Question about Belkin Computers & Internet
Hi I have the belkin N1 wireless router its been fine till about two days ago now it will not let me get on line .when I look for my signal strength and other networks there is a small red cross insted of the signal strenth green bars....can you advise me ... mally.
Got in touch with belkin
Posted on Jul 04, 2008
My wireless router only worrks when you are right by it
Strange, as these modems tend to have a pretty decent wireless signal strength. Try changing the channel your modem broadcasts on. If you surf to 192.168.1.1 you'll be able to visit the modem interface, where you can change this setting.
Aug 18, 2010 | Belkin N1 Wireless-N Wireless Router
My icon says I only have 80% signal strength, is
80% is a good signal strength....but if you want to increase the signal strength, then you need to move the wireless router to a very ventilated area, also the router should be placed atleast 5 feet away from other electronic devices like, modem, ups, microwave ovens,refrigerators etc.... also there should be a line of sight between the router and the wi-fi adapter... but in order to connect to a wireless network 25% of signal strength is enough....
Apr 17, 2010 | Belkin Computers & Internet
Belkin adapter will not connect to home network. It says poor signal strength even when I'm in the same room!
hi it is simple to connect to the wireless network using the belkin adapter.
You can switch over to the windows utility. that should work. it does not work then try to uninstall and reinstall the adapter.
Click here for more info
Oct 11, 2009 | Belkin N1 Wireless USB 2.0 Network Adapter...
Extend the range of my N1 router - how?
I have 2 x Belkin N1 vision dsl (cable) routers. One is connected fine with Virgin 20 meg broadband. Is it possible to use the other N1 vision router as a range extender up stairs to get better signal , without using any cat5 cabling ? I.e router-to-router
Aug 04, 2009 | Belkin N1 Vision Wireless Router
Belkin N1 wireless network not working
It might be an idea to upgrade the firmware which can be downloaded from manufacturers' website
Mar 20, 2009 | Belkin N1 Vision Wireless Router
Not satying connected
Try using the Window built in connection utility. Open up the belkin softwar, click on the 3rd tab and select, use windows. See if that works
Jun 04, 2008 | Belkin N1 Wireless USB 2.0 Network Adapter...
Belkin N1 router - wireless light not on???
Wow! I'm having the same problem!!!! Worked great...Now it's pooped!
May 15, 2008 | Belkin (F5D8231-4) Wireless Router...
Belkin N1 MIMO Wireless Router dropping it's wireless signal.
You can try configure only 802.11 n. Change wep or wpa, test again.
This issue no solved, turn off your wireless router, and search other signal around your room with his pc´s or notebooks wireless. If you see many networks wireless, check the channel less network and put your router this channel.
Test again and see solved this issue.
Good Luck!
Mar 27, 2008 | Belkin (F5D8231-4) Wireless Router...
Poor signal strength on wireless router? ?
k login to the w/l router and change the channels to 11>or 1 use always use these only and delete all teh temp files and delete cookies and clear history and check with antena which is straight>and reboot the router and laptop>and rate me solved if its help full
Oct 30, 2007 | Belkin (F5D6230-3) Wireless Router
Computers & Internet Logo
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
