Motorola Headset S9 Control Keys Prob.
Hi
i am using motorola S9 for last one year.
I had the same problem of controls keys which i have corrected of my own.
Most of the sites i read say's this problem is due to the moisture.
Let me tell its not because of moisture.
Below steps will help you guys hopefully if its only the keys control problem.
Take the headset,The control keys are placed near the ear plugs within a area
which is different from the other part.
now what u have to do is just take some sharp thing or your nails enough and
move it around the control keys area (edges) and peel off the rubber layer
carefully.Please note its very soft rubber so be careful not tear it off else it
will be spoiled completely.
After u remove this layer u wll find layer of plastic attached to the rubber
whichh u took out and the same kind on the base. you will fin ther will be
small vertical lines and center one dot on the peeled out rubber and on base
horizontal 2-3 thin lines at the edges and dot at the centre.
actually thes are the contacts which acts as a switch if u observe it would have
been covered with the rubber kind of gum used to stick thes layers.
Just clean these (only)contacts area with piece of cloth and use some rubber kind
of glue (Do not use Feviquik it will spoil the strips completely) at edges and put
it back ,b4 fixing it gum u can test it by just keeping it and check if the keys
are working then fix every thing as it was b4 and stick the peeled out rubber panel
with the same type of glue.
there u are ur problem is solved enjoy the best music experirnce with your S9.
If u have any problem or Queries please post it i wll try to answer as soon as
possible.
if u want a video for this i wll b up loading it soon and post d link.
