Question about Motorola Mobility A1200
Incoming Calls Only
Phone receives incoming calls,call failure everytime I dial any number?
    Master:
  • 497 Answers
Do check ur network connection
Thanks for using Fixya
Posted on Jul 17, 2008
Incoming calls
Go to your phone call history and find the phone number you want to block. Press AND continue to hold your finger on that number until there is a "pop-up" with many options. Select the Block Contact option.
(If you don't hold the number down long enough you may dial that number).
Nov 02, 2013 | Samsung SGH-F300 Smartphone
I have a mobile of spice model no m4330 .from todaymy incoming calls are barred .if anyone dial my number it answeres that the number is busy . my outgoing calls are running smoothely.pls help me to break...
To cancel bared incoming calls on your phone, enter one of the code given below.
##67#, ##21#,##62# or ##61# then okay/send/yes. the phone will be unbarred.
Regards
Jun 25, 2011 | Cell Phones
Incoming calls: When we receive an incoming call,
Extension call forwarding is controlled by a timer, and they put these things in the manual. If your CF after 2 rings is from a call to a specific extension, from that extension, dial *713 and a 2 digit number from 00-99 seconds on the intercom. Start with 18.
If your call forwarding is from intercept, then you have a system programming issue and need to look in the installer's manual or check with your system programmer.
Carl
Dec 01, 2010 | Panasonic KX-T7633 Corded Phone
Who know the call barring password for nokia E52 plz help !! :):) thnx
I am having a problem in incoming calls, there is red cross(inside red circle) appeared on my main screen of my mobile E52. The incoming calls appeared in received call but i cann't receive my incoming calls. If you have the solution please let me know
Apr 06, 2010 | Nokia E52 Smartphone
Partner Plus 4.1 incoming calls problem
Voicemail is answering the calls. you need to program the system for voicemail and this will stop
Feb 02, 2010 | Avaya Computers & Internet
Lexmark X6170 Has a shared phone/fax line with different numbers
Open the Lexmark "Fax Printer Setup Utility". Click on the "Connection/Dialing" tab. In the "Interact with Phone Line" section, "Answer Incoming Calls:" should be set to "If fax tones are detected".
If this is turning out to be too unreliable for you, you will need to either manually receive incoming faxes (by changing the setting to "Manual"), or you will need to at least spring for a separate phone number with a distinctive ring for incoming faxes.
Apr 05, 2009 | Lexmark X6170 All-In-One InkJet Printer
Call barring
Use the network services menu for this...
Use this menu to access network services. Please
contact your service provider to check their availability and subscribe to them, if you wish.
This network service allows you to restrict your calls.
1. Select a call barring option:
All outgoing: prohibit outgoing calls.
International: prohibit international calls.
International except home: only allow calls
to numbers within the current country when
you are abroad, and to your home country.
All incoming: prohibit incoming calls.
Incoming while abroad: prohibit incoming
calls when you use your phone outside of your
home country.
Cancel all: cancel all call barring settings,
allowing to be sent and received normally.
Change barring password: change the call
barring password obtained from your service
provider.
2. Select the type of calls to be barred.
home country.
provider.
if you have any queries about your mobile..you can have a look at this user manual which can be downloaded from
http://safemanuals.com/user-guide-instructions-owner-manual/SAMSUNG/SGH-D600-_E
hope this helps :)
Dec 16, 2008 | Samsung SGH-D600 Cellular Phone
No respond to incoming calls
go to phone settings. check the profile and change it accordingly..regs
Jun 19, 2008 | Nokia 6260 Cellular Phone
Motorola Mobility A1200 Logo
44 people viewed this question
Top Motorola Mobility Computers & Internet Experts
David Payne
David Payne
 Paul Flint
Paul Flint
Level 1 Expert
Unlockingcom
Are you a Motorola Mobility Computer and Internet Expert? Answer questions, earn points and help others
