Question about Video Game Consoles & Games
Nintendo ds lite power cutting out
My sons ds lite's power cuts out & the whole things shuts off even when fully charged?
  • 30 Answers
I need a proper diagnosis. Does the top screen flash?
email pcs_cheltenham@ymail.com I may be able to help
Posted on Jan 20, 2010
I have a nintendo ds lite, that is older but only used a few times. My son just stuck a metal object in the back game slot while he was playing pictochat and the whole thing shut down and will not turn...
needs main fuse ( F2) repalcing
they are surface mount ( solder) fuses and small (1.3mm)
for any more help see www.dsdoctor.co.uk
may also need a game slot if pins are bent :-)
Jun 19, 2010 | Nintendo DS Lite
Help! My sons ds lite is two years old and has just
might be good to take out battery then put it back in, if that doesn't work go to nintendo forums, maybe reimburse you.
Dec 27, 2009 | Nintendo DS Lite Console
Son dropped his nintendo DS lite, now it won't
this happend to my sister it dont work anymore had to get a new 1 when ever it dropped it broke a little chip thing inside take it to a gamestop take it appart see what the problem is
Nov 16, 2009 | Nintendo DS Lite Console
My son's nintendo ds will not power on.
possibly, the battery went bad after overcharging...but is that supposed to be charging automatically? have the battery checked
Aug 11, 2009 | Nintendo DS Lite Console
Power shuts dowd
the battery is not charging correctly or has a fault contact nintendo
Aug 06, 2009 | Nintendo DS Lite Console
When i try to power on my son's DS Lite, the red light is on, and both screens power on for about 2-3 seconds max and then the system shuts off. It also wont charge when connected to the wall.
You may need to get a replacement battery pack when the battery is below 30% the light will turn red, the battery requires 4 hours to charge, and when the battery is fully charged the amber colored light will turn off. If you still need to purchase a new battery contact nintendo cust serv at 800-255-3700 or you can order online at nintendo.com You will need a #00 philips screw driver to remove the battery cover, install the battery with the 2 tabs in first, close compartment and allow battery to fully charge before use. The average battery will last for about 500 charges. Hope this helps
Aug 05, 2009 | Nintendo DS Lite Console
Nintendo DS Lite won't come on
@JoepIt, you have a defective LCD screen. Could be upper of lower (I thing for 99% the upper).
@pietras1422, on the mainboard next to the power-switch, there is a resistor. If could be loose or is missing completely. Problem will occur when the DS Lite is dropped to the ground
Nov 18, 2008 | Nintendo DS Lite Console
Ds lite charging lite comes on but when i press power button nothing happens
Are you leaving the DS charge until the light comes off? Remember that there are two likes too, one for charging and one for power. If you're just charging for some random period of time (lets say... One hour) then your Battery isn't going to be fully charged. The best way to ensure that your DS Lite is charged is to leave it charge until the charge light turns off. You can play your DS Lite while you are charging (I do it all the time), but it just means that you're just running off of the outlet.
A good test is to charge it fully (until the charge light comes off), unplug the charger cord (Make sure it's secured tightly to your DS while charging), then play for a little bit, your light should be a normal color (green).
If you cannot even play by using the outlet, then you need to
find a charger cord that actually works (You may need to send in the charger for replacement). If the same thing happens with 2 different batteries (assuming that you have two official Nintendo batteries).
TIP: Also run your fingers across the Charger cord. You're going to get a slight friction burn from the rubber, but you're going to get all of the kinks out of the wire in the cord. My charger cord had a similar problem (did not charge all the way, only charged until I moved the DS) but when I ran my fingers across it (pinching) it worked again.
Also check the pins in both charger cords, charging will not work if one pin is missing, nor if any are bent.
May 12, 2008 | Nintendo DS Lite Console
Video Game Consoles & Games Logo
175 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
