1999 Ford Escort Logo
A
Anonymous Posted on Dec 21, 2010
How to replace a thermostat - 1999 Ford Escort
ZJ Limited
Level 3:
  • Ford Master 17,989 Answers
  • Posted on Dec 21, 2010
ZJ Limited
Ford Master
Level 3:
Answers
17989
Questions
0
Helped
14458710
Points
60858
2.0L Engine
SOHC ENGINE
(see Figure 17)
  1. Disconnect the negative battery cable.
  2. Remove the air cleaner outlet tube.
CAUTION Never open, service or drain the radiator or cooling system when hot; serious burns can occur from the steam and hot coolant. Also, when draining engine coolant, keep in mind that cats and dogs are attracted to ethylene glycol antifreeze and could drink any that is left in an uncovered container or in puddles on the ground. This will prove fatal in sufficient quantities. Always drain coolant into a sealable container. Coolant should be reused unless it is contaminated or is several years old.
  1. Drain the cooling system until the level is below the thermostat.
  2. Unplug the coolant temperature sender and coolant temperature sensor electrical connections.
  3. Disconnect the upper radiator hose and heater coolant hose from the thermostat housing.
  4. Unfasten the thermostat housing bolts.
  5. Remove the thermostat housing and the thermostat.
  6. Clean the gasket surfaces thoroughly until all traces of the old gasket residue are removed.
Make sure the tabs on the thermostat engage properly into the slots in the housing.
Fig. 17: Remove the thermostat housing mounting bolts-2.0L SOHC engine
To install:
  1. Install the thermostat in the housing making sure the tabs engage.
  2. Install any new gasket required.
  3. Install the thermostat, housing and bolts. Tighten the bolts to 8-12 ft lbs. (10-16 Nm).
  4. Connect the upper radiator hose and heater coolant hose to the thermostat housing.
  5. Attach the coolant temperature sender and coolant temperature sensor electrical connections.
  6. Fill the cooling system.
  7. Install the air cleaner outlet tube.
  8. Connect the negative battery cable.
  9. Start the car and check for leaks.
DOHC ENGINE
(see Figures 18 and 19)
  2. Unplug the Camshaft Position (CMP) sensor electrical connection.
  3. Unfasten the water hose connection retaining bolts and move the connection aside.
  4. Remove the thermostat and seal from the housing.
Fig. 18: Location of the water hose connection mounting bolts-2.0L DOHC engine
Fig. 19: Remove the thermostat and seal. Inspect the seal for damage and replace as necessary-2.0L DOHC engine
To install:
  1. Inspect the seal and replace it if damaged.
  2. Install the thermostat and seal in the housing.
  3. Install the water hose connection and bolts. Tighten the bolts to 71-97 inch lbs. (8-11 Nm).
  4. Attach the Camshaft Position (CMP) sensor electrical connection.
  5. Fill the cooling system.
  6. Start the car and check for leaks.
Hope helps (remember to rate this answer).
2002 Mazda Tribute. How to replace thermostat Housing please?
I need help replacing my thermostat on my 2004 Mazda
JustAnswer https://www.justanswer.com > Mazda Repair
Dec 2, 2015 - The thermostat housing is bolted with 3 bolts to the end of the head closest to the drivers side fender. Thanks for letting me assist you. I ...
1 answer · Top answer: Welcome, I'm Chris and independent contractor that helps customers here. The best way to flush ...
Thermostat replacement Mazda Tribute 2001 - 2011
Haynes Manuals https://haynes.com > en-au > tips-tutorials > mazda-tri...
Free advice from Haynes' master mechanics. Full repair guide available for this vehicle. Save time and money with the experts at Haynes.
Need to replace thermostat in my 2005 mazda tribute 2.3.
Oct 20, 2022 - 1. Drain the engine coolant. 2. Remove the accessory drive belt tensioner. 3. Remove the thermostat and thermostat housing assembly. ^ Loosen ...
