Question about Fujitsu M4097D IPC Path-Through Flatbed Scanner
Scanner out of paper
Hi, When I attempt to scan, I receive error message 'Scanner out of paper". Can you please tell me how to correct this?
  • boermre Jul 16, 2008
    Thank you for your response. Vendor was called to troubleshoot and provided the same information. The paper sensor appears to be the issue. The cost to replace with new sensor was high considering the age of the scanner. So we are replacing with new scanner.
    Problem Solver:
  • 14 Answers
Well, I think you have got the price for the whole sensor unit.
It is possible to use the much cheaper sensors from a Fujitsu M3093. If only one or two sensor arms are broken a technician can exchange this arms very easy. Normally you need a sensor unit Part No. PA03951-0154 for round about $ 630.
But you can also insert the sensor arm from these part:
PA98201-0179 Sensor M3093DE/DG (EX/GX)
or
cost about $ 25 per sensor !
Isn't this a good thing to save a lot of money?
Posted on Jul 22, 2008
    Problem Solver:
  • 8 Answers
Please check if all paper sensor arms are present and not blocked.
Sometimes on of then will be missing or broken.
The center sensor just below the separation pad is the paper end sensor. If this sensor don't work, the scanner do not stop feeding.
It means you scan on sheet, the scanner eject it and then the feed motor do not stop because the paper end sensor don't record a paper end.
Another case may be a driver error. In case you are using XP and installed a new service pack please check your SCSI driver versions (ASPI32 and so on) and TWAIN resp. ISIS driver and update them.
Posted on Jul 15, 2008
Why am I getting the message "the system cannot find the path specified" when trying to scan?
Hi Tania,
You receive this notice when the drive and folder the scanner is configured to save the scan is missing. You can correct this by telling the computer where to save the scan. follow this simple steps.
  • On your computer desktop, click Start - open Devices and Printers -
  • Right-click on the printer/ scanner icon and select scan options. Assign a destination folder for saving your new scans.
Please rate me if this helps.
Oct 08, 2014 | Canon PIXMA MX452 Wireless Inkjet...
Hi, I have a lexmark x7170 and keep getting an error message "unsupported cartridge". Help please!!
If you receive an error message that tells you that you have an unsupported cartridge, then you need to remove the cartridge. After installing the appropriate type of ink cartridge you should no longer receive the error message and you can then perform a print test.
Instruction on how avoid unsupprted cartridge message.
  1. Lift up the scanner unit (with the power on). The printer cartridge carrier will move to the top of the printer into the loading position.
  2. Press down on the lever above the cartridge and then raise the cartridge lid. Remove the cartridge and make sure the cartridge supports no more than four colors (cyan, yellow, magenta and black) and a speed of 22 parts per notation.
  3. Insert the compatible ink cartridge into the carrier and then lower the cartridge lid. Close the scanner unit, then make sure plain white paper is inserted into the paper loader.
  4. Press the "OK" button on the control panel and the unsupported cartridge message should be gone. Press the "Select" button and a test alignment page will print.
Nov 21, 2010 | Lexmark X7170 All-In-One InkJet Printer
Fi-6130 scanner displays J1 paper jam after
Does the message shows after few pages scanning or is there any panel error message like J-1 on scanner start up?
If the issue occurs during scanner start up, then there are staple pins or dirt might be stuck inside the US Sensor panel inside the scanner. Cleaning and removing the objects will resolve the issue.
If the error occurs after few pages scanning, then you may have to check the Pick Roller, Brake Roller, Pinch Roller and US Sensor FX status. you may have to replace any of the above, if damaged or worn off.
Hope the above information is helpful.
Please check your device first and get back to me.
Thank you.
Regards,
TechSatya
Jul 19, 2010 | Fujitsu fi-6130 Flatbed Scanner
Paper jam message is showing but nothing is jammed in scanner and it will not pull the paper through
Hi
Hope the above info is helpful.
Thank you.
Regards,
Tech Satya
May 26, 2010 | Fujitsu fi-6130 Flatbed Scanner
Load mp feeder error optra t 642 printer
I received this message when I was trying to print a pdf file. I attempted messing with the positioning of green paper guide to no avail. My co-worker suggested I uncheck the Choose paper source by PDF page size box on the Print pop-up box. This did the trick.
Dec 08, 2009 | Lexmark T642 Laser Printer
I have a fujitsu 4120 scanner that will not pull the paper even after i changed the roller and pad.
Does the scanner displays any error message on the scanner panel? Is there any TWAIN error message?
If paper jam occurs, U1 error will be displayed on the scanner panel and TWAIN driver will display " Paper jam the ADF (Code DS32002)" error message.
This error is detected when one of the followings occurs:
1) A document does not reach the TOP sensor while the scanner has transported the document about 250 mm to pick. (The scanner
performs retry operation.)
2) The trailing edge of a document does not reach the TOP sensor after the scanner transports the document by the length (L) below. (The document may have slipped on the rollers) Scan condition Transported length.
In order to assist you with your scanner issue, Please provide the issue details with error message.
If nothing is being displayed, then the issue could be due to failure in Pick Motor function or Pick Sensor malfunction.
Thank you for contacting FixYa.
Regards,
TechSatya
Apr 24, 2009 | Fujitsu fi-4120C Path-Through Scanner
Error message 2,177,0 and 2,7,0
follow the link
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=235&modelid=10445
also the contact number
Solution: Contact information for Canon Technical Support.
Canon Telephone Support Contact Information. For toll-free technical support, please call 1 (800) 828-4040 during regular business hours (currently Monday-Friday 8:00 a.m. - 12:00 midnight. EST, Saturday 10:00 a.m. - 8:00 p.m., excluding holidays).
Mark
Apr 12, 2009 | Canon CanoScan 4200F Flatbed Scanner
Scanner runs out of paper
hi,
check paper pathway if theres some jam ..removed the jam if still error check and replaced motor ot paper sensor.. thx en good luck
Apr 14, 2008 | HP LaserJet 3030 All-In-One Printer
Fujitsu M4097D IPC Path-Through Flatbed Scanner Logo
216 people viewed this question
Top Fujitsu Office Equipment & Supplies Experts
Chris Larocque
Are you a Fujitsu Office Equipment and Supply Expert? Answer questions, earn points and help others
