Question about HP OfficeJet d145 InkJet Printer
Ink cartridge replacement
Replaced blk ink cartridge and windo still indicates "supply exusted'
It would appear your printer (or HP) believes the time for the use of your ink cartridge has expired and therefore will not accept the cartridge. Need to isolate the battery in the printer for an hour or so. Battery is inside the machine right hand front ie put a thin credit card between it an one of the terminals as it is hard to replace if you remove it.
Posted on Jul 15, 2008
Why wont my printer print in blk?
take the black cart. out and dab on a wet paper towel, unplug printer and use q tip to clean the print head where the cartridge goes with alcohol, if that doesnt work you have a bad cartridge
Nov 09, 2015 | Office Equipment & Supplies
I installed a new black cartridge and now it is not printing. I need the installation guide for allignment
Please follow below instruction. Otherwise, visit this link. Link
We hope we have provided you a solution to your problem.
Thank you.
The Canon Pixma Mp160 is an all-in-one printer, scannermag-glass_10x10.gif and fax machine. Replacing the cartridge in the printer requires little effort. Make sure to use the correct replacement cartridges for your MP160; installing the wrong cartridge type could prevent your printer from working or cause it to fail. Use caution to prevent ink spilling or dripping on you.
Step 1 Identify the cartridge that requires replacement. Press the "Copy" button to display the ink level. "BLK" indicates your black ink cartridge; "COL" indicates your color cartridge. If the display is only one bar (or none), then the cartridge should be replaced.
Step 2 Open the top compartment (scan lid) on your Canon printer. Pull back the compartment support legs to hold it open.
Step 3 Put on gloves, and then push the cartridge down to unlock it. Pull it toward you to remove it from the printer.
Step 4 Remove the tape strip from the replacement ink cartridge. Insert the new ink cartridge (black on the left, color on the right) at an angle, with the gold circuit facing down and towards the front of the printer. Push the cartridge up to lock it in place.
Step 5 Repeat the process if you are replacing multiple cartridges. Close the scan lid when you are finished. If the "Low Ink" warning does not go away, then turn the printer off, wait a few minutes and turn it on again.
Aug 01, 2010 | Canon PIXMA MP160 All-In-One InkJet...
Kodak 5350 Color Ink Error Problem Solved
Yes the cartridges of all newer printers have chip that indicates the cart ink level, when the cart is empty the chip self destructs.
May 04, 2017 | Kodak EASYSHARE 5100 All-In-One Printer
I have replaced both the color and black ink cartriges, however the printer is giving me the "color ink low" indication and a check ink u163 blk alarm. We have reset the cartriges to no avail.
Per the troubleshooting guide found on THIS WEBSITE, it would be recommended to ensure that you have the proper cartridge for your printer. Also, double check that you have fully seated in the cartridges and that they align as they should. Lastly, it is important that you are using Genuine Canon ink cartridges to ensure longer printer life, not void any warranty you may have remaining on the printer, and most importantly to ensure proper communication with the actual cartridges.
Nov 12, 2009 | Canon PIXMA MX310 All-In-One Printer
Hp all in one 6180 won't print
The ink cartridges included in the box are used to set up the printer. This type of ink cartridge is called a “host” cartridge. Once the printer has completed device initialization, they are marked as regular “trade” cartridges. This error only occurs if the printer has finished the device initialization process and one or more of the ink supplies inserted into the printer are a “host” supply.
Solution: The indicated ink cartridge(s) cannot be used after the device has undergone first-time setup. Once the product displays the message ' The following ink cartridges cannot be used after device initialization and must be replaced ', the designated host cartridge(s) (indicated by the color icon(s) on the display) that were rejected should be discarded or recycled and never used again. Replace the ink cartridge(s) with the appropriate “trade” ink cartridges for the HP All-in-One.
May 14, 2009 | HP Photosmart C6180 All-In-One InkJet...
Polling the ink cartridges for available ink level.
then click on replacing ink supply, and the first box down tells you about ink cartridge levels.
There you go Utah
Please leave rating...thank you kindly
May 10, 2009 | Epson Stylus Photo R220 InkJet Printer
I just replaced both ink cartridges and the alarm light is now on. The LCD screen reads check ink, U053, BLK COL. I can't get the printer to work or perform any functions.
On the canon MX300, holding the "reset" button down for about 10 seconds will extinguish the alarm light & should normalize all functions. The ink level will still indicate "low" , just ignore it.
Apr 08, 2009 | Canon PIXMA MX300 All-in-One Printer
Display shows: printer cartridge incorrect
It seems like you are using incorrect printer cartridges.....
Make sure that part number on ink cartridges should be :
MK990 Cartridge, Ink, Standard, Series-9, Black CTRG,INK,STD,SERIES-9,BLK 0 1 0 Yes 1 N MK991 Cartridge, Ink, Standard, Series-9, Color CTRG,INK,STD,SERIES-9,CLR 0 1 0 Yes 1 N MK992 Cartridge, Ink, High-Yield, Series-9, Black CTRG,INK,HIYLD,SERIES-9,BLK 0 1 0 Yes 1 N MK993 Cartridge, Ink, High-Yield, Series-9, Color CTRG,INK,HIYLD,SERIES-9,CLR 0 1 0 Yes 1 N MK995 Cartridge, Ink, Series-9, Photo
Nov 10, 2008 | Dell 962 Photo All-In-One InkJet Printer
I just replaced my blk ink cartridge also, nothing prints
Jul 24, 2008 | Canon MultiPASS MP730 All-In-One InkJet...
HP OfficeJet d145 InkJet Printer Logo
126 people viewed this question
Ben Johnson
