Question about Hoover Washing Machines
Hoover 205 washing machine
Recently given a secondhand Hoover 205 w/machine, but no usermanual. Initially working OK, but it went out-of-balance on spin. Now nothing. No activity on any cycle setting. Have checked power point - OK. Have set Left-hand control knob to Reset. Still nothing.
Your advice please. Also, is a usermanual available for download or e-mail?
The actuator arm for the out-of-balance safety switch had become misaligned from the safety switch. As such, it had tripped but could not be reset.
Posted on Jul 06, 2008
I have a Hoover 205 washing machine model that is not spinning & have tried to get into it to have a look but can't see any panels to undo - is there access?
OF course there are . tiny people did not make it usually the top is held with clips that need released .with a really thin spatula
Nov 21, 2015 | Hoover Washing Machines
Water level control on Hoover 205 top loader
as long as it fits on it will be ok ..pressure not to much
Feb 06, 2014 | Hoover Washing Machines
Washing machine off balance in one cycle
Make sure washer is on a level surface and all four feet adjusted properly. A slight forward lean may help with this problem as the out of balance switch is at the rear.
Feb 28, 2010 | Washing Machines
Fisher & paykel GWL11 washer won't rinse
sounds like you have two problems, the burning smell is probably the pump,out of balance is usually due to worn aout suspension rods
Oct 14, 2017 | Fisher and Paykel GWL11 Top Load Washer
Hoover Zodiac 12 that won't spin.
possible filter blockage, or the pump has failed/seized, machine CANNOT spin while it CONTAINS WATER, the door interlock will not open for the same reason,WATER in drum.
manually drain excess water into a bowl now
1 clean filter, 2 check pump for objects that prevent impeller working may still need pump if seized
Jun 12, 2009 | Washing Machines
Water leak at rear of drum on Hoover Nextra HNF 3157 washing machine
The outer plastic casing around the drum was cracked by change left in a pocket. I fixed it with a secondhand casing
Jul 26, 2008 | Hoover Washing Machines
Hoover washing machine HF7160E
I am a recently retired appliance engineer of 20 years, and this at first sounds like motor carbons, the belt needs to be placed on from the bottom motor pulley first the onto the drum pulley last, not easy to describe in words, anyway start with the carbons, then if they ok there is a module (main PCB circuit board) normally on Hoover washes located top of machine inside front right corner in a plastic casing, look for burn marks. work safe with electrics, always unplug first
Sep 09, 2007 | Hoover HF7 160E Front Load Washer
Hoover elite 930 top loader washing machine
I am a recently retired appliance engineer of 20 years start with checking the other solenoid, the conditioner one, it may be that that is not working, and double check the cold one, remove the two wires and check for a circuit, it may be actually filing up initially with hot water without realising it, always work with safety remove the plug before removing panels etc if i have helped rate me please
Sep 09, 2007 | Washing Machines
Washing Machines Logo
541 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
