Question about Baby Lock Eclipse Serger
Rolled hem on chiffon
When making a rolled hem on a very light weight fabric such as chiffon or a light weight cotton knit, the stitches will often slip off of the fabric, though the edge is being cut. I have tried putting the differential feed below normal, but this still does not work. I have also experimented with different upper, lower , and needle settings, but the problem persists. Any suggestions?
  • rbjat520 Feb 19, 2009
    I have a Baby Lock Evolve. I am experiencing the same problem. It seems the problem is when I get to an area that is not on the straight or cross grain of the fabric. The stitch seems to go off when I get near a bias section. Ben
Turn under the edge just about 1/4" and do a rolled edge then you can go back and trim off any of the folded under fabric that may show. Also, this keeps the hem from pulling away so easily. You may also try putting some water soluble stabilizer under the fabric before you serge.
Posted on Mar 19, 2009
    Problem Solver:
  • 16 Answers
Try a setting on a wide cutting width
Posted on Jul 03, 2008
Can I make rolled hem with a Juki MO 2366 N?
Most likely. Most overlockers can make a rolled hem. You will probably want to do a lot of practicing on scrap chiffon before trying it on the real thing. It involves using only one needle, both loopers, and making appropriate adjustments to the machine.
Serger 101 Threading the Juki MO 654de Machine for Roll Hemming by CKC...
How to Serge Rolled Hem
Serger Stitches 101 Cheat Sheet Never Ever Without It Your New Must Have...
Bernina has some very nice Serger Workbooks that could be helpful:
Bernina Mastery Workbooks
Nov 13, 2017 | Juki Sewing Machines
I have tunneling on fabric when i use the zigzag stitch.
Sometimes it is because the tension is too tight.
Also, if it is light-weight fabric, like chiffon or fine silk, the fabric does not have enough body to hold the stitching flat. You can add tissue paper to the fabric and stitch it into the seam. Once stitched, the tissue paper can easily be torn away. (If your machine has a blind hem presser foot--or what she refers to as an over edge foot below, it may be helpful. It is a presser foot that has a bar that separates the right and left side of the stitch and provides just enough leeway for the thread to lie flat.)
tunneling when zigzagging Threads Magazine Gatherings Forum Sewing...
Jul 09, 2017 | Sewing Machines
My new machine sewed fine in cotton material, but I am having trouble sewing on a silky top.
Machine settings usually need to be re-adjusted when the project materials change, ie the needle size & type, the type/weight of thread, the presser foot pressure, the thread tension, the stitch length, etc. Sewing woven cotton is very different from sewing silk or chiffon. Test on scraps of the fabric before actually sewing on the garment. Even adding tissue paper to the stitching will help prevent fabric puckering.
Top 10 Tips for Sewing With Silk
How To Sew With Silk And Silklike Fabrics
Jul 05, 2017 | Sewing Machines
My juke mo644d serger what side needle do I use for 1 thread serging
The needle "system" is determined by the manufacturer, ie 130/705. However, some sergers do use a different needle system that may be slightly longer or shorter. Getting the right one is very important for the successful use of your machine.
As far as the size of needle, that is determined usually by the fabric and the thread weight you are stitching. For example, if you are sewing chiffon with a fine thread, you would want to use a smaller size needle (like a 65), but if you are stitching denim, you would want to use probably a 90 needle with heavier thread. Be sure to consult your manual because most machines do Not recommend using a needle larger than a 90.
As for the needle type, that is also determined by the fabric you are stitching, as well as what is available in your needle system, ie a ball-point needle might work better on a knit fabric but a universal needle will probably work better on a woven cotton. For the most part, I use the same needle type for my projects unless I encounter problems, like knit fabrics running because the needle is cutting the fabric.
The following may be helpful:
All About Needles
SCHMETZ Household Needle Chart
Overlock Needles SCHMETZ Needles
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=2&ved=0ahUKEwjUvK2Y36vTAhVPy2MKHWq6AAQQFghAMAE&url=https%3A%2F%2Fwww.bernina.com%2Fen-US%2FResources%2Fbernina-products%2Fzubehoer%2FNadeln%2FPDFs%2FNeedle-brochure-2016&usg=AFQjCNHLWzgwdiO1d2_cFFIdsqPtcEz0MQ&cad=rja
Apr 17, 2017 | Sewing Machines
How do I set my Bernette 334D to overlock thin T-shirt material?
Thin, light-weight fabrics present some issues with sergers, ie the fabric tunnels with the stitching. Usually, it is better to use a narrow seam. Also, a stabilizer (wash-away) or even adding a strip of thin paper (toilet tissue, adding machine tape, etc) to the seam will help the fabric hold its shape when stitching. I have also sprayed & ironed heavy starch on thin fabrics to help stabilize.
sewing patternreview com
Serging Chiffon and Other Slippery Fabrics
Make It Handmade Understanding Your Serger Features
30 Best Tips for Sewing Knits with Serger Sewing Machine Serger Pepper
Jul 02, 2016 | Sewing Machines
Best tension settings for a rolled hem on stretchy fabric
you don't mention if the machine is a sewing machine or serger, or the name or model number?
