Question about Cell Phones
The volume control on side of 6230 wont raise the volume from lowest level so playback of songs etc not audible
  • 32 Answers
Technical issues which needs to be fixed by your company you are with.
Posted on Jul 03, 2008
How to unmute microphone (microsoft Vista)
::Look EASIEST WAY OF THEM ALL RIGHT HERE::
[1] --> Right Click the Volume Icon at the bottom right corner of your screen [The Task bar].
[2] --> Click [Playback Devices]
[3] --> Right Click the [Speakers] Icon and click Properties
[4] --> Click the [Levels] Tab; and there you will see the Microphone Volume slider (The one at the very bottom of the "HD Audio output" and "PC Beep" sliders where you can un-mute the mic playback (By clicking the unmute icon, than slide the volume up to where you prefer it... Simple smile.gif I hope I was able to help someone with this... wink.gif
Dec 26, 2010 | Computers & Internet
Tip
How do I make my iTouch Louder
<p>He the volume of the iPod Touch can be affected in some way, the definition of musical sound check the volume limit set in the settings device preferences. The tool of sound check, which can also be found on iTunes, check your iTouch music and video library for the stabilization of the equalizer song for a constant level, the volume limit reduces the volume to grow beyond a set point, which helps the potential adverse effects of hearing loss caused by loud music. <br /> <p><br /> <p>1. Press the button to the left of the iPod Touch. The volume switch top left of the iPod Touch increases the sound volume, and gives a volume icon on the screen as it grows. Accident on the volume button for the iTouch, it seemed sound problems. Touch the "Music" icon to start playing the song, press the volume for music to grow. <br /> <p><br /> <p>2. Adjust the volume control settings. Tap Settings on the iPod screen Touch, Touch "Music" and tap "volume limit." Slide the tab to the right of way to reduce the volume bar to change the limit of the maximum. Press the Home button to save and Settings. <br /> <p><br /> <p>3. Sound Check off. Tap "Music" in the Settings window and slide the guide Sound Check to the left to the sound check feature off. A Sound check song keeps playing very hard at the same level. While the function prevents sudden jumps in volume, can also lead to a series of songs to play very soft, depending on the quality of the music. <br /> <p><br /> <p>4. Adjust the volume to your headphones. Press the "+" button on your Apple headphones, the volume of a music or video playback to increase. If a song or video does not play, the volume control adjusts the volume on the iTouch. <br />
on Aug 05, 2011 | Computers & Internet
Vgn t350p no sound
Try the steps below, this should work:
  1. Restart the computer.
  2. Check the system volume to make sure the volume is not muted or too low.
  3. Ensure the volume control dial on the left side of the front panel is increased to an audible level.
  4. Plug in a set of headphones to see if there is sound through the headphones. NOTE: If there is sound through the headphones, the issue is with the speakers.
  5. Ensure the playback device is correctly selected .
  6. Select a sound scheme in Control Panel.
  7. Reinstall the sound drivers.
  8. Check for conflicts in Device Manager.
  9. Remove all added hardware to see if it is conflicting with the sound card.
  10. Reset the BIOS to the default values.
  11. Use the System Restore utility to restore the system back to a point when the sound last worked properly.
Download and install the Audio drivers from the below link:
http://esupport.sony.com/US/perl/swu-download.pl?mdl=VGNT350P&upd_id=1670&os_id=7
Thanks!!!!
Dec 21, 2010 | Sony VGN-T350P: VGN-T350 Pentium M 753...
The volume on the ipod (4th gen) seems to change on its own. WTF!
the volume may change depending upn the quality of the songs that you may have downloaded...one way to fix that is to go to itunes...edit...preferences...click on playback and check the sound check option...this will adjust the sound levels of all songs automatically...you can even change individual song volumes....right click the song that you want to change in your library...go to get info...options...and there you can adjust the volume of the song or even define preset equalizers for any particular song...hope im of help :)
May 22, 2009 | Apple iPod 4th Generation MP3 Player
Sound of the recording after burnt to a cd is very low
adjust your top knob which is called the gain, this will allow the incoming signal to be muchlouder depending on where you set it , the bottom fader is for playback volume and mixing and you should also a avolume control for your head set , follow also the recording instructions in your manual for optimal settings , there,s no reason that your recordings should come out with low volume other then your gain control being set to low , hope i was able to help , if i was please leave a nice rating ,sincerely glenn mayer
Mar 09, 2009 | Tascam 2488 Portastudio Multitrack...
How can i raise the volume on my dell inspiron 1525
Here's how I fixed mine with Win-VISTA:
1. Click START
2. Click CONTROL PANEL
3. (Switch to CLASSIC VIEW)
a. Click on SOUND
b. Click on PLAYBACK Tab
c. Click on SPEAKERS/HEADPHONES
d. Click on PROPERTIES
e. Click on CUSTOM Tab
i. Make sure PC SPK MUTE is NOT checked
f. Click on LEVELS Tab
i. Slide PC SPEAKER to 100%
ii. Don’t worry about the SPEAKER slider, it’s controlled by the keyboard buttons
g. Click on ENHANCEMENTS Tab
i. Make sure LOUDNESS EQUALIZATION is checked
h. Click OK
i. Click OK
4. Close CONTROL PANEL
Dec 07, 2008 | Dell Inspiron 1501 Notebook
How to increase sound in nokia6600
well, if i suggest u don't waste ur time in thinking how to increase to sound, this set really has low sound, try to use songs have high pitch in notes of song., or raise pitch of ur songs from computer then upload to ur phone. otherwise no such way to increase volume of ur phone.
Feb 23, 2008 | Nokia 6600
35 in. GE tube TV volume issue
The front panel control assembly, or the circuit area for this panel most likely has a fault condition.
I have also seen some of the button switches fail on the control panel.
Jerry G.
Nov 14, 2007 | GE 35GT740 35" TV
Musit volume too loud through headphones
Download mp3gain (freeware) and it will adjust the volume in all your mp3 files down to a reasonable level. Try 84 dB. Then sync them onto your phone.
Nov 03, 2007 | LG enV VX9900 Cellular Phone
Volume problems when connecting the Ipod
have you tried lowering the IPOD volume?? Try searching for auxiliary settings on Manual! Patrick
Jul 25, 2007 | Alpine CDA-9853 CD Player
Cell Phones Logo
118 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
