Question about Belling 644 Electric Kitchen Range
Belling Format cooling fan
The cooling fan keeps running when all is cooled down. powering off stops it but it can come on for no reason when the cooker is not in use.
Do you know what part this requires to fix? Thermostat,? controller?
Is it a part I can get and will I be able to fit it?
Thanks Martin
  • m44sel Jul 07, 2008
    Hi tresilla,
    I rang Belling for the part and they said it required a small circuit board part that cost abot £130 and was not available anyway as the cooker is about 20 years old.
    With your knowledge is this right or am I getting duff gen?
    It is the case fan controller I need, The fan keeps running long after the cooker has been switched off and has been known to start for no reason.
    Regards, m44sel
    President:
  • 1,462 Answers
I assume you mean the casing fan and not the fan inside the oven.
this is controlled by a fan stat which is inside the casing. cheap part and easy to fit. iv forgotten the exact location but remember it located at the top
Posted on Jul 04, 2008
  • douglas smith Jul 08, 2008
    some older belling did have a controlling pcb for various functions including the casing fan - didn't realise it was so old. i remember this pcb is located somewhere behind the control panel. might be worth while getting at it to check for damage.
I have a belling double oven. The bottom is fan assisted. It all works okay but when it is turned off it is making a drumming noise after the fan has stopped. This lasts for at least 5 minutes. Any...
Sounds like the cooling fan bearings are worn, hence the noise after you turn the cooker off.This fan is in the top of the oven and helps to keep the inside cooker electrics cool and often keeps going for a while after you have turned the cooker off. Best to call an engineer to check this out for you!
Nov 30, 2014 | Ovens
LG Express Cool Turbo GR T542G Stopped cooling
it should run when the comp is on and the unit is calling for cooling, you most likely need a new fan for your unit.
Aug 10, 2013 | Refrigerators
1986 Mazda 323 coolant fan comes on when motor is hot and stays on.
Is the engine actually cooling off? If the temp switch isn't seeing a drop in temperature, it will keep the fan running.
Oct 02, 2017 | Cars & Trucks
When I plug the unit into power, the CPU fan runs very fast but no boot, and then when I press power on the fan slows down and the PC boots normally. It shuts down in about 30 minutes with no sign of...
Sounds like you are overheating. One way to tell if it's overheating is you say it will run for about 30 minutes then shuts down. When it shuts down try rebooting to see if the boots successfully. If it fails to boot successfully right after it shut down then you are probably overheating. If you wait awhile to let it cool down for 30 minutes or so and if you reboot and it does it successfully you definitely have a overheating problem. If I remember correctly all those compaq sr series have loud and fast running fans. Computers overheat because of three reasons for the most part: 1) A fan has stopped working. 2) The Thermal Paste on the CPU and Heat Sink has dried up or is not thick enough to keep the unit cool. 3) Dust has clogged the fan vents and inside the computer. Fortunately for you desktops don't have to be completely disassembled like laptops to get to the fan, CPU and heatsink. Just pop the case and you'll see the components attached to the motherboard
Mar 18, 2012 | HEWLETT-PACKARD Compaq Presario SR5518F...
I have a new belling b170f and have just turned it on however the fan at the back wont turn off. how long would I expect the fan to run. The oven has not even been hot yet
If its less than a year old then call belling as it sounds like the thermostat for the cooling fan is faulty. Its designed to cut the cooling fan in at around 65 degrees celsius to protect electronics.
Mar 02, 2011 | Ovens
Why does my radiator cooling fan remain on after I turn off the ignition?
The car has a computer that is linked to the engine. It is hard wired to it meaning the computer is always on. Upon shutting your engine off taking the keys in hand the computer is still on sensing the engines temperture. The coolant sensor will send power to the relay to keep the fans running untill cooled down enough. Then the sensor will cut off power to the relay shutting off the fans
Mar 19, 2010 | 2002 Jaguar X-Type
Air won't cool when the car is stopped on a 2004 chevy cavalier. car temp is normal
make sure electric coolant fan is running.if not check or replace fan relay.the coolant fan has to be running to cool down refrigerant in condensor.so refrigerant in condensor is cooled back down to high pressure liquid so it can go to evaporator.see ifcoolant fan not working.the AC is not going to cool.when you driving the condensor is cooling down from moving air when car is going.when you come to a stop.cooling fan suppose to be on so condensor gased can be cooled down.
Jul 10, 2009 | 2004 Chevrolet Cavalier
Amana Cooling Condensing Unit fan stops spinning after 15 mins
Capacitor, dirty condencer coil causing the motor amps to run too high. But most likely worn bearing on blade side of motor causing it to pull to one side causing it to over heat and shut down. Sleve bearings should have no side play.
Jun 28, 2009 | Amana PTH123B25AJ Heat Pump Air...
Infocus in26 fan runs continually
The fan does run continuously on this projector however it should be running very very slow when the projector has completed it's lamp cool down routine.
The reason for this is that a portion of the switching power supply remains energized (running) when the projector is at rest. But as I mentioned it should run very slow in this state. If it remains running full blast then most likely the fan speed control chip is shorted which can cause fail 2 ways, either the fan 1. runs full
speed or 2. remains stalled (then the projector will go over-temp and shut itself down) I hope this answers you question.
Cheers
Dec 18, 2008 | InFocus IN26 Multimedia Projector
Install a new ststem cooling fan
as i recall, the fan is at the back just under the hob and is removable without removing the hobtop - just held in by 3-4 screws. if i'm wrong and hobtop has to be raised, this is quite easy. take off the side panels and you will see 2 screws each side holding the hobtop on. don't confuse them with the screws which hold the plate retaining bracket in place but it is all quite obvious. as a thought, are you sure the fan is faulty? the fact it is not operating doesn't mean it is faulty. the fan is turned on by a fan stat which may also be faulty.
May 11, 2007 | Belling 644 Electric Kitchen Range
Belling 644 Electric Kitchen Range Logo
327 people viewed this question
Top Belling Kitchen Ranges Experts
Paul Carew
John Tripp
John Tripp
Hjalmer Lamminen
Hjalmer Lamminen
Are you a Belling Kitchen Range Expert? Answer questions, earn points and help others
