Question about Danby DCD5505W Electric Dryer
Replacing bryer belt
I am trying to replace my belt for my dryer how do I replace the belt on my danby dcd5505w dryer
  • cgaston53 Nov 16, 2008
    I replaced one myself a couple of years ago and now it has broken. It's fairly tedious. You have to take off the top and back as i recall, and the toughest part is threading the belt through the drive mechanism on the bottom underneath the big drum. This will be the last time I replace one of these belts. If it breaks again it becomes property of the Salvation Army.
    Genius:
  • 3,422 Answers
Please CLICK HERE this will fix your problem.All the instructions are given step by step with the diagrams.
Posted on Jul 03, 2008
  • Priya darshan Jul 03, 2008
    @Ekse saw your sol. only after posting mine...
  • 13,433 Answers
Read here
http://repair2000.com/wpoolbelt.htm
this may be helpful me know if you need anything else.
Thanks,
Ekse
How do you take apart a Danby Designer dryer to replace the belt?
INSTRUCTIONS TO CHANGE DRYER BELT DCD5505W-1, REMOVE THE SCREWS ACROSS THE BOTTOM OF THE FRONT THAT GO FROM BOTTOM UP
REMOVE THE TOP BY REMOVING THE 2 SCREWS HOLDING IT DOWN FROM BEHIND, PULL BACK AND LIFT OFF. REMOVE THE 2 SCREWS ON EACH SIDE THAT GO FROM INSIDE FORWARD THAT HOLD THE PLASTIC FRONT ON AND REMOVE THE PLASTIC FRONT REMOVE THE FRONT SCREW FROM THE CENTER BRACE BAR RUNNING FRONT TO BACK ACROSS THE TOP
REMOVE THE 2 SCREWS ON EACH SIDE AT THE TOP THAT WERE REVEALED WHEN THE PLASTIC FRONT WAS REMOVED REMOVE THE 6 SCREWS AROUND THE FACE JUST INSIDE THE DOOR THEN SWING THE FRONT OUT RIGHT TO LEFT REMOVE THE 2 SCREWS ON EACH SIDE OF THE INNER BULKHEAD PANEL AND REMOVE THE PANEL AT THIS POINT YOU CAN REPLACE THE BELT,
IDLER, AND MOTOR MOUNTS THE 1 EXTRA STEP THE REPLACING THE MOTOR IS TO REMOVE THE BACK AND THE BLOWER COVER THEN UNTHREAD THE BLOWER WHEEL FROM THE MOTOR SHAFT.
May 11, 2010 | Danby DCD5505W Electric Dryer
Here are the Danby instructions: First Make Sure that Dryer is Unplugged from outlet.
THE FRONT THAT GO FROM BOTTOM UP. REMOVE THE TOP BY REMOVING THE 2 SCREWS HOLDING IT DOWN FROM BEHIND, PULL BACK AND LIFT OFF. REMOVE THE 2 SCREWS ON EACH SIDE THAT GO FROM INSIDE FORWARD THAT HOLD THE PLASTIC FRONT ON AND REMOVE THE PLASTIC FRONT. REMOVE THE FRONT SCREW FROM THE CENTER
BRACE BAR RUNNING FRONT TO BACK ACROSS THE TOP. REMOVE THE 2 SCREWS ON EACH SIDE AT THE
TOP THAT WERE REVEALED WHEN THE PLASTIC FRONT WAS REMOVED. REMOVE THE 6 SCREWS AROUND THE FACE JUST INSIDE THE DOOR THEN SWING THE FRONT OUT RIGHT TO LEFT. REMOVE THE 2 SCREWS ON EACH SIDE OF THE
INNER BULKHEAD PANEL AND REMOVE THE PANEL. AT THIS POINT YOU CAN REPLACE THE BELT, IDLER, AND
MOTOR MOUNTS. THE 1 EXTRA STEP THE REPLACING THE MOTOR IS TO REMOVE THE BACK AND THE BLOWER COVER THEN UNTHREAD THE BLOWER WHEEL FROM THE MOTOR SHAFT.
Mar 19, 2010 | Danby DCD5505W Electric Dryer
Searching for a Danby Dryer belt
appliance parts pros 1-877-477-7278
Oct 31, 2009 | Danby DCD5505W Electric Dryer
How replace belt danby electric dryer dcd5505w
Remove the retaining screws off from the front panel. Remove the two wires connected to the door switch(the wires can go back on either way).Pull the front panel away from the drum. Look down to the bottom right corner facing the front of the unit and locate the tensioner and drive pulleys. If the old belt is still intact(which is usually not the case) remember the routing order of the belt. Slide the new belt onto the drum keeping in mind which side goes to the drum. The ribbed side should face outward.Next you want to curl the belt over the tensioner(providing the tensioner is still in it's slot) and then over the drive pulley. Replace the front panel and the door switch wires. You're good to go. Thank you, Dana
Oct 06, 2009 | Danby DCD5505W Electric Dryer
Dryer runs but wont tumble
Try checking to see if the dryer belt is broken, the dryer belt wraps around the drum and goes to a motor at the bottom of the dryer that turns the drum, if so you can usually get a replacement belt from the maker of your dryer by visiting there website.
Mar 11, 2009 | Danby DCD5505W Electric Dryer
Dryer belt PH 1930 for danby model dcd5505w-1
Call Danby Customer Service at 1-800-263-2629; The part costs $25 or so plus another $7 shipping. Better than getting it through a distributor, I was given a price of $40 through a local place.
Oct 30, 2008 | Danby DCD5505W Electric Dryer
Part Number DB-6060532 available at marcone.com
Mar 18, 2008 | Danby DCD5505W Electric Dryer
Hello....
I needed to replace my belt. I called the Danby Customer Service number 1-800-263-2629. I called early in the morning and got straight through. I received wonderful, prompt friendly service.
The belt cost $25.19 plus postage and handling.
Joe
Jan 16, 2008 | Danby DCD5505W Electric Dryer
Door Handle Broken
yes contact your local appliance dealer or if you have the manuals that came with this dryer contact the manufactuer by the listing on thier literature.
Or do a web seach LIke :DANBY DCD5505W DRYER PARTS
Jan 15, 2008 | Danby DCD5505W Electric Dryer
Danby DCD5505W Electric Dryer Logo
420 people viewed this question
Top Danby Dryers Experts
Tim Whalen
SHARCNET-USA
SHARCNET-USA
Are you a Danby Dryer Expert? Answer questions, earn points and help others
