Question about Sunbeam SG6622RP Grill
Venturi tubes I just replaced the burner on a Sunbeam 750 grillmaster. the venturis just barely reach the gas orifice Is this safe or
  • 30 Answers
The venturi tubes should go over the gas orifice. If the tubes were to drop off, you could have a fire outside of your grill and possibly an explosion.
Posted on Mar 04, 2010
Grill burner will not burn like the other
Dynasty burners are replaceable and they are very good appliances (when they're actual dynasty, manufactured by jade).
About 90% of the time someone complains about burner flames or heat it is the check valve needing to be reset. I explained this earlier but let me know if you need to know how to do this.
On the rare occasion the check valve is not the problem (and 90% could actually be very low because this is almost always the problem!) the burner could need to be cleaned or replaced or the gas orifice and valve could need to be cleaned or replaced.
Dynasty burners are very heavy cast iron, single venturi "H" burners. Although coated cast iron is quick to oxidize and sometimes because of the coating the rust will start from the inside out. Lift the burner from the back of the barbecue and slide it away from you. Check to see if it is corroding from within.
The single venturi tube extends from the bottom of the burner into the control panel where it slides over the gas orifice at the tip of the control valve. It is possible for the gas valve to get a small insect crawl in through the orifice and build a nest inside the small cavity inside the control valve.
Remove the burner to reach through the inner firewall with a ratchet to pull the orifice and then check the inside of the orifice and the inside of the valve behind the orifice. If something is clogging the orifice the gas will flow unevenly and you may have flame-flashing inside the control panel which will destroy the lubrication in the control valves and will destroy the ignition parts inside the control panel.
I suggest the check valve solution with the drip tray removed so you can look from under the control panel for gas leaking through the air holes in the venturi tubes. Also, remove the control panel and leak-test the valve with soapy water because if previous flashing occurred the first casualty is usually the seal between the valve and the gasket which can lead to more leaking gas.
Check valve:
Turn everything off (tank and bbq).
Disconnect hose and regulator from LP tank.
With tank disconnected, turn the BBQ on. Turn every valve to "high" and leave it for 5 minutes.
Turn everything off -- completely off.
Reconnect tank but turn the tank on very, very slow. The check valve problem occurs when gas "hits" a swing arm too hard as the gas leaves the cylinder so turn the cylinder on very slow and then relight the grill.
Jan 25, 2014 | Dynasty DBQ-30 (LP) Grill
No gas enters tube. nat gas valve on. ignitors sparking. orafices clean.
Glad you cleaned the orifices. Did yo also clean the burners and their venturi valves when you had the burners out? If not, I suspect you may have a spider colony that has built nests in each venturi valve. If so, it stops the gas flow to each burner dead in it's tracks.
Hope this helped you and thanks for choosing FixYa.
Aug 07, 2011 | Viking DVGBQ532-3RTL (LP) All-in-One Grill...
How do you open venturi tubes to clean?
If you remove the burners, the Venturi Tube is part of the open end of the burner that fits over the burner orifice. It should look like a slot on each side of the burner. There's really nothing to open, once the burner is removed.
Hope this helped you and Happy Grilling!!
May 30, 2011 | Fiesta Blue Ember Gas Grill
How do you remove the venturi tubes of a Blue Ember Gas Grill? The manual explains how to clean the venturi tubes, but it doesn't say how to remove the tubes for cleaning. The manual just says...
The venturi tubes are part of the burner. It"s a slot on both sides of the burner tube, where it goes over the burner orifice. You will need to remove the burners to check and clean them.
Hope this helped answer your question.
Apr 18, 2011 | Fiesta Blue Ember Gas Grill
Hi! Hope you can help us--we have a Brinkman 4-burner grill that is about 5yrs. old. Last yr. we started having problems with burner #2 not lighting all of the way and the burners all looked a bit rusty,...
I think you husband is trying to clean the wrong thin. The venturi tube is part of the burner itself. It's the open end of the burner, that has an air intake adjustment on it. It fits over the burner orifice. He may be hitting the orifice, which in fact may be clogged. Remove the offending burners and he will be able to see the burner orifice, which can be removed with the appropriately sized wrench. Once removed try blowing through it. If air doesn't blow through, it's clogged. Clean it with a straight pin that is no larger that the orifice hole. You do not want to enlarge it. Also, the new burners may need adjustment of the venturi for the proper air to gas mixture. Consult you Owners Manual on how to adjust it.
