Question about Canon PIXMA MP780 All-In-One InkJet Printer
Black 3e Cartridge
The Black 3e prints as if it is out of allignment. The are light blue/gray horizontal stripes throughout the page of my black printing pages. TOn some pages, the letters don't even show up, just a white streak.
When I print the test page from the printer maintenance, everytying looks good except the 3e also has a white stripe through it.
What can I do?
    Genius:
  • 1,665 Answers
It seems the black ink tank is not exactly on the Printhead and may be air in the pipe.
http://www.fixyourownprinter.com/forums/printer/40028
Posted on Jul 03, 2008
    Master:
  • 848 Answers
Check the printer head and roller inside the printer
also check the nozzle because it may be clogged due to some
dust
Heavy black stripe on back side of every printed page
This is probably due to miss alignment, there is an option of test page which will be scanned to allign the cartridge, if ur's a all in one printer. This test page is printed at the first time and scanned instantly for first time operation.
Thankyou
Mar 20, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Brother MFC-6800 1. Prints with 3/8" blank vertical line down the entire page; 2. Prints with a couple of 1/16" blank vertical lines down the entire page; 3. Prints with some gray shadow...
This solution is unconventional but it worked for me. The black roller on my MFC had irregularities on it and was creating horrible printouts. I pulled out the drum and cartridge and cleaned the large black roller. I used furniture polish to make the roller very smooth. Now it prints really nice.
Nov 29, 2010 | Brother MFC 6800 All-In-One Laser Printer
Black toner cartridge prints everything in gray
Well if your warranty is expired, I guess you really have had the cartridge quite a while.
There are a couple of things (cartridge related) that could be the cause.
The toner can settle in the cartridge, so try removing the cartridge from the printer, and holding it drum downwards give it a good shake side to side.
If the cartridge was stored in too warm a place, the toner could have formed a solid lump. This situation can be made worse if the cartridge bag was opened (or not sealed properly), and the storage conditions were damp as well.
Was the cartridge still in a sealed bag unitl you recently put it in the printer ??
If not, the drum could have been affected by light exposure. This would cause lighter density on the page than you would expect, though I would have thought that part of the image on the page would be full density (as part of the drum would have been sheilded by the cartridge body - that part effectively being inside it).
Its also possible that the drum was a duff new one, (or not replaced) when the cartridge was remanufactured.
An original drum in these cartridges is a purple colour, aftermarket drums are blue, green, or blue-green.
The only conclusive way of checking the drum is by substitution unfortunatly.
It might still be worth having a word with your supplier (accepting that they don't have to do anything for you), they may value their reputation, and have enough faith in the quality of their product to want to know what has gone wrong n this case.
Mar 31, 2010 | Dell 3110cn Laser Printer
Need a stereo wiring diagram for my van.
Yep!
Here you go...
1995 Mercury Villager Car Stereo Radio Wiring Diagram
Radio Constant 12V+ Wire: Green/Purple
Radio Ignition Switched 12V+ Wire: Yellow/Black
Radio Ground Wire: Black/Light Green
Radio Illumination Wire: Green
Radio Dimmer Wire: N/A
Radio Antenna Trigger Wire: N/A
Radio Amplifier Trigger Wire: N/A
Front Speakers Size: 5′ x 7′
Front Speakers Location: Doors
Left Front Speaker Wire (+): Orange/Light Green
Left Front Speaker Wire (-): Light Blue/White
Right Front Speaker Wire (+): White/Light Green
Right Front Speaker Wire (-): Dark Green/Orange
Rear Speakers Size: 5′ x 7′
Rear Speakers Location: Side Panels
Left Rear Speaker Wire (+): Light Brown/White
Left Rear Speaker Wire (-): Light Brown/Yellow
Right Rear Speaker Wire (+): Light Brown/Green
Right Rear Speaker Wire (-): Brown/Pink
That's what they show for factory
K
May 31, 2009 | 1995 Mercury Villager
Stripes on Images only - Text OK
Perhaps the CMY color heads need alignment. If you have not already done so, run a head alignment from the driver maintenance section. It will print out a page containing several lines and text, and request you select the closest-aligned images. After this is done, do another image print to check for improvements.
Normally, the printer uses the black cartridge for text and the CMY inks for images (even for black on photo and specialty paper). So when you are printing normal text pages on plain paper, only the black ink is used. A good check for this would be to print a normal text page, but select photo paper in the driver to trick the printer into using the CMY inks to make a substitute black text page. If this looks ok, then you are having issues other than cartridge alignment.
May 24, 2008 | Canon BubbleJet i560 InkJet Printer
Replaced empt 3E cartridge. Now it won't print
I had removed and reinstalled the empty 3e cartridge. Sorry for the Confusion. I hadn't put a new 3e cartrige in until today. Them I ran " deep clean" twice. The printer works fine. I still don't understand why the printer wouldn't print color, when I was had set the printer to print in color when my 3e cartridge was empty and all colors including the 6 black showed full.
Mar 31, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
Printer problems,
i think the heads need cleaning click start ,click devices and printers, right click on the printer image, click troubleshoot and follow instructions.
May 07, 2017 | Canon BJC 8200 Photo InkJet Printer
Black will not print
This may seem obvious but have you tried cleaning and refreshing the print heads? I've had a similar problem with only certain colors and the cleaning seemed to help.
Nov 06, 2007 | Canon PIXMA MP780 All-In-One InkJet...
Printing problem
The black cartridge printhead needs to be cleaned or replaced. Follow your printer manual instructions.
Mar 18, 2007 | Canon PIXMA MP780 All-In-One InkJet...
Canon PIXMA MP780 All-In-One InkJet Printer Logo
149 people viewed this question
old marine
old marine