Apr 15, 2016 | Sewing Machines
How do I adjust tension on a Janome Harmony 9102D
Sounds like you want to do a rolled hem for a handkerchief edge, I do the following to create a rolled hem on my over locker. Take out left needle and cut and remove that thread. Open front cover and slide back lever for the stitch finger in the needle plate, this finger stops the fabric rolling under thread tension normally so you need to pull it back out of engagement. Your Janome may have a similar means to select the rolled hem or you may need to remove the stitch finger with a screwdriver, it varies between models.
Thread upper looper with wooly nylon and right needle and lower looper in matching colour thread. (You can go wooly on the bottom looper but it hardly shows so I never bother.) Disengage upper blade and move the fixed lower blade to the right to trim less, then lower upper blade back into position. Now tension, needle leave alone (5)' upper looper very loose (2-3) and lower looper tighten up to 6-7 and test stitch. You want the upper looper thread to go right underneath and the lower looper thread to disappear against the needle stitch. And the fabric to roll inside the stitching. Finesse tensions on the loopers until this is right, you may need to change blade position too, depends on weight of the fabric and how it rolls. Once this is right turn stitch length down to close up stitching, 0.8 or even 0.5 if you want full coverage. Thats it. You can use differential feed if you want a fluted rolled edge, nice on knits.
Mar 02, 2015 | Janome Harmony 9102D Mechanical Sewing...
Make a rolled hem
If you want it done entirely by machine you will need a special attachment. You'd have to check the make and model of your machine to find out if there is an attachment available from the maker. If not, there are some companies that make general attachments, and they'll list what machines these will fit. Check online sewing supply houses for this kind of thing.
You can also make one by hand. Any decent sewing book would tell you how. Usually you sew a straight stitch along the hem, using quite small stitches. Trim hem to a quarter inch from the stitch line. Crease the fabric or press it along the stitch line to the inside. Anchor your hand thread, then take a short stitch right along the stitch line. Next catch one thread of the fabric a quarter inch above the stitch line. It's just a basic running stitch, back and forth. Every few stitches, gently snug up the thread, which will roll the hem over. The finer the fabric, the smaller the stitches you take where they'll show should be.
There are some images that will help, if you enter the following search terms in google, you will see several pictures. Type the words," Illustrations for how to make a rolled hem by hand ? " and you will get a load of ideas.
Oct 09, 2014 | Sewing Machines
How do I create a rolled hem with this machine. I see the stitch width knob, but do I need to remove one of the threads for this?
Making a rolled hem on any overlocker is achieved in the following way:
use right hand needle only and top and bottom loopers. Turn stitch length down so threads are closed up (on mine this is 0.5). Your stitch length dial will be one on the right hand side near the flywheel usually. Loosen off the the top looper tension and tighten up the bottom looper tension (these are the right and 2nd right tension dials on front of the machine). On my Bernette I leave the needle at the usual 5, 2 on the top looper and 6.5 to 7 on the bottom looper thread. Move cutting blade position to the right so that you are trimming the fabric quite a bit wider than your stitch, this makes the fabric "roll" underneath inside the stitching to form the rolled edge or hem.
There is also another step that needs to happen where you change or remove a little stitch finger that sits in the pressure foot or just under it. On the Bernettes, you flick a lever to move this stitch finger back towards the operator so it is out of the stitch forming area. On some machines, it is a case of changing the little stitch finger which is screwed onto the pressure foot with a screwdriver.
I really don't know with your Necchi which it is but have a good look at the pressure foot, and around the blade cutting area and see if you can see a lever or check out the accessory bag and see if there is another stitch finger in there, it would be smaller than the one on the foot now. In effect, this finger sits out and the threads wrap around it to form your normal overlock but for rolled hem you want a much smaller finger in place to make a very little seam.
The other variable which makes a very neat job is to use a thread called "wooly Overlock" in the upper looper only. This thread when pulled under tension is tight looking but when you let it go, it fluffs out. So when seaming on a rolled hem it fills out the stitching and covers the edge of the fabric fully giving a smooth look. You can do it without but wooly thread makes a great job and you'll see it on all Ready to Wear seams usually for this reason.
If I am going to roll hem a fine sheer woven fabric like organza or chiffon I will change the needle to make sure it is nice and sharp and also ensure it is a regular point, not a ball point (I seam lots of knits so have ball points in most of the time on mine) Usually a size 80 is fine.
I hope this gets you going with your overlocker, I usually test stitch quite a bit with the stitch length at the normal 2.5 setting and adjust the looper tensions until I've got the stitch looking good, then turn it down to the very close 0.5, just to not waste a ton of thread.
Sep 09, 2011 | Necchi 6002 Sewing Machine
Rolled hem or rolled edge
You need to disengage the cutting blade by openingfirstly opening the front and left hand side covers. pull on the larger of the two silver knobs and slide the red lever towards you. I'm not sure what the tension settings are, but I'm certain you need to reduce them a fair bit to aid in the rolling effect. I only use 3 threads when doing a rolled hem.
My description isn't too detailed but I hope it helps!
Jun 11, 2008 | Janome MyLock 634D Mechanical Sewing...
Sewing Machines Logo
1,402 people viewed this question
Top Baby Lock Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Jon Piercy
Are you a Baby Lock Sewing Machine Expert? Answer questions, earn points and help others
