I purchased an acer aspire 5920 notebook a few months back my wife said that the sound just stopped working a few days ago. I have checked through the control panel device manager and both are functioning ok. Its hard to watch a movie or listen to music with no sound!!!, a solution would be gratefully received
    President:
  • 1,314 Answers
Can you hear sound through the headphone port? If so then it's possible the speaker wire came loose on the inside. If not, then it's most likely a motherboard problem and you should contact ACER for warranty service.
Posted on Jul 03, 2008
Good Morning: I have an Acer Aspire 5920
As by your description, the FN F7 key combo did not solve the problem. Please restart the machine , press F8 then select from the list "Safe mode" then press enter. Then see how the Touch pad reacts in Safe mode. If it works perfectly in safe mode, we can assume you have a software problem that is preventing it from working in normal windows mode.
Please download and install the latest BIOS for your machine. The E525 has a issue where the TP just stops working, upgrading the BIOS solves the issue on the E525...
Acer Aspire 5920 3813 BIOS
Please install one of these drivers for the desired Operating system...
Acer Synaptics Device Driver Windows XP
Acer Synaptics Device Driver Windows Vista
Acer Synaptics Device Driver Windows 7
May 13, 2010 | Acer Computers & Internet
Acer 5920 wont turn on, we bought an extended
This is a common problem with Acers but usually it is the battery and the adapter. Replace the battery as well as the adapter and you shouldn't have any issues. Surges can be the main cause for this or running the laptop hot has also been the culprit.
Apr 02, 2010 | Acer Aspire 5920-6727 Notebook
My acer aspire 5920 is completley dead it will not turn on with a fully charged battery which was charged up using a second 5920, it will not turn on with a working power supply either. I have completly...
Might your switch be non-functioning? Can you check that independently?
Otherwise, sounds to me like you did eveything.
Same thing happened to me with my dog once. I let him out and that was it! :-)
Oct 09, 2009 | Acer Aspire 5920-6727 Notebook
I have acer aspire 5920 vista when i shut down laptop i pressed acer arcade button then it started up and shut down again now it will not start up !all im gettin is restore settings .they dont work to...
tell me, are you able to get to the menu when you computer starts up (F8 options )
if so just go for the option last knowing good configuration.
it will start up as normal. if it does try to do a system restore from a few days ago.. restart again and it will work .
in case the F8 menu does not show up.try removing the battery for at least 3 days so the CMOS resets to default.
hope it works
Oct 07, 2009 | Acer Aspire 5920-6727 Notebook
Hi i recently bought a 5920 acer laptop ,i used it for couple months ,while using it one day i pluged in the charger and left the room for couple minutes only to dicover it was not on anymore since then...
sounds like power pack. Look for your warranty papers. Or, call ACER in your country and arrange repair (might also be the laptop itself). They can arrange pick up and repair under warranty.
Aug 04, 2009 | Acer Aspire 5920 AS5920 Notebook
Screen jumping on acer aspire 5920
First boot in safe mode and the display resolution will be minimal if the screen appears ok with big fonts then try and adjust the normal resolution but not high resolution like 640x480 with 256 colors, if it works then you acer laptop screeen is fine but the exactly display drivers to be reloaded else there is a problem with your laptop screen which needs to be replaced
Mar 18, 2009 | Acer Aspire 5920 AS5920 Notebook
Computers & Internet Logo
59 people viewed this question
David Payne
David Payne
