Question about Kenmore 24032\24036 Top Load Washer
Kenmore 70 series
Kenmore does not complete rinse cycle. Stops in the middle of the cycle and shuts off. Does not get to spin cycle. Help.
  • 5,911 Answers
It sounds like you have a bad lid switch. If you open and close the lid, you should hear a distinctive "clicking" sound as the lid switch is activated when the lid closes. If you hear no sound, you need to check the following:
Some washers have the lid switch under the right-hand side of the wash tub opening and is activated through a small slot on the wash tub casing rim by a small plastic piece on the lid called a lid strike. If this is the type you have, make sure the lid strike is still intact or the switch will not activate. Check the two mounting screws next to the slot and make sure they are present and tight. These are the mounting screws that hold the lid switch in place. If they come loose it can prevent the switch from activating.
Newer models have the lid switch mounted under the washer casing in the left-hand rear adjacent to the left washer lid hinge. The switch is activated by a rod on the lid hinge. Sometimes a simple adjustment of this rod can correct contact problems.
No matter what configuration you have, if you make all these preliminary checks and the switch still does not work, replace it. The following link will give you step-by-step instructions on how to accomplish this:
http://www.fixya.com/support/r385198-replacing_lid_switch
If you require further assistance, please let me know. I hope this helps you.
PS If you provide me with your COMPLETE model number (located under the washer lid along the tub rim) I can also assist you with locating parts.
Posted on Jul 03, 2008
Kenmore 70 Series Washer Won't advance in the
Bad timer. Try to find a used one if possible, this item is a little expensive.
Aug 23, 2010 | Kenmore Washing Machines
Kenmore Model 22722 will not drain
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Jun 01, 2010 | Washing Machines
Kenmore 70 series Washer will not drain and spin
You have a bad lid switch . Try inserting something into the hole on the top and see if that starts the machine in drain/spin . If not , still bad lid switch . If so , tells you still bad lid switch .
Jul 26, 2009 | Washing Machines
My kenmore top loading washer 70 series wont go into spin cycle
check the lid switch some washers will fill and was with the lid open but will not spin, if the lid is closed manually actuate the lid switch or bypass it electrically, or replace it.
Apr 07, 2009 | Kenmore 22422 Top Load Washer
Kenmore washer will not go to rinse cycle. 70 series
I had the same problem and it was a broken switch that prevents the washing machine from going into spin with the the top door open. The switch is located in the upper left corner, you can see 2 screws that hold it in. Reach under and check that the middle point when pressed pulls the ends where the actual switch is, you should hear a click.
I was able to temporarly repair by focing the swtich to always be depressed with 2 strips of duct tape. - Warning the washer will go into spin cycle with the top open.
Jan 04, 2009 | Kenmore 22422 Top Load Washer
Kenmore 70 series Washer will not go to spin cycle
Check the lid switch. That is a VERY common problem on these models.
Dec 13, 2008 | Kenmore 3.2 cu. ft. Plus Top Load Washer
How to work my washer?
the timer change by itself. You don't have to change anything.
But cold rinse only works if you have the cold water connect to the washer
May 08, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
60 people viewed this question
Sal De
fordexpert
Robert Rankin
