Back to:
Tags:
Tascam 2488 Portastudio Multitrack Recorder System
Problem with the hdd. check the h/w (by 2 users)
posted by xumbrega on Jul 03, 2008
i havent used the tascam 2488 in a while but it was stored in a warm dry place . now it wont boot up . what do i do and will the memory be lost.
Same problem. Checked the cables, over and over again. Power is not the problem. It turns on, but fails to boot. I read somewhere that formatting the HDD may help. But what format (NTSF, FAT32, other?) should I use? Where can I get this info?
Thanks.
Comment by xumbrega, posted on Jul 08, 2008
Actually - I tried formatting with seagate's own OS - as suggested elsewhere in the web. To no avail. Cables, power, etc. are functioning.
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by clayton8180, posted on Aug 10, 2008
I am in the exact same situation. I got the 2488 out after properly storing it for a few months and received the same message. I never had any problems with it before.
Best Solution
posted on Aug 25, 2008
FixYa! (100)
tj49133
Rank:Apprentice Apprentice
Rating: 100%, 2 votes
my tascam truns on but tell me i have a TG initialize error and just hangs can u help
Comment by tj49133, posted on Aug 25, 2008
my tascam 2488 TellS me i have a TG initialize error AND JUST HANGS THERE ATA START UP CAN U HELP
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on problem with the hdd. check the h/w:
I don't want to Accept this solution
Solution #2
posted on Aug 02, 2008
Not Rated (0)
phathair1
Rating: 0%, 0 votes
I tried everything that I can think of also, so I am going to send it into the shop. I will post what they tell me.
BR
Thank You!
Can you Help with these Home Theater Systems problems?
Tascam 2488 Portastudio Multitrack Recorder...
I am very frustrated with this whole system. The manual...
I am looking for someone that I can pay ### per hour to...
Loading problems.
Repair Service
Find Home Theater Sys. Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
