Aug 18, 2014 | Kitchen Appliances - Others
I have a Adcraft DF-6L and it was not cleaned as it should. The elements have a coating on them from the solids from frying. How is the best way to clean these without damaging them? Any help is greatly...
After cleaning fryers for 25 years, I always revert back to EasyOff oven cleaner. Be very careful when you try to scrub or scrape the elements. There are two thermostat cap tubes. If either one is damaged the fryer won't work. The cap tubes have a small charge of gas which expands and contracts to tell the thermostat when to come on and go off. You probably can't get them perfectly clean. Start by putting water in the fryer pan and letting it boil for a few minutes. Pour the water out and if it was really greasy, boil it again. When you have floated most of the grease that will melt away, then spray the elements with the EasyOff, or store brand oven cleaner. Let it stand for 30 minutes and then rewet the element and scrub carefully with a good stiff nylon bristle brush. A steel brush might damage the cap tubes. Rinse completely clean before using the fryer.
Sep 30, 2010 | Adcraft DF-6L/2 Deep Fryer
My deep fryer stopped working while frying. How
id look in the right side groove and you will see a tiny microswitch that wont allow power to the element unless its sitting in the cradle I simply took the 4 screws off in the back of the heating element control and by passed it by connecting the 2 red wires and it worked so now I got to find the microswitch but at least I can use it
Dec 22, 2009 | Tefal Ultimate EZ Clean Pro Deep Fryer
My fryer just stopped working after frequent use, i tried replacing the cord but it is still not even responding, even to being reset via the reset button is there anything i can do, or is all hope lost...
it sounds as if the element may have burned out. here is a link to the model and manual and phone number of Euro-Pro. It would be worth your while to call them and ask their advise. Good luck
http://www.euro-pro.com/europro/faqdetail.aspx?modelno=F2015L
Nov 27, 2009 | Euro-Pro F2015L Deep Fryer
Emerilware fryer wont power up FR7009001
You can go to T-Fal website they have replacement parts the new element is $101.99. i need a new element also but thinking of buying a whole new unit and keep old one for parts
Jun 11, 2009 | Emerilware FR7009001 Deep Fryer
Wells deep fryer won't heat
Is the oil coll and it still doesnt reset?If so the hi limit is bad,which is the reset.If you gain acess to it you will see 2 wires.Connect these wires and it should heat.HOWEVER this is a saftey device that prevents the oil from getting too hot and catching on fire.
Mar 22, 2009 | Wells F-686 Deep Fryer
Fryer quits heating have to hit reset switch
This button should be a high limit switch. If it is a small red button mounted to a 2" x 2" or so device. You most likley have an issue with the thermostat letting it over heat. The best thing to do would be to replace both the thermostat and the high limit for safety reasons.
Mar 18, 2008 | Star Kitchen Appliances - Others
Adcraft DF-6L/2 Deep Fryer Logo
462 people viewed this question
Top Adcraft Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you an Adcraft Kitchen Appliances - Other Expert? Answer questions, earn points and help others
