Here is the link for the manual:
http://www.timtaylor.net/tech/iP4000%20Service%20Manual.pdf
SOURCE: Canon PIXMA iP4000 Will not print red Deep clean won t work Other colors OK
remove print head assembly. clean off.
print head not on cartridge.
SOURCE: When printing pictures, there are faint white vertical lines on
Cleaning usually doesn't help that printhead much. A new one QY6-0049-000 is around $40.00. You remove by lifting the gray handle on the left after removing all the inks.
SOURCE: Using a Canon pixma ip4000 and when printing
You need to replace the printhead, QY6-0049-000. They get plugged and cannot be cleaned. around $40.00
SOURCE: how to clean the print head
You clean it your printer maintenance software.If you are not success then it is out of order i mean damage.You can take a decision you put in water 4 hours.After all dust ink soft then dry it and clean it maintenance software.
SOURCE: canon ip4000 remove print head
Hi! You may access tha manual by clicking here. Please use the set up instruction manual (2nd m,anual from the top). Thanks for visiting FixYa.com!
If you need more help come back.Post /
thumbs / testimonial are
welcome!
