Question about Drive ION iTT03x Turntable
I Have a problem with my Hard drive
My hard drive (Maxtor) does not appear in My computer, but when i check in the device manager it shows the properties of the Hard drive. I have tried changing the Jumpers. I need your help
I have the same problem
did you solve it??...and how?
Posted on Nov 12, 2008
My computer isnt reading my maxtor onetouch 4. i hear the click that it reads but i cant find it anywhere on my computer or disk management. and yes it is blinking. please help, i have 8 years of info on...
If the OneTouch does not appear in My Computer or cannot be found by Maxtor Manager, right click on My Computer icon and select Properties, Device Manager, Disc drives, and expand Disc Drives. There will probably be a yellow overlay over Maxtor drive, to show it has a problem, so right click on it and select 'Choose drivers for this device' to reinstall them. Without going online they seem to be found somewhere locally on the PC and I hope this will do the trick.
Dec 30, 2010 | Maxtor OneTouch 4 500GB External USB 2.0...
My Maxtor one touch has stopped being picked up by my computer when plugged in. When power source is plugged in led light (white) just blinks and never turns solid
You said it has stopped being picked up when plugged in so I hope this is note is relevantbut I don't think it is abnormal for it just to blink.
If the OneTouch does not appear in My Computer or cannot befound by Maxtor Manager, right click on My Computer icon and select Properties,Device Manager, Disc drives, and expand Disc Drives.
There may be ayellow overlay over Maxtor drive, to show it has a problem, so right click onit and select 'Choose drivers for this device' to reinstall them.
Without goingonline they seem to be found and reinstalled from somewhere locally on the PC and I hope this willdo the trick.
Also in case this helps, I don't find the OneTouch (Maxtor Manager) software appears when the driveis plugged in, so I think this is normal too.
You should look for an icon (a capital M within a blue disc) for Maxtor Managerin the taskbar, at the bottom right of the PC's screen.
Right clicking on this icon, (capital M), should bring up awindow with Maxtor Manager at the top.
Then click on the text 'Maxtor Manager' to open the program's window.
Hope this is what you wanted.
Dec 28, 2010 | Maxtor OneTouch 4 500GB External USB 2.0...
My harddrive is not showing up on my computer
If the OneTouch does not appear in My Computer or cannot befound by Maxtor Manager:-
Right click on My Computer icon and select Properties,Device Manager, Disc drives, and expand Disc Drives.
There will probably be ayellow overlay over Maxtor drive, to show it has a problem, so right click onit and select 'Choose drivers for this device' to reinstall them.
Without goingonline they seem to be found and re-installed from somewhere locally on the PC and I hope this willdo the trick.
Nov 03, 2010 | Maxtor OneTouch 4 Mini 160GB External USB...
Maxtor mini one touch 4
When you were in device manager did you notice if it was enabled? Did you try to force install the hardware somewhere else, or did you try to change what driver was used?
Ryan Frame
Creative Energy Associates Technical Center
Aug 24, 2009 | Seagate 80GB One Touch 4 Mini-maxtor USB...
My Computer does not show hard drive
I'm assuming you use Vista. First view the Maxtor drive (Start - Control Panel - Admin Tools - Computer Management - Disk Management) and see if Active or make it Active. You then can give it a drive letter.
Jun 10, 2009 | Maxtor Hard Drive
Maxtor 200 gb external will not show up in my computer after numerous installs
For Vista you don't need any driver for this, it should recognize and install automatically.
Did you check the device manager to see if the disk is recognized in the device list?
Next step is to check the Disk Manager (right-click My Computer, select Manage and then select disk management), and see if the disk already has a partition and has been formatted. If not, then it will not show up in "My Computer" with a drive letter yet.
Some details on external hard disk troubleshooting might also help.
May 20, 2009 | Maxtor Personal Storage 3200 (U01E200) 200...
Hard drive connects and then disconnects quickly
Sounds like a bad solder joint or break on the circuit board. If the data on it is important, you may need to use a data retrieval service.
Jan 18, 2009 | Maxtor DiamondMax 10 6L300R0 (6L300R020PK)...
Maxtor 3200 160gb usb hard drive not in my computer
Is it showing up in your USB system tray icon as a device?
Go to the Computer Management interface from the Administrative Tools. In there is a Disk Management node. See if the disk drive shows up there. Maybe it is listed without a drive letter and you need to supply one in order to see it in "My Computer".
Also, has the drive shown up properly before and is just suddenly not showing? Or is this the first time you're trying to use it? When you connected it to the USB port, did a little tooltip window appear and say it located a new hard drive? It should then install the right driver and notify you that it is ready for use. There is a chance you might need an updated device driver...
Dec 24, 2008 | Maxtor Personal Storage 3200 (U01E200) 200...
Not detected by My Computer
Go into Control Panel go into 'Administrative Tools', double click 'Computer Management' click on 'Disk Management'. Do you see the hard drive?? Right click on the drive and select 'Format'. If this didn't help, write back and we'll find another way.
Jul 14, 2007 | Maxtor Personal Storage 3200 (U01E200) 200...
Drive ION iTT03x Turntable Logo
Top Drive Audio Players & Recorders Experts
 Grubhead
Grubhead
richie46
Darrell
Are you a Drive Audio Player and Recorder Expert? Answer questions, earn points and help others
