Computers & Internet Logo
Posted on Dec 21, 2010
Why does my pc show ppp link error? - Samsung Modem Configuration Software (413115)
Anonymous
Level 1:
New Friend:
  • Contributor 3 Answers
  • Posted on Dec 21, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
97
Points
9
Ur net was not conected properly..
pls. disconect and reconect.
uninstall your modem and then install
3helpful
When i connect my samsung GT-S3653 with laptop for internet via samsung pc studio it showing error "os error PPP link protocal terminated, kindly provide the solution
If your using a DSL line, then the PPP settings should be adjusted...
PPP means point of protocal prresence used in DSL...
If you've converted over to CABLE or other means, then disable the PPP settings or Clear them out.
And have the system recommend a setting to start with when you reboot.
tip
How do you configure Multilink PPP on Cisco Routers
How do you configure Multilink PPP?
Given that the two sites that are connecting via Multilink PPP communicate with each other and coordinate the configuration, configuring Multilink PPP is easy. Here is a sample configuration of 3E1 circuits being bonded to form a single 6Mb Internet circuit:
controller E1 4/0
framing NO-CRC4
channel-group 1 timeslots 1-31
description Connect to OtherSite#1
controller E1 4/1
framing NO-CRC4
description Connect to OtherSite#2
controller E1 4/2
framing NO-CRC4
description Connect to OtherSite#3
interface Multilink1
ip address 1.1.1.1 255.255.255.252
no cdp enable
ppp multilink
ppp multilink group 1
interface Serial4/0:1
no ip address
encapsulation ppp
no fair-queue
ppp multilink
interface Serial4/1:1
no ip address
encapsulation ppp
no fair-queue
ppp multilink
interface Serial4/2:1
no ip address
encapsulation ppp
no fair-queue
ppp multilink
This configuration is from a Cisco 7200 router that has Qty 1 Controllers E1 interfaces (plugged into module 4). These E1 controllers create the Serial4/0:1, Serial4/1:1, Serial4/2:1 interfaces that are bound to the multilink group #1, and other serial interfaces (Serial4/3:1, Serial4/4:1 and so on...)
It is the multilink1 interface that is actually the single combined interface that really has the “6Mb” of bandwidth, and that is where you would apply all of your “normal interface configuration” for this 6Mb connection that connects to the Internet. You can see how the multilink 1 interface has an interface number that matches the ppp multilink group. On that multilink 1 interface, you have the IP address for this link, an ACL on the interface, firewall, NAT, or other router interface commands.
By using the multilink interface, you are able to bond all three of these E1 interfaces into a single router interface — very cool!
To verify that your multilink interfaces are up and running, you can use the show ppp multilink command, like this:
Router# show ppp multilink
Multilink1, bundle name is OtherSite
Bundle up for 3w4d, 89/255 load
Receive buffer limit 85344 bytes, frag timeout 1000 ms
10518/6985 fragments/bytes in reassembly list
21651 lost fragments, 3287247349 reordered
17098/8879018 discarded fragments/bytes, 18 lost received
0xA990C7 received sequence, 0x7F6AA8 sent sequence
Member links: 3 active, 0 inactive (max not set, min not set)
Se4/0:1, since 3w4d
Se4/1:1, since 3w4d
Se4/2:1, since 3w4d
Router#
The key to configuring Multilink PPP is the multilink interface, the ppp multilink protocol on each router, and the ppp multilink group x command on each interface. Multilink PPP isn’t a difficult router configuration to set up, and it is extremely valuable when you need multiple circuits bonded into a single circuit from a single provider.
And for sure, you can just add multilink interface to be routed using OSPF, PBR or any other routing protocol.
on Jan 12, 2010 • Computers & Internet
2helpful
3answers
Sir when connect tata photon plus then show on error 734 PPP link is terminated
sir ,
i use the tata photon plus but when i cnnecting it shows error 734 the protocol link was termineted
1helpful
I have the samsung pc studio3 but it is not able to show the S3500 as connected.
I have got Sumsung S3500 phone with Vodafone Connection. I'm able to use net in the mobile using GPRS but when I tried to connect to internet from my PC (OS is Windows XP) through PC suite it gives me Msg "OS Error Message. The PPP Link Control protocal was terminated" and i am not able to connect to the internet. Firends help me to resolve this. My email address is [email protected]
I was having error while connecting my samsung L700 to pc for dial up connection. i was connecting to pc with Airtel Mobile Office and my operating system is windows xp.the error which i was getting is...
FIRST U ASK IN CUSTOMER CARE FOR ID OF YOUR MOBILE FOR INTERNET CONNECTION.AND NOTE THE CODE FOR INTERNET CONNECTION .THEN INSTAL PC STUDIO IN YOUR PC AND THEN INSTALL NETWORK WIZARD AND THEN YOU CAN RUN INTERNET ON YOUR PC THROUGH MOBILE
Ppp link error occure when i connect my phone to internet in pc. piz tell me the solution for this prob.....
its a dialing problem , these errors occur when there is some connecting problem at the network providers side . contact your service provider for correct settings or dialing rules.
20helpful
3answers
Error 734 ..ppp protocol terminated in .Aircel pocket internet
dear Sir,
I have the mobile handset samsung GM S 3310. I am usuing Aircel Pocket internet in this phone. Surfing net is not a problem from the handset , but unable to connect it to my laptop.
Before dial up, it gives :error 734 ..ppp links protocol terminated. Therefore I Can not connect pc to handset as the dial up connection is not established.
7helpful
9answers
Problems on games in samsung e250
To Install Java Games On Your Samsung-E250,You Have To Download "Softick" PPP and A "Java game Uploader"(search it on Google)..........
lnstall java games using usb data cable
SAMSUNG E250
Install\Run SoftickPPP221 from the Softick.PPP.v2.21 Folder. Ignore any errors about usbsync.dll by pressing OK.
Leave the option use usb in shared mode checked.
Run when finished installing. You will get an error message about being unable to locate usbport.dll, just click cancel.
Plug in your usb cable and turn phone on.
Right click on softickppp running in your taskbar and select settings.
In the usb tab uncheck accept ppp connection on usb and tick both use usb in exclusive mode and overide usb compatability,
Click on ok and completely exit softickppp by right clicking then exit.
Run softickppp and again goto settings. On the bluetooth\serial tab tick the correct com port.Mine is com3. Then click ok
On your phone key in *#52828378# press 2 ota type setting and select serial bearer ota.
Run samsung java uploader and add your jad file
On your phone select 3 serial test , 1 ppp up , 2 usb
Your phone will now reboot. While its rebooting right cklick on softickkppp in your taskbar and choose shutdown ppp
When your phone has rebooted again key in *#52828378#
Right click softickk ppp and activate ppp
On your phones java test menu press 3 serial test , 1 ppp up , 2 usb , 2 serial download
Your game should install and start running.
PPP
The P300 supports PPP PAP Authentication, PPP CHAP Authentication, PPP MS-Chap Authentication, and PPP Password encryption - MD5, but it does not support PPP data stream encryption.
Top Samsung Computers & Internet Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Jean Thiebaux
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