Need an Owners Manual? Go to http://www.brinkmann.net/my_grill.aspx and enter the Model Number of your grill.
Hope this helped you to solve the problem. Please don't forget to rate my response to you. Thanks!
Mar 27, 2011 | Grilling
We're trying to clean the venturi tubes on our Blue Ember FGF50069 gas grill but we don't understand how to disengage the tubes from the burner. Can you help us? Are there any images of the...
The Venturi tubes are part of the burner, where it goes over the burner orifice. You can remove the burner(s) by disengaging them from the burner holder. Which should be at the inner rear of the grill's burner compartment. Then the burner will slide off the burner orifice.
FYI - A couple of years ago, there was a massive recall on the Fiesta Blue Ember Model grill. Don't know if your is old enough to fit that category. So I have included a link to the Consumer reports Website, that liist the Serial Number of those involved.
http://blogs.consumerreports.org/safety/2009/07/fiesta-again-recalls-blue-ember-grill-after-reported-injuries-burns-fires.html
Hope this helped solve your problem.
Feb 26, 2011 | Fiesta Blue Ember Gas Grill
Thermador sgcs365rw - I need to replace the cover for the on/off light. To access it I need to open remove the cooktop but one of the venturi is stuck fast. How can I undo it?
Hello- You got lucky and only have one stuck, unfortunately you will need to order a few more parts. The only way to get the venturi out is to drill it off, drill it down enough that you can get the burner around what use to be the nut portion of the venturi. You will also need to get the orifice holder that the ventrui screws into under the cooktop. These parts are pretty cheap. You could try to put some LIquid Wrench around the ventrui overnight but be sure not to try to force it out too much because the gas supply tube to that burner can get creased if the orifice holder starts to turn... What works best for me to drill the venturi is a countersink, preferably for metal, which has it's largest diameter bigger than the outside of the venturi. Get some cutting oil and start drilling, the ventrui's cut pretty easily but take your time and try not to damage the burner. Once you get down real close to the burner you can try to carefully pry the burner over the remnants of the venturi. Good luck, hope this helps. Best regards.
Sep 27, 2010 | Thermador SGS36GS Gas Cooktop
I am uncertain as to why my barbeque smokes black and leaves a soot film on the whole inside of the barbeque and on the meat that I am cooking. It is certainly a cheap model but I replaced the burner and...
Can you see the smoke coming from the tip of the flame itself? Did you not have this problem before you replaced the burners? If yes to both, then the problem is with the venturi tube of the burner not providing enough air. The venturi tube is the part of the tube where the gas jet from the valve first enters it. There are some holes that control the air/gas mix by their configuration and size. Perhaps you have the wrong model replacement burner. The orifice (very small hole) out of which the gas shoots into the venturi, and the venturi tube itself are both designed slightly differently for use with Propane (bottled) or Natural (piped) gas. Perhaps your new burner has an adjustable venturi to allow more air. If so, remove the rocks so that you can see the flame and adjust by trial and error.
Jun 10, 2010 | Garden
Yellow flame
You may have a rusted, clogged or damaged burner or venturi tube. With a flashlight, check for spider webs, wasp nests or dirt (mud) dauber nests in the opening of the venturi tube where it connects at each gas valve orifice. Clean it out manually or blow it out with air compressor. Make sure the air adjustment opening (on the end of the burner's venturi tube) has not been changed. If it's closed too much, it will be difficult to light and cause lazy yellow flames. If it's not clogged, the burner may just be old and rusted and the burner holes are not allowing very much gas through anymore. It's also possible the burner has rusted so bad, the burner holes have been enlarged, it is falling apart or has cracks along the burner seams. If so, replace the burner(s) immediately. It is unsafe to use. Your local propane co can usually order the parts you need and some will even do the work, if you are uncomfortable doing it yourself. Bring with you the Make, Model and Serial number of the grill, so they can order the correct parts for your specific grill. Also specify whether it's natural gas2_bing.gif or propane.
Douglas
Jun 06, 2010 | Char-Broil CharBroil Master Flame Gas...
Sunbeam SG6622RP Grill Logo
314 people viewed this question
Top Sunbeam Grilling Experts
Gil Shultz
David White
Douglas Dinnebeil
Douglas Dinnebeil
Are you a Sunbeam Grilling Expert? Answer questions, earn points and help others
