Westinghouse 32" TV Model No.: SK-32H240S Widescreen HDTV no picture is display, but there is sound
  • Josh Tucker Jul 04, 2008
    I'm not sure if I stated my problem correctly. The TV worked fine,
    then this problem happened intermittently, and now it happens all the
    time. What happens is when I turn on the the TV, I see the picture for
    about 2 seconds, then it goes blank. It was working fine yesterday,
    then I turned it off for a couple hours, and came back to the problem
    I'm having. I've had this TV for only 4 months.
    What do you mean by vertical and horizontal ICs?
    The TV worked fine, then this problem happened intermittently, and now it happens all the time. What happens is when I turn on the the TV, I see the picture for about 2 seconds, then it goes blank. It was working fine yesterday, then I turned it off for a couple hours, and came back to the problem I'm having. I've had this TV for only 4 months.
  • 75 Answers
If it is under warranty, please go ahead and exchange it for a new piece.Any problem further, please leave a comment.
THANK YOU!!!!
Posted on Jul 04, 2008
  • 13,433 Answers
Double check that everything is connected correctly and you have the right signal input open. (you are watching the right channel - from where the signal should be coming from.)
  • 2,335 Answers
Check all your cable connections from any video source to the TV. Unplug your TV for about 30 minutes and see if that works.
If all of the above does not solve your problem, then your TV has a hardware malfunction.
Do you see any light on the screen when turns on?
  • Jaime Hernandez Jul 04, 2008
    If the TV is only 4 months old, still under manufacturers warranty.
    I would suggest to call the place where you bought it from since there's seems to be a hardware failure.
    Main support number 800-245-0600
    Guru:
  • 1,894 Answers
No picture is due to the vertical and horizontal ICs problem.
Problem: Westinghouse SK-32H240S HDTV has a flashing/blinking blue/red power led
hi when the colours flash again, press the menu button on the remote control and retune the tv hope it helps
regards
shaun
Mar 28, 2014 | Westinghouse SK-32H240S Television
Need westinghouse tv model sk-32h240s service manual
Westinghouse TV SK-32H240S http://legacywd.com/pdf/111_User_Manual.pdf
Aug 03, 2012 | Westinghouse SK-32H240S Television
I have a Westinghouse SK-32H240S 32" flat screen
First when tapping changes the picture you have somewhere a bad connection; in electrical board or wiring.
When the screen goes blank after a while means some capacitor is bad/old.
Mar 13, 2011 | Westinghouse SK-32H240S Television
I have a westinghouse tv model number SK-32H240S no picture
It seems that your unit has some sort of Video side, PSU fault, or a problem to the Video section that is shutting down the Power Supply Unit, PSU. This happens so that no further damage, and possible fire will occur.
You need to take the unit to a reputable service centre/man and ask for a firm "Quote" for the work to be done.
Jan 21, 2010 | Westinghouse SK-32H240S Television
Picture goes off sound stays on
Hi
Yes the problem has been solved. finally. The information on your web site was correct but the replacement board that I needed was no longer available. I ended up taking it to the local repair shop and he "worked on the board" that was messed up. Cost about the same as a new board would have, if I could have gotten one. Thanks for the great web site.
Dec 30, 2009 | Westinghouse SK-32H240S Television
Has sound,picture only comes on for a couple seconds at start up.
This is a Backlight Bulb or Inverter (power supply for backlight) failure.
If in warranty, take it to service
You can try to order an Inverter, or if needed you can get a replacement bulb (not easily available)
May 18, 2009 | Westinghouse SK-32H240S Television
Westinghouse SK32H240S 32'' LCDHDTV Picture appears and Disappears
This problem is caused from a problem with the main board. The main board will need to be replaced. It runs from $100.00 to $150.00.
Mar 28, 2009 | Westinghouse SK-32H240S Television
Can't progam my direct tv remote to operate my westinghouse 32''tv
I don't have DTV anymore, so I don't remember the exact code I used for my SK-32H240S, However, I do remember that I found one that worked at this site. Scroll down to locate your remote series # - it most likely will be printed on the upper left corner of the front of the remote - as an example, mine says RC64. Click on the corresponding listing, then follow the directions on the site. I tried only a few codes before finding one that worked correctly. Good luck.
Dec 27, 2008 | Westinghouse SK-32H240S Television
Televison & Video Logo
57 people viewed this question
Top Televison & Video Experts
