Question about Dell Dimension 5100 (D51L1) PC Desktop
Shutting down my 5100 tends to want to shut down on its own after approximately 5 minutes of run time. The power supply was tested and it was said to be fine. The heat sink was re pasted, with the same result. The hard drive was wiped out and the os was reinstalled, that did'nt work. The cooling fan runs fine. everything is clean and free of dust. The problem was only on occasion, then it became more frequent over time, now its after five minutes being on.
    Scholar:
  • 160 Answers
For solving your problem do the following:
1. Start -> Settings -> Control Panel
2. Select Power Options
3. Power Options Window appears
4. Choose the Power Schems and select the sub options as "Never" in each combo box for every options
5. Click on Apply
6. Repeat step 4 for every power schems
7. Click on OK
Let me know that your problem is solved and rate me as Fixya!
Posted on Jul 05, 2008
    Guru:
  • 1,342 Answers
Try replacing the CMOS battery.
What Could Cause My Computer To Shut Down For No Reason?
What brand of pc is this? Download a diagnostic program to test internal functions. Sounds like maybe a motherboard or power supply issue.
Jul 28, 2014 | Dell Inspiron 530s Desktop Computer
IN104 automatic shutdown
Hello, my infocus in104 will power up for a while (1- 5 minutes) when connected to the power supply and turned on, after that it automatically shuts down. Power button does not light red when it automatically shuts down and need to be unplugged for a minute or more before red power button will light up again.
Mar 21, 2013 | InFocus IN104 Projector
Main remote control is not working can you bypass the remote temporarily
No. However you may be able reset the thermostat to its factory setting.
Turn the thermostat off.
Shut of the gas and water supply to the unit.
Unplug or disconnect the unit from its electrical power source. Disconnect the thermostat from the heater.
Wait approximately 5 to minutes, and then reattach the thermostat wires to the heater.
Turn the water supply on and open the tub faucet to its hottest setting for about a minute.
Turn the faucet off and make sure no water water is flowing anywhere in the house.
Turn the gas supply back on.
Reconnect the thermostat wires to the heater.
Connect or turn the power supply back on.
Wait at least 2 minutes before turning the thermostat power button back on.
After the thermostat power button has be pressed, wait an additional 2 minutes before running water.
Test the heater at this time. Turn the water on at the farthest faucet to its hottest setting. measure the temperature with a cooking thermometer.
If you need to make adjustments to the water temperature, either up down, shut all the faucets off first.
The thermostat should read 100 degrees Fahrenheit when it first starts.
If you are receiving an error massage, consult with the manufacturer.
If the thermostat is reading the correct water temperature but the unit is not operating, there are other issue need to deal with. Let us know if this works or you need further assistance.
Sep 26, 2010 | Rheem Tankless Water Heater Main Remote...
Behringer mixer power goes off after running about 5 0r 10 minutes then power turns on.what is problem with the power supply board
That time lag would indicate a thermal problem.
Likely the power supply is a switching type that has some three terminal regulators after it such as 7805, 7815, 7915.
These have thermal protection in them and one may be shutting down.
Use circuit cooler to isolate the part that is shutting down.
May 20, 2010 | Behringer Xenyx 1002fx Mixer 10 Input 2...
Come on, boots up, then shuts down 5 - 10 minutes later.
check your power options make sure you don't have hibernation enabled, its in the system control panel. try booting from a linux live cd like Ubuntu which you can download for free. If it runs fine under linux, its a windows problem, if it keeps shutting down its a hardware problem. Could be bad ram, or CPU overheating.
May 09, 2009 | Computers & Internet
ACER Aspire 5100 powers down at will
When you turn the laptop on hit f8 until the menu comes up, try use the last good known configuration. If that does not work tap f8 goto safe mode and then to system restore and restore it to an earlier time. Let me know if it works.
Apr 15, 2009 | Acer Aspire 5100 Notebook
Heater shuts down prematurly
If the heater runs fine for the 15 or so minutes without smoke/odor- do this
  1. check for water droplets on bottom of tank
  2. check for restricted fuel filter
  3. test photocell
  4. test safety control (reset)
You don't state whether this is a spark plug heater *or* Hot Surface Ignitor type. I made the assumption you were inquirung about a Spark Plug Heater. Disregard the list if the heater is an HSI type---- troubleshooting is different.
More troubleshooting tips for a Spark Plug Type heater
Dec 25, 2008 | Reddy R70ET Utility Heater
Compressor starts and doesn't stop
Relay for the compressor may be stuck ( Contacts welded) both the fan and the compressor should operate at the same time. Have the relay(s) checked and possibly replaced.
Apr 29, 2008 | Dometic Rooftop RV Air Conditioner
Dell Dimension 5100 (D51L1) PC Desktop Logo
Alun Cox
