Question about Lexmark X2500 All-In-One Printer
I have problem with de ink - Lexmark X2500 All-In-One Printer
    Genius:
  • 1,269 Answers
Okay. What seems to be the exact problem?
Posted on Jul 26, 2008
It shows messege like it is time to reset the ink levels
most of this printers have this problems due residues and blocks the tiny cells wich conducts de ink try to clean with high pressure LPS NOFLASH electro contact cleaner
Sep 16, 2015 | Office Equipment & Supplies
I have epson TX110 printer. The printer not function and says " The printer's ink pad are at the end of their service life". How to fix the problem? Thanks.
Give me your email add. I'll send you the program where you can use to reset the printer's ink pad. Here's my email roy_paulo@yahoo.com.
-Roy Paulo
Sep 13, 2010 | Epson Stylus Multifunction Inkjet Printer/...
No ink
You cant do any more printing jobs unless replace the yellow cartridge.
May 26, 2010 | Canon PIXMA MP620 All-In-One InkJet...
My Canon Image Prograf iPF700 keeps running out of color ink even through all setings are on Black and White (Monochrome). Any suggestions, getting sick of paying for ink im not using.
I you see in the preferences of the printer you have 2 kinds of monocrome( check de advanced option) one uses the all the colors to print in black if you use the second monocrome when you print its not black its more like brown. but this way you dont use de colors inks
Apr 19, 2010 | Canon iPF700 InkJet Printer
HP C7280 All in One Printer: Ongoing error to change ink
Hola. Si el cartucho es nuevo, devuelvelo, es el cartucho que esta defectuoso.
Pero si es cartucho ha sido recargado lee las siguientes lineas:
Tienes que decirme si los cartuchos was refilled, porque en ese caso la impresora no los va a reconocer como llenos., la razon es porque los cartuchos tienen un "contador electronic" que solo analiza informacion de cuantas hojas se han impreso, y al momento de ser recargados solo les colocan tinta, y el contador sigue marcando vacio.
Si aun con este mensaje puedes seguir imprimiendo, no te preocupes, pero si no, por favor dejame saber el modelo de tus cartuchos como respuesta y te mostrare como resetear.
Apr 04, 2010 | HP PSC 2175 All-In-One InkJet Printer
Getting error 0xc18a0206
Aquí es el contenido de la charla, espero que te ayuda también! Christina es la persona de soporte técnico.
Cristina: Vamos a realizar algunos pasos para aislar el problema y encontrar una solución para ello.
Christina: Por favor siga los siguientes pasos y que me haga saber el mensaje que se mostrará en la impresora.
Christina: A. - Mantenga pulsado el "*" tecla.
B. - Presione la tecla "#" y suelte ambas teclas.
La pantalla debe decir "Intro Especial clave Combo"
C. - Presione y suelte en la secuencia de "1", "2" y "3" botones.
CustomerName: ok
CustomerName: pantalla dice "apoyar" R0631M
Christina: Fine.
Christina: 2. Oprima y suelte el botón de flecha derecha hasta que la pantalla dice "Menú de configuración del sistema".
Christina: 3. Oprima y suelte el botón "Aceptar".
Christina: 4. La pantalla debe decir "estado de error de hardware". Si no existe ya, tecla de flecha a "estado de error de hardware",
Christina: 5. Oprima y suelte el botón "Aceptar".
Christina: 6. La pantalla debe decir "estado de error de hardware: Despejado. Pulse OK para borrar ".
CustomerName: yup
Christina: 7. Oprima y suelte el botón "Aceptar". Mensaje a los cambios "estado de error de hardware Resueltos. Pulse Cancelar para continuar ".
CustomerName: ok
Christina: 8. Pulse y suelte el botón "Cancelar" tantas veces como sea necesario, de modo que, o bien el "Bienvenido a Photosmart Express" aparece la pantalla, o, el "fallo del sistema de tinta" aparece la pantalla. POR FAVOR, NO intente imprimir en esta etapa.
CustomerName: ok
Christina: 9. Utilizando el botón de encendido, apague la unidad y desenchufe el cable de alimentación de la parte posterior de la impresora y la pared.
CustomerName: hacer
Christina: Fine.
Christina: 10. Espere 30 segundos para obtener el poder de vertido y, a continuación, enchufe el cable en la toma de corriente y, a continuación, en la parte posterior de la impresora
CustomerName: hacer
Christina: 11. Encender la unidad. La impresora puede mostrar mensaje "BOTóN PARA PODER UTILIZAR LA IMPRESORA SHUTDOWN" seguido de "Pulse OK para continuar". Pulse Aceptar. La impresora comenzará la "TEMNE UNA TINTA proceso de inicialización". Permitir que este proceso para completar y no interrumpir. Una vez que el proceso de inicialización se ha completado, la impresora imprimirá una página de diagnóstico.
CustomerName: hizo una buncha ruido, y no imprimir una página de diagnóstico
Christina: Bueno.
Christina: ¿Es todavía el mensaje de error que se muestra en la impresora?
CustomerName: No
Christina: Bueno.
CustomerName: debo intentar imprimir algo?
Cristina: Vamos a imprimir una página de prueba libre, para comprobar la funcionalidad de la impresora.
Christina: Pulse sobre el menú de configuración "todo en uno" luego desplazarse utilizando la tecla de flecha y seleccione la opción Imprimir a continuación, seleccione Informe de Autoevaluación Informe de ensayo.
Oct 22, 2008 | HP Photosmart C5180 All-In-One InkJet...
How to reset the ink level monitor on Canon Prixma MP 160
Disconnect the printer's outlet
Hold the Botton of power while connecting to the outlet
Holding down the power button pressed twice the reset button (red circle with a triangle)
Release the power button
The printer takes about 10 seconds into the show vaor numeroco zero.
Pressing + to the value moves from 0 to 1.
When this value to 1, press the button that is on par with reset, this will light up two lamps
One is that of plain papaer and the other of photo paper, at this point is put paper into the printer
Pressing the power button once or twice (it does not matter), the printer will print a proof sheet
When you print this sheet the value in the display returns to zero, leaving it well
Open scan cover (to remove the cartridges but was not removed), with the lid open faith disconnect the power to printer
Remove the cartridge, close the lid and turn on the printer.
Re-positioned and Refill cartridges in the printer and READY.
Mar 12, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Lexmark X2500 All-In-One Printer Logo
18 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
