Question about Magic Chef MCWC30MCG Compact Wine Cooler
Change light in wine cooler
There is a plastic lens on roof of wine cooler that i can't seem to remove to replace light bulb.  Any suggestions other than a hammer?  thanks.
Took everything out and got on my back with flashlight to find a tiny screw holding lens in place.  Found that a little night light fit and worked fine.  Wish the manual had a simple direction to fix the problem.
Posted on Jul 06, 2008
Can't figure out how to change the light bulb in my Wine Cooler? Can't get the plastic cover off? help!
Hello there,
How many techies does it take to change a light bulb (without a hammer)?
There is a tiny screw holding the lens cover in place. Once removed, the lens will come off and you can access the bulb.
Hope this helped
Thanks for using FixYa
Jul 24, 2008 | Magic Chef MCWC30MCG Compact Wine Cooler
Where do I get the replacement bulb for a EWWC30MCG wine cooler? Can I order it from your web site?
If its one of the bulbs that looks like a small glass tube that has metal on both ends good luck! I tried to find a bulb for my cooler and you have to 100 of them , they won't sell just one.
Jul 21, 2014 | Furniture
Edgestar wine cooler blowing fuse on the left side circuit board
If you have replaced the circuit boards it's probably associated with a wiring short circuit or compressor failure. Suggest you get a professional technician to further investigate the fault. In the interim check for a short to the frame of the unit, an internal light or for moisture issues or a condensation issue from water.
Mar 25, 2014 | EdgeStar ES TWR325ESS-32 Bottle Dual Zone...
Can't remove cover to change bulb.
Never seen one like it, would help to know if lens is plastic or glass. If plastic would suggest you grip both hands on lens and see if you can compress lens and disconnect end cap(s). If glass, can\'t compress lens and would assume that end caps have to be removed, may be friction fit or have protrusion that has to be overcome. Tough one if not in my hands and never seen one. Good luck, JW
Mar 04, 2013 | Home
How do you change the light bulb in the e wave wine cooler?
I took the screw out but the lens won't budge and I don't want to break it. how does the lens come out?
Oct 07, 2012 | Magic Chef MCWC30MCG Compact Wine Cooler
Danby wine cooler model dwc172bl thermostat replacement
Once I figured out there were black plastic caps covering the screws holding the inside back panel in place, it was an easy fix. The cooler is now up and running. Thank you for giving me the $10 incentive to figure it out myself.
Jan 18, 2009 | Danby Silhouette DWC512BL Wine Cooler
Short maybe?
check voltage on outlet is grounded properly try another outlet
Nov 03, 2008 | Haier BC112G Wine Cooler
Haier Wine Cooler
Hi LinnieMcAdam,
I'm Harvey the Master Plumber.
Your question is: Where can you find a 10 Watt replacement light bulb for your Haier Wine Cooler?
I usually have success at the hardware store. Start there. Then you can try the store where you bought it or call Haier.
Feel free contact me again!
Please give me a rating here at before you sign off
Thank you,
Harvey your Master Plumber
Sep 13, 2008 | Refrigerators
Marvel Cooler/Fridge Light Not Working
It sounds like the bulb is not getting power. There is a door switch that turns it off when the door closes...this may be stuck. There is usually an optional (depending on age) ON/OFF switch that overrides the light to be on full time. If the light will also not turn on with that switch then there must be a disconnected or broken wire either going to the light switches or going to the light socket from the switches. I hope this helps.
Aug 30, 2008 | Marvel (6SBARBSG) Wine Cooler
Magic Chef MCWC30MCG Compact Wine Cooler Logo
520 people viewed this question
Top Magic Chef Furniture Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Magic Chef Furniture Expert? Answer questions, earn points and help others
