If you have a tubular tire (also called a sew-up), and you know that you have full-size wheels (either 700c or 27 inch), you need a 700c tubular. Tubular tires only come in a few sizes and the most common is the 700c. A tubular tire is a unique type of tire that usually has a tube sewn inside. This gives the tubular a round cross section and means that it must be glued onto the rim.
700c and 27 inch are actually different sizes (27 inch is slightly larger diameter than 700c), but they're often confused because they're so close and they're both found on road bikes - or have been over the years. These days, the common road-bike wheel and tire size is 700c. But, people still sometimes mistakenly refer to it as 27 inch, which was popular 25 to 30 years ago.
So, the bottom line is, if you get a tubular called a "27 inch" or "700c," it will be the same size and it will fit your wheel just fine. The size that you don't want is "650c." That size will be too small for your wheels. If you have something besides a tubular tire (if your tires aren't glued onto the rims, you don't have tubulars), to determine the size simply look carefully at the sidewalls. You'll find the tire size marked there if you look closely.
Fitment for 1999 XL Tubeless Cast Wheels:
Wheel Position and size = 19 inch Front; Rim Size and Contour = T19x 2.15 MT; Rim Valve Hole Diameter = 0.45 inch; Tire Size = Dunlop D401 ELITE S/T 100/90-19
Wheel Position and size = 16 inch Rear; Rim Size and Contour = T16 x 3.00 D; Rim Valve Hole Diameter = 0.35 inch Tire Size = Dunlop D401 ELITE S/T 130/90-16
Wheel Position and size = 19 Inch Front; Rim Size and Contour = T19x2.50 TLA; Rim Valve Hole Diameter = 0.45 inch Tire Size = Dunlop K591 S&FR Elite SP 100/90-V19
Wheel Position and size = 16 Inch Rear; Rim Size and Contour = T16x3.00 D; Rim Valve Hole Diameter = 0.45 inch Tire Size = Dunlop K591 S&FR Elite SP 130/90-V16
Tire Fitment for 1999 XL Tube Laced Wheels:
Wheel Position and size = 19 Inch Front; Rim Size and Contour = T19x2.50 TLA; Tube Size = MJ90-19 Tire Size = Dunlop D401 ELITE S/T 100/90-19
Wheel Position and size = 16 Inch Rear; Rim Size and Contour = T16 x 3.00 D ; Tube Size = MT90-16; Tire Size = Dunlop D401 ELITE S/T 130/90-16
Wheel Position and size = 21 Inch Front; Rim Size and Contour = T21x215 TLA; Tube Size = 3.00 x 21; Tire Size = Dunlop Touring ELITE II MH90 - 21 56H
Wheel Position and size = 16 inch Rear; Rim Size and Contour = T16x 3.00 D; Tube Size = MT90-16; Tire Size = Dunlop Touring ELITE II MT90 - B16
Tire Pressure - All Models:
Cold up to 300 Lb. Load (includes rider, passenger and cargo)
Front = 30 psi (2.1 bar)
Rear = 36 psi (2.5 bar)
Up to GVWR maximum load
Rear = 40 psi (2.8 bar)
