Question about Konica Minolta DiALTA CF910 Copier
EP 5000 copie very light
I have an EP5000 and he give me copie very light even if I replace starter
  • 145 Answers
Did you run F-8 ? and make sure T/S and CHARGE are clean optic .
? is it happening when you manual darken density
''check your drum,and drum count
hope that helps
Posted on Oct 25, 2008
Minolta EP 4000 always shows please wait after you photocopy two papers until you reboot it. and after rebooting it will still repeat thesame thing, how can i fix it please
Check fuser assembly, make sure the heater element is ok, if not replace. The thermal cut out shoul properly checked to ensure its normal characteristics.
May 30, 2016 | Konica Minolta Minolta Ep4000/ep5000...
C0f30 error minolta photo copy
When was the last time the developer was replaced in the developer unit? If it has been replaced then you might have a bad ATDC (Automatic Toner Density Control) sensor Located right below the developer unit. If the developer was replaced when it was done was a vacuum cleaner used? IF so the static electricity from the vacuum clear destroyed the sensor, NEVER USE a VACUUM cleaner to remove the developer. Also when the developer was replaced, was counter cleared to tell the copier developer was replaced, the copier use the counters to determine certain voltages for certain assemblies, if not image problems and codes can appear. Finally was the F8 run after the developer was installed before any prints or copies made? If not buy new developer and start over, counter is to be cleared first, then developer replaced, then F8 run.
Sep 29, 2014 | Konica Minolta Minolta Ep4000/ep5000...
Stabilizing image controller not ran
Stabilizing Image control sounds like a Color copier not a analog b/w copier which the EP 5000/4000 is. What is the model of the machine?
Sep 11, 2014 | Konica Minolta Minolta Ep4000/ep5000...
Error codeC06F1
there is a C-06FX but no C-06F1
Mar 06, 2014 | Konica Minolta Minolta Ep4000/ep5000...
Photocopieur
C - 0100 Charge corona wire winding failure.
C - 0200 PC drum charge,Image transfer/paper separator coronas failure.
Clean the coronas wire and the coronas house using isoprophil alcohol and clean or change the contact combs(a little Cu pieces)
If you enter in service mode and select Counter mode you can reas the trouble code list description.
Apr 26, 2013 | Konica Minolta Minolta Ep4000/ep5000...
MINOLTA CODE PANNE C 0 D 50
Duplex unit problem,pull out /push in the duplex unit.Open close the front cover.
Jan 15, 2013 | Konica Minolta Minolta Ep4000/ep5000...
Can the batteries be replaced on my remington ep-5000
You can have the battery replaced This needs to be done by an Authorized Service Dealer. To find your nearest dealer in the USA, use the online search function here:
http://www.remingtonproducts.com/ConsumerService/AuthorizedServiceDealers.aspx
If you are in another country, go to the top right of the screen, mouse over the Country and select your country. Look for a tab for the Authorized Service Dealer search function.
Sorry someone has not responded sooner.
Oct 11, 2010 | Remington EP5000 Epilator
Konica Minolta DiALTA CF910 Copier Logo
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
