There should be a decal on the mower deck with the decal part number 711457 that has the belt routing on it.
Go to this link: https://groundscare.custhelp.com/ci/fattach/get/24425/1274204499
and see page 3. Picture is MX10511.
If this is NOT your deck please so state and I will look again. If your deck still has a deck part number decal on it and I gave you the wrong routing please... if you can find the deck PN pass that in your response.
Thanks for choosing FixYa,
"Seasons Greetings"
Kelly
The Victa V125 mower is a heavy piece of garden equipment. If you have spun off the belt while the unit was in use then fixing the belt back should be the least of your worries.
Engines such as this dont just get their belt spun off usually the belts spin off as a result of poor alignment of the levers and if these levers are not properly adjusted the belt will spin off again and again.
But if you just want to fix the belt back usually these belts have an adjuster which usually is in the form of a large bolt. once you twist this adjuster the levers ease on the tension you put in the belt and adjust the bolt back. But it would be wise to get an expert check the levers for alignment to avoid the belt spinning off again and causing more damage.
Hope this solution has been helpful?
Sir this does not help me at all as I dont know how it goes back on thats why I needed directions which pulley it went into etc. I cant take it to a mower place as one it is so close to christmas, I dont have any way of getting it there and I need to get my lawn mowed before christmas as I have family coming over. I know thats not your concern but that is my dilema thats why I needed to know how to put the belt back on.
Thank you Have a nice christmas.
