Question about Dirt Devil Vacuums
Dirt Devel MVP Model O86925: What replacement belt do I need and how do I replace it? Thanks. ljh044@bellsouth.net
No funciona mi mp3
Posted on Jul 03, 2008
How do I get bag of my hand held dirt devel for stairs
Fixya does not sell replacement Dirt Devil bags.
Aug 12, 2017 | Vacuums
My dirt devil keeps shutting off randomly
It's overheating. Empty the cup and replace the filters. There's a breaker that opens up and turns it off when it gets too hot. When it cools down it closes back up and it will run again. It'll argue with you til the end of time or until you fix the problem.
Good Luck
Jan 13, 2013 | Dirt Devil M085805 Upright Vacuum
Does the MVP vacuum motor armature have brushes that need to be changed?
yes the motor has brushes which need to be changed if worn out.
Jun 19, 2011 | Dirt Devil Ultra MVP Vacuum
I need to put a new belt on the Ultra hand vac 8230. How do I get the cover near the belt off?
If you go to this URL:
http://www.dirtdevil.com/manuals/?id=497300a5-3758-479d-a8e5-0555f40193f0
you can see the pictorial of what you need to do to change the belt.
Oct 02, 2010 | Dirt Devil Ultra MVP Vacuum
How do I change the bag on a dirt devil model 103?
On the open end of the bag that slips onto the vacume, there is a cloth "tab" sticking up from the band. Take hold of this tab and lift up while easily pulling back until you see the band about half way off the vacume. Now, you can take hold of the band and pull the bag the rest of the way off. You will notice that there is a "rib" in the middle of the band on the side that faces the vacume. That rib fits into the groove where the band goes on the vacume. When you install the bag put the band on this groove and work the band on around the housing. You can center the "tab" anywhere, just place it where you can get to it easy. The other parts you need are on the internet, I found them all including that rubber plug called the "attachment port" plug. The p/n for the replacement part is 3-201744-601. The original p/n is 3-501744-601 but you'll be better looking for the replacement part number. Good luck!
Dec 30, 2009 | Dirt Devil Vacuums
Want insturtion book and bag # for vaccim #086355 upright and bag size
your vacuum takes a type U bag oem part # 3920750001 and the belt is a style 4&5 belt
May 26, 2009 | Vacuums
Dirt devil mvp not sucking
Could be bad filters, is there suction at the end of the hose. That will tell you which direction to start looking. If no suction at hose end, then filters could be the problem. If you have suction, then the problem is down lower, dirt inlet is clogged, if belt has never been changed, then I am sure it has stretch to the point that under load it doesn't turn like it should. Could even be that although the motor is running, it may be running at a slower speed, in which case it would have to be replaced.
Oct 14, 2007 | Dirt Devil 12 Amp HEPA Filter Vacuum...
Vacuums Logo
Top Dirt Devil Vacuums Experts
Nick Olsen
JoeVacs
Are you a Dirt Devil Vacuum Expert? Answer questions, earn points and help others
