Question about Xerox WorkCentre PE16 All-In-One Laser Printer
Xerox WC Pe16 ask for solution for Internal error false... line 226
Hi, this is the error, position value may change every time, but line 226 is always the same.
Please help me
internalerror-false
position:0x33cb(13259)
system:h6fw/xl_pa
line:266
version:qpdl 1.22 12-022003
  • Anonymous Sep 19, 2008
    position
  • alanaplin Nov 07, 2008
    I have same problem as the line 495 message
INTERNAL ERROR - FALSE
POSITION: 0x4364c (276044)
SYSTEM: H6FW/xl_image
LINE: 495
VERSION: QPDL 1.40 11-14-2005
Posted on Jun 10, 2011
HELP::>:>:>
POSITION : 0X9FCA3 (654499)
SYSTEM : H6FW / XL_IMAGE
LINE : 495
VESION : QPDL 1.40 11-14-2005
Posted on Sep 02, 2008
Two differents internal error
The cable could be Faulty replace it with a new or known to be working fine .
Jun 25, 2015 | Samsung SCX 4200 All-In-One Laser Printer
How to install Xerox WorkCentre PE16 scaner? i ...
How to install Xerox workcentre PE16 scaner?i install twin & driver but not work . Please help...
May 20, 2010 | Xerox WorkCentre PE16 All-In-One Laser...
Windows vista cannot connect to xerox workcenter pe16 networking printer, error not enough memory
not surprised..vista is a nasty program. not enought memory refers to vista not your PE16
try downloading from xerox website..website is useless but try
Nov 17, 2009 | Xerox WorkCentre PE16 All-In-One Laser...
Put a brand new maintenance kit in Xerox Phaser 8560 and it died
This is from the service manual. The lobes on the camshaft that rotates the maint kit up are know to crack. If they have rotated on the shaft this could cause your problem.
If you remove both sides and home everything it will come ready as long as nothing is broke
Harry
The 7,007.49, 7,008.41, 7009.42, and 7,010.43 errors indicate that the
Printhead was unable to tilt normally on its axis. Possible causes include:
??  The printer was powered off in the middle of a cleaning cycle and the
Wiper Blade has frozen to the Printhead.
??  A Drum Maintenance Camshaft lobe is broken and holding the Drum
Maintenance Kit’s oil roller against the Drum when it should be retracted
to its home position.
??  Process Drive not being aligned correctly.
??  A damaged Printhead Restraint.
??  Ink spilled in the Roll Block preventing proper Printhead motion.
??  Ink or other debris under the Printhead preventing proper motion.
??  The Wiper Assembly not being aligned correctly or ink spilled in the wiper
tracks.
??  The Head Tilt Gear not being homed correctly.
??  The X-Axis Motor nose cone not being installed correctly.
??  The ferrite torrid on the Printhead interface cable has slipped behind the
Printhead causing the Printhead to bind when it tilts backwards.
??  The black plastic shroud on the back of the Printhead is snapped off and
binding the Printhead when it tilts back.
Caution
After servicing the printer, manually set the following assemblies to their
home position before powering on the printer. See Section 6 for
instructions on setting these components to their home positions.
??  Printhead (tilted forward and disengaged from Printhead tilt gear)
??  Head Tilt Gear (disengaged from Process Drive train; arrows on left
frame point to each other)
??  Wiper Assembly (bottom of travel)
??  Process Drive (holes on Transfix Camshaft and Drum Maintenance
Camshaft line up with marks on frame, large gears within assembly
line up with holes in Process Drive housing)
Oct 21, 2009 | Xerox Phaser 8560DN Laser Printer
Ow to change resolution in xerox workcenter pe16 scanner
resolution for impression or copie if impression enter from propriété printer if copie you choose it from screen
May 28, 2009 | Xerox WorkCentre PE16 All-In-One Laser...
Xerox Phaser 8560 - error code: 07,010.43:205458
This is from the service manual. If you remove both sides and home everything it should come ready.
Harry
tracks.
Caution
Apr 21, 2009 | Xerox WorkCentre C2424DN All-In-One Laser...
Xerox P16 error
What I would do is go through the Menu program and delete ALL of the memory programs complete look for system data then scroll through the memory and delete all the Memory this is where i would start first, By the way "Samsung" made this product for Xerox so this is technically a Samsung Product.
Jul 04, 2008 | Xerox WorkCentre PE16 All-In-One Laser...
Xerox PE16 Workcenter
if you print from a printer do you get the blank like?
if Yes, then you may have some dead LED's on the scanner (this will need replacement)
if No, then look at your scanner (small thin glass strip that reads the paper when being copied) and clean it. 9 times out of 10 there is some white-out or toner stuck to it, clean it and that should fix that.
hope this helps with the white line
thanks for rating
Jan 13, 2008 | Xerox WorkCentre PE16 All-In-One Laser...
Internal error
We received a similar problem on ours:
Internal Error - False
Position: 0x268f3b (2527035)
System: H6FW/xl_image
Line: 476
Version: QPDL 1.22 12-02-2003
We would also like to know exactly how to fix this problem as it doesn't seem to work at all now!
Dec 28, 2007 | Samsung SCX-4100 All-In-One Laser Printer
Xerox WorkCentre PE16 All-In-One Laser Printer Logo
1,498 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