1 answer · Top answer: Good Afternoon, my name is ***** ***** ill be helping you, so sorry to hear about the issues ...
How to change MAZDA TRIBUTE Thermostat
AUTODOC UK https://club.autodoc.co.uk > ... > Thermostat > MAZDA
Illustrated step-by-step manuals and video tutorials on replacing MAZDA TRIBUTE Thermostat will tell you how to carry out DIY replacement of parts and ...
Mazda Tribute Thermostat Housing Pipe Water Outlet V6 ...
Parts Factory https://partsfactoryaus.com.au > product > mazda-tribute-...
Nov 22, 2023 - Mazda Tribute Thermostat Housing with a Replacement Warranty of 3 Years. Our Video Tutorials allow people to save Thermostat replacement cost.
Review by Jay · ‎ A$95.00 · ‎ In stock ..
How do I replace thermostat?
    1. Maintenance and How-to: Thermostat Replacement ...
      https://www.youtube.com/watch?v=RIC6Z4D6Q3E
    Feedback
  1. How to Replace Your Vehicle's Thermostat - For Dummies
    www.dummies.com/how.../how-to-replace-your-vehicles-thermostat.htm...
    Just be sure that you do this when your engine is completely cooled. Locate yourthermostat if you haven't already done so. Place a bucket under where you're going to be working. Remove the clamp. Pull off the hose. Remove the bolts that hold thethermostat housing in place and lift out the old thermostat.
    How to replace a car thermostat ' How a Car Works
1helpful
2answers
Overheated. Why won't it start?
I'm not really familiar with JEEP mechanics but if you've replaced your water pump and it's still overheating with full water/coolant level, you should check the thermostat; when it fails, it's a common cause or overheating in all kind of cars
I'm attaching some links to Youtube tutorial about replacing thermostat in a Jeep but you can expand your Google search using terms
Youtube replace thermostat JEEP Liverty
https://www.youtube.com/watch?v=Y3NpLdG993U
Jeep 4 0L straight six thermostat replacement
Thermostat Replacement Overheating fix Part 1 Jeep
How To Change the Thermostat in Jeep Wrangler
2002 Jeep Grand Cherokee Thermostat Replacement
Replacing the radiator thermostat in any Jeep Cherokee Jeep liberty Jeep...
Replace thermostat in a 1997 Dodge Intrepid
The thermostat is an easy replacement. The part from the part store should be very inexpensive and is very easy to install. IMPORTANT: allow the cars cooling system to completely cool down before starting to work on it. Here are the steps to replace the thermostat:
1. Allow car to cool.
2. Place drain pan under radiator and allow for coolant to drain below the thermostat. Do not completely drain the system unless replacing the fluid.
3. Remove the hose clamp and hose from thermostat housing.
4. Remove the two bolts holding the housing to engine.
5. Remove the thermostat gasket and clean the gasket completely off the engine and thermostat housing.
6. Remove the thermostat and replace with new.
7. Place new gasket on with reassembly.
Thermostat needs replaced
To replace a thermostat, you will need at least: 1. A new thermostat 2. Screwdriver 2. Needle-nosed pliers. Depending on the thermostat and location in your home, you may need more. Make sure the new thermostat you are using to replace the old one with is compatible to your 110-volt housing circuitry. Always turn off the electrical power to the home thermostat at the power panel or circuit breaker box.--------------------------------------------------------------------------
carbrain c168 scanner
Need to know how to replace the thermostat on a 1996 buick century wagon 3.1 6 cylinder engine
Trace the upper radiator hose to the mounting area on the intake manifold. Loosen the hose clamp on the manifold end of the hose and remove the hose. Pull the thermostat out of the intake manifold.
