Question about Microwave Ovens
Built in kitchenaid microwave starts beeping, then won't function. flipping breaker helps sometimes, but other times it doesn't help.
  • Anonymous Jul 04, 2008
    Turn on microwave and it made a load sparking noise. From that point on it will turn on but it will not heat up.
  • Microwave Ovens Master
  • 9,098 Answers
To bsm
When this happens, what is shown in the display? Is it the same displayed info each time?
This is usually a failing membrane keypad, but your reply will help me know if it's that or some simpler.
We're happy to help and we appreciate your thoughtful rating of our answer.
to Guest
Since yours is a different problem, please repost as a separate message and include your brand and model number.
Posted on Jul 04, 2008
Kitchenaid architect II microwave won't stop beeping
Hi Carole,
Dear you most probably have problem with electronic control board in your microwave oven.
It has to be fixed by an Electronic Technician.
If you have knowledge in Electronics then I can help you fix by yourself.
Just let me know
Regards
Ashwin
Dec 17, 2014 | KitchenAid Microwave Ovens
Frigidaire FFMO1611LS microwave does not beep
Hi Paul R - Reset the microwave by either unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and restart unit. If unit continues to not beep, then it may be experiencing a wiring failure or faulty board. A professional is recommended to properly assist with the repairs. You can often locate a certified technician by visiting the manufacturer website.
Feb 28, 2013 | Frigidaire FFMO1611LS 1.6 Cu. Ft. Built-in...
Microwave won't start when pressing the start botton
call Chas&son,s appliance repair at 579-379-0993 and they will come out the same day no less okay
Feb 13, 2013 | GE JE2160 Microwave Oven
My Bosch electric oven displays "Unlocking Door" and none of the buttons work. I've cut the power at the breaker and then turned back on, but it doesn't reset. Do I need to call a...
You haven't said how long you cut power for when you flipped the breaker. These things sometimes have heavy capacitors in them taht will take a time to discharge and allow everything to reset. Before you call a service tech, unplug the unit (or flip the breaker, whatever) and leave the unit disconnected for half an hour. This may just be all you need to do.
Jun 30, 2011 | Microwave Ovens
Kitchenaid built in Microwave model YKHMS155LSS-0 Starts by itself, displays PAN, beeps intermittently and sometimes displays an F1 error
Dougmcduff have you resolved this problem with you kitchenaid microwave turning on periodically??? I have the exact same problem. Any solutions? I called Kitchaide and no help there.
Mar 10, 2009 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Microwave/Convection Oven has mind of its own: turns to Crisp mode on its own.
Yes this is a touchpad issue. As you have noted the crisp button is stuck and this is the cause of this. You can try removing the keypad and push up the pressed button. If its jammed then replacing it is the only way.
Sep 02, 2008 | KitchenAid KBHC109J Convection/Microwave...
Microwave will not respond to any button being pushed
The service man just left it was the 20 amp line fuse. Have one on order.
Jun 11, 2008 | KitchenAid KBMC140HSS Convection/Microwave...
Kitchenaid microwave oven KBMC140HSO
I started having the same problem with my KBMC140HSSO. You cannot see the error codes without disassembling the control panel (the codes are on another display that covered by the front panel). After doing so I found the error code to be F2, E3 which is "Key held down too long, or key shorted". I am ordering a replacement keypad and will report back if this fixes the problem.
Mar 29, 2008 | KitchenAid KBMC140HSS Convection/Microwave...
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
