Green picture tv bright green
  • asil69 Jul 19, 2008
    my 4 yr old goodmans tv picture turns green, it flicks back to normal for a couple of minutes, then everything goes back to green coloured picture, ive changed the scart leads no joy. Help??
    Scholar:
  • 173 Answers
Shorting or shorted green gun in CRT . The green driver transistor shorted or intermittent.
a simple voltage check would tell me witch one it is.
Posted on Sep 14, 2008
To discover the real solution as to why your turds are tapered, go
to this web address:
www.taperedturdsinc.com
Posted on Aug 31, 2010
3 Suggested Answers
snakehead
  • 1074 Answers
SOURCE: tv has bright green color
you are having a problem in your video circuit and your tunner section if the green is smooth also have the deflection ic checked.but this set needs to be taken to a qualified tech repairs could cost about $1oo.00 good luck.
Posted on Mar 21, 2007
bobjrdns
  • 84 Answers
SOURCE: green picture
a green screen on power up with retrace lines. At shut down a point appears in the middle of the screen. Sounds like either a shorted G2 grid, or bad flyback. If a phospher flake has shorted the grid in the tube, you can sometimes have luck by using a megger set at 1000VDC, to burn away the short. This is usually caused by the line HV going too high causing the anti-UV protection to kick in so fit a dummy load 40W lamp instead to the line output to allow measurements to be made.
Posted on Oct 19, 2008
Separated picture, one bright pink, the other bright lime green. The top and bottom of picture is distorted. The center of the picture is the best in all respects.
Please replace convergence output chips in tv to solve this issue, tv has two big black ICs at right side and number is STK392-110, replace both ICs to fix picture problem
Thanks.
Jan 25, 2011 | Hitachi 65SWX20B 65" Rear Projection...
Bright green picture
defective green picture tube crt. suggest local service center
Nov 09, 2009 | Toshiba 65HX83 65" Rear Projection...
My phillips model 60pp920217f has a horrible picture...no green to the color
The green CRT coolant has congealed thats whats giving you the green halos. Change the coolant in the green and blue and your set will be fine. red is never affected so the red coolant should be fine.
May 07, 2008 | Philips 43PP9202 43" Rear Projection...
Black/Green Distortion - Picture Quality - Wharfedale
This is no solution but a point in a probable direction.
A tech guy told me ALL the LCDs they have seen in their repair shop have "swollen" capacitors, this is due to voltage instability. Lowering the internal voltage regulator and replacing the swollen capacitors (which eliminate noise) apparently restores the LCD to new working quality. Without actually "seeing" my problem the tech said that should repair it. I have not tried this yet but eventually will begin that way.
Mar 11, 2008 | Televison & Video
Sony kp57hw40
Reset RGB screen controls....located behind lower front speaker
grill & access cover.....turn down ( CCW ) green screen slightly
and other two colors as needed.....T.
Mar 05, 2008 | Sony KP-57HW40 57" Rear Projection...
Picture has green tint on startup
Jar-Head, bad news, the picture tube has a mild short in the green cathode, tech can come out and try to restore it but it`s usually a futile attempt on sony tubes, sorry to be the bearer of bad news, BMW Rider
Jan 14, 2008 | Sony KV-32S26 32" TV
Tv has bright green color
Nov 16, 2006 | Samsung TXK2554 25" TV
Solid green screen
Is the green really bright with small white lines in the screen?? If it is its probably a shorted picture tube. That is if you still have sound. If you have no sound its probably a power supply problem in the sweep section of the set. This is not a repair for a consumer to do as its a solid state set and there are no user serviceable parts inside these sets. Get a service person to assit you with this repair. Good Luck
Jul 01, 2006 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Some part of TV has been fused causing no picture on screen , only bright green horizontal lines , not even video channel could be set ,cannot see menu on screen please help by specifying possible...
if the screen is real bright green with thin small white lines in it its probably a shorted picture tube. Or a shorted Green driver Transistor. Good Luck
Apr 12, 2006 | Thomson 14MG135 14" TV
Televison & Video Logo
364 people viewed this question
Top Televison & Video Experts
