Question about Video Game Consoles & Games
Ps3 not switching to hdmi connection - Video Game Consoles & Games
  • Anonymous Apr 21, 2009
    when i put the hdmi on my ps3 to my lcd it doesnt show and when i go to DISPLAY SETTING - VIDEO OUTPUT SETTINGS i try to put it on hdmi but then it doesnt work PLZ help!!!!!!!!!!!!!1
  • velvet423 Apr 21, 2009
    no hdmi out
    even when set to hdmi in ps and on tv
    tried all solutions of turning off tv and ps, holding the button down for 5 sec etc....
When i remove my HDMI cable the there is no picture
Posted on Mar 22, 2010
    Problem Solver:
  • 8 Answers
Basically mate just when it comes on do you want to go to hdmi, click yes and go to your hdmi channel we had the same probelm but now its sorted :)
Posted on Apr 22, 2009
You need to go into your Display settings and change your connection to HDMI.
Posted on Jul 03, 2008
When I switched my connection from HDMI to av on my ps3 I couldn't hear sound anymore why
Its completely understandable , lot of people face the same trouble switching between the two..
The first step is to make sure that your PS3 is on standby. In a more understandable term, just make sure that your PS3 is turned off but plugged into the wall to the point that the PS3 power light is showing red and not any other color. To switch PS3 HDMI to AV you will have to hold the power button down until it beeps twice. You will have to make sure that your PS3 is off before you begin holding the button down or it may not work successfully. This will tell the PS3 to switch back to AV video. You will have to do this every time you switch to and from PS3 HDMI to AV. This also means that you will have to select the option that allows HDMI every time you try to go back to the HDMI interface. One you do it once you will problem remember by heart on how to fix the problem of not being able to switch PS3 HDMI to AV interface.
Jan 30, 2014 | Video Game Consoles & Games
Samsung TV Is Not Picking Up A Playstation 3 HDMI Signal
If you are able to connect your PS3 to another TV using the same HDMI cable that would rule out your PS3, if it works.....or
does the PS3 itself have any settings that perhaps need to be set to an HDMI output as opposed to Composite or SCART etc?
Also have a look at the HDMI settings in theh TV menu too.
Jan 10, 2014 | Video Game Consoles & Games
Connecting Ps3 with philips tv (full hd) when i got hd cable in, and click to switch so the ps3 uses hd to show things and i than switch over to the channel i plugin the hdmi cabel it gives blac kscreen
If it's the first time using your PS3, use the composite cables that came with it. Turn on the PS3 go to video settings and switch the input to HDMI. After you've switched to HDMI, turn the PS3 off and connect your HDMI cable, go back to video settings and change the resolution to 1080p. If this isn't the first time you've used HDMI for your PS3, make sure your T.V. is on the correct input. If the T.V. is on the correct input, try switching the HDMI cable to a different input. If that doesn't work try using a different HDMI cable, testing different HDMI connections if you're still getting the black screen. If none of those work then it's probably a problem with the PS3, but just to make sure try plugging something else with HDMI to see if that works. If another HDMI device works, then it's your PS3, if it doesn't then it could be a problem with your HDMI connections on the T.V.
May 04, 2011 | Philips 52 In. LCD HDTV
Only sound comes when i connect HDMI cable to my TV for the ps3
you need to select High definition output on the PS3. Connect it via hdmi and via standard lead switch the tv to standard so you can see the picture then select high definition output. Switch over to hdmi and you should see a picture
Mar 01, 2011 | Video Game Consoles & Games
PS3 HDMI - Sony Bravi KDL-40V2000 Problem
  • Have your ps32_bing.gif in standby mode (red light).
  • Now, press andhold the power button in the front down. Your ps3 will beep twice. Letit go almost exactly after you heard the second beep.
  • Wait 10-15 seconds. A display will show up, and just answer yes to all!
try this
May 08, 2010 | Sony Playstation 3 (PS3) Console
My ps3 works with a hdmi cable but it will not display to any tv.
hold your finger on the restart button(the button next to disc eject button) for 5 sec to reset the settings
Jun 05, 2009 | Sony Playstation 3 (PS3) Console
Sharp Aquos LC-32B20E wont display a PS3 output via HDMI
I too went through this problem.
Step 1 - Plug in your "composite" cables and the HDMI cable to the PS3. Obviously, the "composite" cable are the ones that came with the system. You need to start with them as the default connector.
Step 2 - After connecting the "composite" cable and the HDMI cable to the PS3, connect the other ends to your TV.
Step 3 - Power on your PS3
Step 4 - Select display settings-->video output settings
Step 5 - Change from the current video cables to HDMI. (Your tv has different inputs. When you switch to HDMI in the PS3, you will have to switch your TV to the HDMI input that it is connected to, to get a picture)
Step 6 - Be quick, the PS3 will display a "test" for 30 seconds. You need to switch your tv to the correct HDMI input and press "X" on your controller to accept the change.
Let me know how this works for you.
Apr 03, 2009 | Sharp Televison & Video
PS3 won't connect to TV with component video.
You need to connect the PS3 to the television with both connectors (HDMI and Component). Then in the display settings change it from HDMI to component and during the 30 seconds that the screen goes black you need to disconnect your HDMI cable from your playstation. Then switch to the input that the component cable is connected to on your television (ie. AV1, AV2, etc). From here you will see the countdown for the test and you can continue with these settings.
Nov 20, 2008 | Sony Playstation 3 (PS3) Console
Connecting PS3 to receiver via HDMI
First put the orginal ps3 cable onto ps3 then to tv.set tv to see ps3 and go to ps3 setup,now down to display settings,set to hdmi,picture will go off so now switch tv to hdmi input .Next go to sound settings for ps3 and set to hdmi if your amp can work this way ,if not set sound out to optical.
hope this helps.
Jun 24, 2008 | Onkyo HT-SR800 System
No picture connected via HDMI
Your PS3's HDMI settings may be the issue. When you go to turn on your PS3 next time, instead of just pressing the poser button and letting go, hold it for 5-6 seconds until it beeps again and then let go. This will force the PS3 to autodetect your TV again and should bring up the video. good luck!
Jun 19, 2008 | Sony Playstation 3 (PS3) Console
Video Game Consoles & Games Logo
408 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