For more help and troubleshooting go through the help links below:---
Click the link below:-----
THERMOSTAT REMOVAL PROCEDURE/LOCATION DETAILS
Where is Thermostat Located on Saturn
http://technoanswers.blogspot.com/2012/11/where-is-thermostat-located-on-saturn.html
2004 Dodge Intrepid: How to replace Thermostat?
http://schematicsdiagram.blogspot.in/2012/06/2004-dodge-intrepid-how-to-replace.html
How to Replace Thermostat on Audi A4?
http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-thermostat-on-audi-a4.html
How to replace Thermostat on Acura Car models?
http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-thermostat-on-acura-car.html
Where is thermostat located on 2006 dodge magnum 3.5L?//
http://repairhelpcenter.blogspot.com/2011/10/where-is-thermostat-located-on-2006.html
Thermostat on AUDI 1.9 TDI?
http://repairhelpcenter.blogspot.com/2011/10/thermostat-on-audi-19-tdi.html
How to replace Radiator on Audi and VW car models?
http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-radiator-on-audi-and-vw.html
How to Replace a Thermostat.
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-thermostat.html
How to locate Thermostat on Any car model?
http://schematicsdiagram.blogspot.com/2011/12/how-to-locate-thermostat-on-any-car.html
Where is thermostat on Audi A6?
http://technoanswers.blogspot.com/2011/12/where-is-thermostat-on-audi-a6.html
How to replace thermostat on 1992 Buick century?
http://technoanswers.blogspot.com/2011/12/how-to-replace-thermostat-on-1992-buick.html
Replacing thermostat on 1999 Mercury Cougar?
http://technoanswers.blogspot.com/2011/12/replacing-thermostat-on-1999-mercury.html
Thermostat Replacement on Toyota Corolla?
http://technoanswers.blogspot.com/2011/12/thermostat-replacement-on-toyota.html
Where is thermostat located on 2005 Dodge neon?
http://schematicsdiagram.blogspot.in/2012/02/where-is-thermostat-located-on-2005.html
These will help.
Thanks.
1helpful
Its not very hard to replace thermostat.You can replace the thermostat.Follow the radiator hose that connects to intake manifold.That part connects to thermostat housing.For details regarding thermostat replacing,click this link below:--- http://howtobyme.blogspot.com/2011/10/how-to-replace-thermostat-on-2004.html -=--------------- This will help.Thanks.Helpmech.
1helpful
2answers
How do you replace a thermostat on a 1994 pontiac grand am 4 cyl
i own a 1989 ford laser gl and it over heated and bubbling.There is no water in the oil already checked . Could it be the thermostat or a gasket.
2answers
Replacing the thermostate
drain out coolant in a drain until below thermostat level follow radiator hose to engine cylinder block to thermostat housing.remove thermostat housing than remove thermostat.replace with a new o-ring on thermostat before installing new thermostat.make sure thermostat housing surface and engine block surface clean.before installing new thermostat.
Need to find where the thermastat is on a 2003 cadi
It is in the rear of the engine by the firewall and the intake manifold will need to be removed to gain access t it.
Engine Coolant Thermostat Replacement (LA3, LY9) Removal Procedure
  1. Remove the thermostat housing. Refer to Engine Coolant Thermostat Housing Replacement .
  3. Complete the following in order to remove the thermostat from the thermostat housing:
  4. 2.1. Depress the ears on both sides of the thermostat. 2.2. Rotate the thermostat until it clears the retaining feature of the housing. 2.3. Release the pressure from the thermostat. 2.4. Pull the thermostat from the thermostat housing.
Installation Procedure
  1. Complete the following in order to Install the thermostat into the thermostat housing:
  2. 1.1. Align the thermostat pin to the thermostat housing orifice. 1.2. Depress the ears on both sides of the thermostat. 1.3. Rotate the thermostat until it aligns with the retaining feature of the housing. 1.4. Release the pressure from the thermostat.
  3. Install the thermostat housing. Refer to Engine Coolant Thermostat Housing Replacement .
Top Ford Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
xxxxxx xxx
Are you a Ford Expert? Answer questions, earn points and help others
