Tv turns on (red light illuminates) then clicks off by itself. Have to unplug and plug in to make it do the same thing over else nothing from the power button.
  • svadhav Jul 03, 2008
    power light turns on for a few seconds, then switches to steady blink. nothing comes on tv.
    panasonic hdtv pt-47wx42F nov 2002 mfg date
    President:
  • 357 Answers
Hi there
This is what the power supply should look like if you were to take it out of the television:
This is what the electrolytic capacitors should look like:
Thank you for using FixYa. Have a nice day and please remember to rate our earlier conversation as FixYa!
Kind regards
Dustin Ellse (BearWeb)
Posted on Jul 03, 2008
Hello, I have a Samsung LN52B630 TV that quit working...noticeably after a confirmed lightning strike nearby.
Screen coming on when the main plug is removed is normal, that happens on most TV's...Are the spots that have no volts supposed to have voltage? there is a legend on the board to tell what voltages belong no what pin, check that
Oct 28, 2017 | Samsung Televison & Video
My panasonic th-50px60u television turned itself off last night and won't turn on makes clicking noise when unplugged and plugged back in but then nothing red light flashes
Tries tv unplug,replug it back like about an hour later for the tv to do it resetting itself back to the factory setting,tv might work again.If not still same problems.The tv 90-95% it is the board that call the tv power supply board is having a problems.That the board where the tv power a/c cord plug into it.U have all tools and know basic electronic and also can do basic soldering works too?Yes,take the tv aparts,check the tv power supply board carefully for dying and soon to be dead capacitors components parts.These capacitors components parts are alway bulges up or puffing up onto it tops.These dying and soon to be dead capacitors components parts are bulges or puffing ups on to it tops must have to be replaced will solved ur tv power unstable and flashing red light.Or try website like Ebay.com to buy a whole new refurbish tv power supply board for the replacement.
Jul 29, 2011 | Panasonic TH-50PX60U 50 in. Plasma HDTV
50" philips won't power on. get the 4x red blink led light
i have fixed 3 of this tv, with that exact problem in the last 2 weeks, needs a power supply, you can try to unplug it again, plug it in, hit the power button, as soon as it turns green, unplug it again, after 15 seconds , plug it back in, if power doesnt turn on by itself, turn it on, if it turns red again, emediatily hit power again, may have to hit power a few times in a row, but most of the time you can get it to come on this way, once it is on, it should run ok, until you turn it back off, but not a fix, needs power board
Jan 10, 2009 | Philips 50PF9631D 50 in. HD-Ready Plasma...
AKAI LCT3201AD
Find and replace the following caps, Ec18, 19, 20 / 1000uf/16v,
Ec9, 10 / 1000uf/35v, Ec14, 25 / 470uf/35v should resolve the problem. You can get the caps at almost any electronics supply.
This is a common problem in this unit.
Good Luck!
Happy Thanksgiving!
Bill
William Rayburn, CET
Premium Technologies
PO Box 442
Long Beach, WA. 98631
360-642-4993
premtech@willapabay.org
Nov 27, 2008 | Akai LCT2715 27 in. LCD Television
AKAI 32" LCD HDTV WILL NOT TURN ON
The only solution at this point would be to get the power supply repair since new boards are not longer being manufactured. In about 95% of the time if the LCD doesn't power up or turns OFF by itself or need to be unplug for some time to make work again; those are the symptoms of a dying or defective power supply.
I service these power supplies, for more info write to jah2mil@hotmail.com
Nov 27, 2008 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Insignia 42 inch TV won't turn on
The power supply is in the protect mode. There are many things in the set that can cuase this. Most likely there is a short on one of the circuit boards, or the power supply itself has failed.
You will have to have the set serviced in order to get it going again.
Jerry G.
Jun 03, 2008 | Televison & Video
Power problem
would require some troubleshooting, common problems would be convergence amp ic and high volt transformer transistors
If you are really brave tackle this TV FAQ.
http://repairfaq.ece.drexel.edu/sam/tvfaq.htm
Dec 04, 2007 | Panasonic PT-47WX42 47" Rear Projection...
Sony KP-53HS10
I've had my T.V for about 5 years, and the other day the screen just died and I have no audio, but the when I plug it in the red light in the front flashes, have any idea on what to do.
Nov 21, 2007 | Sony KP-53HS10 TV
Tv will not turn on
it is a symtpom of vertical failure in circuit..its either loose connected part or blown up ic in vertical section but most of the time its just a dried up capacitors 100uf/50v 1000uf/25 and 2 2.2uf/50v
Mar 18, 2007 | Toshiba 43H71 43" Rear Projection...
Televison & Video Logo
224 people viewed this question
Top Televison & Video Experts
