Question about Audiovox PPC 6700
Ppc 6670 i got the ppc6700 and the screen is cracked at the top right corner and i cant get passed the align screen part. Do i have to get a new screen if so how to i put it together?
  • 4 Answers
You just need the touch screen (digitizer). There are actually 2 pieces that are mistaken to be the screen. The other piece is the touch screen and beneath that is the LCD display. Be certain to order the correct piece.
To replace, you need a micro phillips head screw driver and a T-6 torx screw driver. Also patience, and a steady hand.
You must start at the back of the device, through the battery door. Remove the 2 micro phillips at the top of the battery opening (one is covered with a tamper evidence sticker). Then carefully, starting at the bottom of the camera plate, pry upwards and to the speaker to unsnap the smaller facing. Remove the camera by gentally pulling up to unplug, then unscrew the circuitry and remove. This will expose the 4 torxs (2 in batt opening) to remove the back cover. After screws are removed, gentally work the covers snaps loose around perimeter and remove (pay attention to the speaker wire) unplug it from the circuitboard. Pull the antenna nub to detach.
Remove the screws holding the circuitboard, unpluging the keyboard and slider ribbon cable. Gentally hold the ribbon cable and remove the securing tape. (dont pull too hard!) Pulling the circuitboard exposes the 4 micro phillips screws (2 each side) to detach the slider.
Remove the 4 torx screws on the back of the LCD slider, then gentally pry around to separate the housing.
To remove the LCD / Touch screen you must unplug the ribbon cables. To do this you need to open the connector's trap (black bar). It hinges. Just pry upwards from the ribbon side. Once bar is lifted ribbon will slide out. Be careful if you need to remove the gold foil tape. Remove the single screw holding the ear speaker, and the ribbon should come out. The screen will not come out after gentally prying it free of the holding snaps in the casing.
Installation is simply the reserve. Hope this helps....
Posted on Oct 03, 2008
Tablet touch screen is only cracked on the top right corner. What can i use to get the screen to respond to touch on the lower half of the screen?
You may have only cracked the top corner , but if the lower part of the screen is not responding then you have also damaged your digitizer. A replacement of the screen and the digitizer may be necessary.
Feb 06, 2016 | Tablets & eReaders
There are cracks from the bottom right corner of the screen right up to the top left and when i turn it on the light still works but i cant see anything
Your laptop was dropped and the LCD backlight is what is lighting your screen. You need a replacement LCD screen.
Nov 28, 2009 | Dell Inspiron 1525 Notebook
I want to do a hard reset on a ppc6700. I have tried the way shown in the user guide, and that doesn't work
Just to clarify, you ARE holding down both soft keys (left and right menu keys with dashes on them) and pressing the reset button?
If so, and it appears to only perform a soft reset, there should be a "clear storage" option in PROGRAMS. It will prompt confirming your selection (just go through the prompts). This is an equivalent to a hard reset.
I hope this helps,
Sep 11, 2009 | Audiovox PPC 6700
Cant send or receieve MMS
immeditly u8pdte your softwere.and also check for your mms settings given by your provider
Aug 24, 2009 | Nokia N96 Cell Phone
Bought 6700 on ebay
Firstly, here's the USB driver for your 6700:
Install that, for starters..
Here's a .pdf for instructions for software upgrade for the ppc-6700.
or maybe you want to shell out the dollars and get the big Microsoft upgrade package, with all the frills:
Hope this helps :)
Season's Greetings!
Chris (ziraffa)
Dec 24, 2008 | Audiovox PPC 6700
Audiovox PPC6700 Blank White Screen Plugged In, Black Unplugged
One thing you can do if you have backup all your info is hard reset the phone. If you do not know how to do so please contact me and i will give you instructions.
Mar 18, 2008 | Audiovox PPC 6700
Hitachi 50ux26b/27k with AP63 chassie convergence problem
It looks like the STK chips need to be replace for fix the distorted colors.
You can download the service manual from here:
Feb 05, 2008 | Hitachi 53UWX10B 53" Rear Projection...
Audiovox PPC 6700
You just gotta really hit it dead in the center, took me a couple of tries but you just really got to hit it dead on
Dec 25, 2007 | Audiovox PPC 6700
Audiovox PPC 6700 Logo
160 people viewed this question
Top Audiovox Computers & Internet Experts
Mohammad Abumuailek
Mohammad Abumuailek
Greg Cann
Greg Cann
Martin Murray
Are you an Audiovox Computer and Internet Expert? Answer questions, earn points and help others
