How to Reset an Eiki Projector Lamp Timer Lamp 1 reset is as follows:-- simultaneously holding down lens shift and Enter button. press "STAND-BY ON" BUTTON on the projector. LAMP 1 100%" is displayed, indicating that the lamp timer is reset. And for Lamp 2 reset is as follows:-- simultaneously holding down "MENU" and "Enter" button. press "STAND-BY ON" BUTTON on the projector. LAMP 2 100%" is displayed, indicating that the lamp timer is reset. First try resetting lamp 1 in that menu button is not to be pressed. But if lamp reset is not getting done then it can be temp related problem. Clean the air vents and the intake vent cover.
This will help.Thanks.Helpmech
Hello
I guess you did not correctly rest the timer and that is the cause of the problem.To reset the timer correctly
Turn on the projector.
Press the "MENU" button and the on-screen menu will appear.
Press 3/4 button to remove the red frame pointer to the Setting Menu Icon .
Press the 6 button to move the red frame pointer to the Lamp Counter Reset item and then press SELECT button.
The message "Reset Lamp Counter?" appears. Move the pointer to "" and then press SELECT button.
Another confirmation dialog box appears and select "" to reset the Lamp Replace Counter..
This should fix the problem.
The projector will not power up so I cant get any menu up,the manual says to reset the timer you hold the lens shift, menu and power button down and the projector will reset but it wont, thats for lamp 1 and lamp 2 is similar.
