Question about Microwave Ovens
Need a manual
Can we get a manual for the Whirlpool gold accubake system, 853879354001, xnj1457056
  • 1,036 Answers
To access the manual for your Whirlpol appliance Click HERE
Enter your reference in the box half way down on the right of that page, and you should be able to download the manual.
Full instructions are given to locate this reference number on the appliance - just follow the links.
Thank you for using Fixya!. If this provides the solution for you, Please rate as such. Thanks.
Posted on Jul 03, 2008
I have a Whirlpool Gold Accubake System Microwave. I have no power to the microwave. The outlet it is plugged into have power running to it and the circut breaker is good and only runs to the microwave...
Most likely the power supply has to be replaced; but it could be the safety switch too. Do you have any experience or knowledge in using meters and troubleshooting electronics? If not and you want to repair the microwave- send it out to a qualified/ certified microwave repair shop. Or else buy a new one. Best regards ~
Mar 13, 2014 | Whirlpool GT4175SPS Stainless Steel 1200...
Whirlpool accubake system E1 - F5 error code
1. If door latched:
  1. Disconnect power from unit.
  2. Check wires and connectors from control to door switch, then from door switch to control. If no damage to wires and all connectors okay, proceed to step 3.
  3. Replace door switch.
  4. Re-apply power.
  5. Press and hold any key down for 1 minute to clear F5 failure code from memory. F2 will appear. Press CANCEL and observe for 1 minute to ensure operation is correct.
You can usually find helpful exploded view diagrams and order parts by entering your full model number with suffix from the tag here.
Dec 10, 2012 | Whirlpool Microwave Ovens
How to change bulb in whirlpool gold microwave
If your owner's manual does not address it, it's not meant to be user-accessed, so you will need to remove the outer cover to access and change the bulb.
If it's an over the range model, you may have to remove it from the wall.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Dec 15, 2011 | Whirlpool Microwave Ovens
Whirlpool Gold Accubake system microwave indicates door open whenever try to heat. Light (inside microwave) does not come on when door is open. Door open error stays on until cancel button clicked then...
I just had the same problem with my microwave. First DISCONNECT THE POWER. Remove the front top grill (screws are on top of microwave). Unscrew the one screw at the top of the control panel and lift it out of the way. You will see three micro switches to the left of the pannel. I bent the metal frame they were mounted to by hand to move them back into place. The microwave oven works great now. If this does not help, then I would consider replacing the top limit switch.
Jul 13, 2010 | Microwave Ovens
I have a Whirlpool Gold Accubake Stove with ceramic top ( approx 9 yrs old) ..the dual burner (one size for smaller pots vice versa) will only heat both burners even when you only turn the smallest part of...
This is becoming a common problem. If your dual burners are controlled by the burner switch only, then you need to replace your dual burner infinite switch. Some models have a seperate rocker switch that switches from small burner to both burners. If you have this style then this is usually your problem. Can also be from shorted wiring but this is very unlikely. Good Luck, Appliance Specialists
Dec 11, 2009 | Microwave Ovens
Microwave runs, but not heating. Whirlpool Gold
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, & testing.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can download Whirlpool owner's manuals and installation instructions (very handy when removing the oven form the wall for parts replacement) here.
You can find helpful exploded view diagrams and order parts here.
Nov 22, 2009 | Microwave Ovens
I have a Whirlpool gold accubake microwave / oven combo model number GMC305PDS07. The microwave will not turn on and will display "DOOR". I think it is thinking that the door is open?. Please help.
Press and hold the DELAY START TIME button for +5 secs and a chime will sound. The option to toggle between SND HI and SND LO will come up, pressing Delay Start Time will change it between these options.
Jul 18, 2009 | Whirlpool RMC275PD Microwave Oven
Microwave Ovens Logo
526 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
