Question about Kenmore 22422 Top Load Washer
My washer isn't spinning, so i need to "Tighten some Belt", how can i do that? replace broken belt
  • 3 more comments
  • reueljoe Aug 02, 2008
    Kenmore 90 series. model 110 26912 60
    doesnt spin, doesnt agitate, just a whirring/chittering noise
    cant see a belt, although i do not have the back entirely off.
    seems like drainage and infill running ok.
  • jefferson phillips Aug 24, 2008
    Jeff; I hav the same problem and i replaced the controller but it did not fix the problem. what can I do?
  • Anonymous Dec 26, 2008
    My kenmore 90, Mod# 110.28902790 does not spin. This model have a belt or direct drive?
  • Anonymous Mar 29, 2009
    I am having the same problem with my kenmore 90 series, # 110.26912691. How do I put the belt back on? It is not broken.
    Thanks,
    Renae
  • Jeff Rockwell
    Jeff Rockwell May 11, 2010
    Is this a Kenmore? What is the model number? It should be located along the wash tub opening under the lid. If this is a recent model, your washer does not have a belt. It may be a direct drive, but I need the model number to confirm. Please post back and let me know.
The part no. 3949670 and 90 series kenmore washer
Posted on Jul 06, 2008
Frigidaire front loading washer drainage
Hello - Is the washer draining or not draining? If it is not, this particular issue could be caused by a variety of reason. I would suggest trying the following steps:
1) Verify a circuit breaker isn't tripped
2) Advance the timer control dial slowly 360 degrees-
If the washer starts spinning, then that means the motor and drive belt are fine but that there is something wrong with either the timer control dial or the agitator solenoid. Call in a professional for this.
If the washer doesn't budge, then verify that the drive belt(s) is attached and not broken by removing the back panel. If the belt is broken, replace it. If it is loose, then tighten it by loosening up the bolt holding the motor and moving it on its swingarm (much like a car alternator) until there is a 1/2 to 3/4 inch deflection in the belt.
Some washers use reversing motors. It's possible the motor works on the spin cycle but not on the wash cycle. If so, call a pro.
3) Visually inspect the lid safety switch- Is it loose or cracked? If so, the washer might work intermittently, stopping at different cycles.
4) Check motor and drive belt- Remove the main access panel (usually in the back). Is the motor spinning, but the drive belt isn't? If so, then you have a drive belt problem.
Oct 01, 2012 | Frigidaire Washing Machines
Drum wont turn but the moter does
Hello Deanna - This particular issue could be caused by a variety of reasons. I would suggest trying the following steps:
Sep 30, 2012 | Frigidaire Affinity ATF7000E Front Load...
Washer spins but will not agitate
If the washer starts spinning, then we know the motor and drive belt are fine but that there is something wrong with either the timer control dial or the agitator solenoid. Call in a professional for this.
Aug 14, 2012 | Frigidaire FEX831CS Top Load Stacked...
Washer is not agitating in whites and slowly in colors. What and how do we troubleshoot?
Aug 05, 2012 | Frigidaire FEX831CS Top Load Stacked...
Washer not spinning
Hi, if it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.
If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
Thanks
Jul 26, 2012 | Maytag Washing Machines
On spin cycle drum going round but not spinning so clothes stay wet
Hi, if it doesn't spin, check to see if the motor is running, then proceed as follows:
Jun 20, 2011 | AEG Lavamat 74640 Front Load Washer
Agitator won't spin and water won't drain during spin cycle
Hi
Try these things first.
If the washer doesn't budge, then verify that the drive belt(s) is attached and not broken by removing the back panel. If the belt is broken, replace it. If it is loose, then tighten it by loosening up the bolt holding the motor and moving it on its swingarm (much like a car alternator) until there is a 1/2 to 3/4 inch deflection in the belt. Some washers use reversing motors. It's possible the motor works on the spin cycle but not on the wash cycle. If so, call a pro.
4) Check motor and drive belt- Remove the main access panel (usually in the back). Is the motor spinning, but the drive belt isn't? If so, then you have a drive belt problem. Go here. If the motor isn't spinning, then go here for washer motor troubleshooting.
If none of these tips resolve the problem, then there's probably a more serious problem with either the motor, the transmission or the agitator itself. If this is is the case, call in a pro.
Thanks for using Fixya.
May 22, 2011 | Maytag Washing Machines
Whirlpool Stylemaster 4217141 tub not moving wash/spin cycles
Sounds like the drive belt is broken or very loose. Take off the back and check the belt. If loose or missing, tighten or replace. This is usually done by loosening the motor support bolts and moving the motor until the belt is tight, then re-tighten the bolts. Replace belt in the same way.
Apr 22, 2009 | Whirlpool Washing Machines
Washing machine doesn't agitate
If washer fills with water but doesn't agitate, the problem is likely to be a faulty lid switch, a broken belt, or a problem with the motor. Note: direct-drive washing machines do not have belts. 1) Check the spin cycle. If this works, the motor is operating and the belt is not broken. If it doesn't, the belt may be loose or broken. If you're fairly handy, tighten or replace the belt, otherwise call an appliance repairperson. 2) Check the lid switch and the tab on the lid that strikes it. If the plastic tab is broken, the washer may halt during certain cycles. Press and release the switch: if it doesn't click each time you do this, it's probably broken. If you're experienced at home repair, you can remove the switch, test it, and replace it if needed; otherwise, call an appliance repair service person. 3) Call a repairperson; there may be a problem with the controls or the agitator solenoid may be broken.
Jan 18, 2006 | Hotpoint Aquarius WD63 Front Load...
Kenmore 22422 Top Load Washer Logo
285 people viewed this question
Sal De
fordexpert
Robert Rankin
