Question about Alpine MRP-M850 Car Audio Amplifier
Cut off Every time the bass drop from my woofers my amp cuts off but is still on wats the problem
    Problem Solver:
  • 4 Answers
Ok you dont have the power you need go to wal-mart and get a cap kit it cost about 80.00 to 120.00 that will fix it
Posted on Jul 04, 2008
No sub woofer output or very little
Your sub amplifier is detecting an overdrive condition and reducing volume to prevent the output stage from burning up. When reduced volume doesn't work, output is cut completely for 10 minutes until things have cooled down.
Mar 27, 2017 | JVC KD-R740BT
My radio cuts out when i turn it up and the bass hits on my subwoofer
You are drawing to much power to the amp. I assume that there is no dedicated power fron the battery to the amp. If there is you should look into a capacitor
Feb 13, 2013 | Car Audio & Video
Can I use my Logitech x-230 speakers without the sub-woofer? My sub-woofer got busted!! Any suggestions?Perfectly good speakers!
i had the same problem with same speaker system. the amp for this system is inside the bass speaker. if your amp is still working but your bass speaker is not you could cut the wires to that speaker making sure the cut wires do not short out. i was quoted more to repair them than it was to buy a new set. but i wont be buying logitech again as ive had two lots fail.
Jan 18, 2012 | Logitech X-230 Computer Speakers
Whenever i turn the volume up with the bass up the music cuts out and a light on the amp says offset. How can i make it stop or how can i fix it?
What size woofers are you running and what size is the amp? It sounds like you are overloading the amp.
May 20, 2011 | Car Audio & Video
I think I blew out the woofer...low frequency rumbling...is that something that can be easily switched out?
The woofer would only blow if it was overloaded with too much signal. The common cause of this connecting a speaker of lower power than the amp or ohms than it. The simple way to cut out rumble is at the amp by reducing the bass, however most amps will cut all the bass and not what you want. Another way is a filter designed to cutt bass or low sounds. However your best bet is to use a Graphic Equalizer to control the tone, most have a 31khz control which will cutt the rumble you describe, but keep the wanted bass sound.
Oct 19, 2009 | Mackie MR5 MR5 Reference Monitor
Problem
you need to get a bigger ground wire and the cut in and out will stop the cutting in and out is the protection mode starting if it cant hold the thump a capacitor 2farad will hold the bass
hope this helped
Feb 15, 2009 | Eclipse Premium 34230 Car Audio Amplifier
Speakers cut off when bass goes up...
sounds like you hava a load problem.if your'e running your woofers at 1ohm,make shure your amp is 1ohm stable.....
Jul 03, 2008 | Car Audio & Video
Amp cuts off
You may have a problem with the power source feeding the amp. You need to check the voltage across the amplifier's B+ and ground terminals when the amp is playing/cutting off. If it's dropping below ~11 volts, you need to determine why it's dropping so low.
Sep 18, 2007 | Alpine PDX-1.1000 1000W x 1 Car Amplifier...
Alpine MRP-M850 Car Audio Amplifier Logo
78 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Tygh Duval
Tygh Duval
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
