Question about ViewSonic VX924 19" LCD Monitor
Trouble hooking external Viewsonic monitor to Toshiba laptop
There is no picture coming up on the external monitor with a standard monitor cable. It has teh desktop image, but no icons or mouse toggle between screens?
how do I get this to work so the laptop desktop display is the same on teh external monitor?
  • Anonymous Mar 15, 2014
    Hooking up Starlogic monitor to my laptop running Vista. Monitor comes on for about 2 seconds then turns off.
  • 45 Answers
If I understand You are using a Monitor connecting the Monitor...
and the background is shared byboth the display however the Cursor stays only on one of them at a time.However it can be toggled among the 2.
If yes,
then this Feature is called the Extended Display.
Use the same Key Combination that you would use for external Display one More time and it should Work.
Posted on Jul 17, 2008
Toshiba satellite c675 monitor light up but not displaying anything
Hook up an external monitor to determine if you have a logic board or LCD problem If the external monitor works the trouble is with the display or its cables. You should also double check that your memory is properly installed and you may want to replace your bios battery. you will need to aquire a toshiba manual for your laptop to help you fix these issues. here is the link for finding your manual Search
Aug 13, 2014 | Toshiba Satellite C675d-s7310 Amd E-480...
How do i repair toshiba satellite a105 ribbon cable repair
Have you tried hooking up an external monitor to it and seeing if it works? I would try that first to rule out a video card issue. If the external monitor works fine, here is a website with pictures on how to disassemble the laptop to replace the screen:
Toshiba Satellite A105 Laptop Disassembly Guide Cooling Fan Heatsink...
Jul 23, 2014 | Toshiba Computers & Internet
Turns on no pic tried to hook up a monitor to it
Hi
Thank you for your query
When hooking up a external monitor please ensure you press the fn key and one of the F keys that has a picture of the 2 monitors on top, this will swap the picture from the laptop monitor to your external monitr
If the above works then the fault resides on your laptop monitor screen, it may be that the riboon cable/ lcd screen or the inverter have gone.
if the above doesnt work then it may be the onboard vga on the graphics card that will need replacing
If this has been useful please leave positive feedback/vote/testimonial as
this will help me greatly - Thank you again
Feb 13, 2010 | Toshiba Satellite A135-S2386 Notebook...
Can't connect to external monitor or to Sony bravia tv. When vga connected nothing happens at all on laptop but external monitor says " check cable" ( have tried another cable ). If connected in power off...
You need to:
- Connect everything with the laptop turned off
- Boot the laptop
- Use the Fn key plus F8 or F9 (I'm trying from a small picture of the keyboard!) to cycle through the external display options.
Dec 22, 2009 | Toshiba Satellite Pro L300 Notebook
Viewsonic monitor lcd to laptop problem
Remove the second monitor entry in Device Manager, and let the machine try to find the driver. I swear, sometimes, computers have minds of their own! ??
Apr 04, 2017 | Computers & Internet
We have the monitor hooked to a docking station for a laptop. I can not view the screen on the Viewsonic, but does display on laptop. I have been able to do an extende monitor view, but not the main view....
when you connect external monitor to a laptop u get two options in the monitor section of graphic properties tab
1.) extended
2.) clone
it is clear from ur post that u are using extended view
try using clone mode then both laptop screen and external monitor will show the main screen
other method is to disable the laptop screen and just allow external monitor to work, in this case laptop screen shows nothing but external monitor shows main screen
Sep 29, 2009 | ViewSonic VG700b 17" LCD Monitor
External monitor issues with Toshiba Advanced Port Replicator III
DebitGuy
I have the exact same problem with a Tecra Laptop and a ViewSonic monitor - Did you manage to resolve this at all?
Thanks in advance
Stu
Jan 08, 2009 | Toshiba Advanced Port Replicator III...
Dual monitors
Most laptops have a function key to set which monitor is active. By toggling this key, you switch between laptop screen, external screen, and both.
On the keyboard, the key is usually Fn pushed together with one of the function keys that has a monitor logo above it.
Jul 22, 2008 | Intel Motherboard
Screen problem.
Does your LCD look like this or similiar? (below) If it does, there should be a female plug similiar to the picture also below.
Hook smaller end of cable to your laptop, the other end to your external monitor. Turn on your laptop. If the vertical lines are not present then its probably your LCD, which will more than likely have to be replaced. If lines are present, then like tom19511 said it may be the video drivers. I've had this same problem with my Toshiba Satellite p35 5 times already. Toshiba had to replace my LCD each time. LCD's are more expensive than an inverter. Good luck, I hope you get it fixed.
Dec 13, 2007 | Toshiba Satellite P35-S611 Notebook
My Viewsonic LCD monitor showing no siganl and blinking continuously. please provide solution
Make sure cables are properly connected in both ends. If you have it hooked up to a laptop, make sure the external monitor is enabled. Usually you can toggle this with the "Fn" key + one of the F1-F8 keys pressed at the same time.
Also check that no pins in the cable are bent or damaged. Try to connect a different monitor to the PC to see if your monitor is at fault, and/or a different PC to your monitor.
Dec 05, 2007 | ViewSonic VE710b 17" Flat Panel LCD...
ViewSonic VX924 19" LCD Monitor Logo
328 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
