Turn the scooter's power switch to the OFF position.
Connect the charger's plug to the charging port on the scooter.
Plug the charger's power cable into a power outlet.
When the charger's LED red/orange light is on, the battery is charging. Optimal charging time is 6 to 8 hours, or up to 10 hours to achieve a complete charge. The scooter manual will have the exact charging
Times recommended for your scooter.
Stop charging when the LED light is completely green.
Disconnect charger from the scooter, then from the power outlet.
Run your scooter before riding it to verify the battery charge.
Make sure that the charger is fully connected to the scooter; ususally the controller lights will go slowly left to right to indicate it is charging. Make sure the charger is plugged directly into the grounded wall outlet, not into an extension cord or power bar. If the charger is not being recognized by the scooter, you may need to replace the charger, or at least the power cord to the charger.
If your scooter has been sitting unused for a while? If so, the batteries might not charge anymore and will need to be replaced. Contact the manufacturer for a service call or troubleshooting over the phone.
The control seems to be the issue. I have rewired so many scooters. When you have power and it wont go, it is usually the control. If you cannot afford the part right away, you can rewire it or have it rewired direct
It is pretty common for the meters on the charger to either not work at all, or give an inaccurate reading. They get bounced and dropped, and they aren't that well built to begin with. Basically, just ignore the charger as long as you are getting a full charge out of it, and getting good distance with each charge.
