Question about Kenmore Dryers
Kenmore gas dryer no flame
Our knemore gas clothes dryer model 75901-75911-75921 does not have the heat or gas working. All gas petcocks are on. I tapped the manifold lightly with a hammer witrh no luck
    Genius:
  • 1,028 Answers
If ignitor glows but fails to ignite suspect coils on burner valve
Posted on Jul 05, 2008
REPLACED SoLeNOID COILS AND IT BURNS BUT SEEMS TO BE A LOW FLAME
How to fix a none heating Whirlpool or Kenmore gas dryer ...
www.askgene.com/...dryer/...dryer/how-to-fix-a-none-heating-whirlpool...
Dec 27, 2006 - How to find, test and/or replace the igniter, the radiant flame sensor ...The part number for the Whirlpool gas valve coils is 279834. ... The main coil seems to be energized all the time and the auxiliary coil is ..... I have a whirlpool gas dryer model WDG5600SQ0 ,the gas will ignite into a flame but burns out ...
Clothes Dryer Troubleshooting ' Dryer Repair Manual
Jan 01, 2016 | Dryers
Ge gas dryer heats but doesnt dry
if the flame is lighting you have lint blocking the air flow either in the dryer or in the vent line,also if you have a flame for the first 10 to 20 minutes and then the flame doesn't light you have bad gas coils located on top of the gas valve,when the coils are bad they can work for the first 10 to 20 minutes until the coils get hot and then they fail and you'll see the ignitor glowing orange but no flame,bad gas coils.then when the coils cool down they can work again.hope this helps.you can try removing the vent line from the back of the dryer and see if the flame stays on,if lint is blocking the air from blowing out the flame won't stay lit long enough to dry the clothes.
Dec 01, 2013 | Kenmore 73952 Gas Dryer
Knemore he4 taking longer to dry clean vents has heat and blowing fine
make sure the lint filter duct is clean,you can remove the back panel if the filter is on top and remove the duct to clean it or if the filter is up front pop off the bottom panel,remove the filter and remove the duct,also if the vent line is long remove it from the back of dryer and stick a leaf blower in it and blow it to the outside,make sure there isn't a cage or anything blocking the outside hood,if there is remove what's there,also if this is a gas dryer you could have bad gas coils located on top of the gas valve,when the coils start to fail they will let the gas in until they heat up and then after around 15 to 30 minutes no more heat until they cool down again,you can run the dryer next time you use it and after 15 or 20 minutes remove the bottom panel or if filter is on top thee should be a cover on front panel,look at the ignitor,if it glows but no flame you have bad gas coils,hope this helps and next time send the full model number off of the machine you're having problems with
Mar 23, 2013 | Kenmore 63942 Dryer
On my Kenmore Soft Heat Heavy duty gas dryer I am having problems with the the fire lighting and going off intermentently . The fact that it ignites and then goes out makes me think that it isn't...
Hello Jerry,
It is working like its supposed to when the flame goes off, the way all dryers work is the flame(heat element on electric heated dryers) comes on and when the drum exhaust temp reachs a maximum of 155degrees and the flame goes off, the air temp will cool off to 120degrees and the flame comes back on and cuts off once again the 155 degrees has been reached..much more that 155 degrees the clothing is very likely to combust and catch on fire.
Please reply and let me know if your having a dryability issue with your dryer or where you just concerned since the flame went off??
GENE
Sep 05, 2011 | Kenmore Dryers
Kenmore 600 series gas dryer not warm
Make sure the vent is clear and air movement is good through the rear vent.
Ten,
Check and or replace the flame sensor and the gas valve coils.
Mar 11, 2009 | Kenmore 73952 Gas Dryer
Kenmore gas dryer not heating up
ck/replace the 2 black coils on valve they will sometimes fail after 1st start up slight chance it may be flame sensor mounted on side of burner to ck remove the 2 wires and short together temporaily if flame stays on and reignites ckd vent system first bad flame may cause sensor to shut it off if flame/vent ok replace sensor
Nov 27, 2008 | Dryers
Dryer heats for 3 minutes, flame quits
the flame is suppose to cycle on and off. If the flame ran continously you would have a fire. And please don't use the top of it for anything such as clothes piles. Dryers need to be free of clutter on top. I know it may be hard to do but do it and your dryer will last you. Good Luck. Whatever you jumpered reverse it ok!
Oct 26, 2008 | Kenmore 73932 Gas Dryer
Intermitten Heat up
make sure that your vent is not plug up can you go outside your house and feel good air coming out the vent when the dryer is turn on if so the only other things it could be is the coils that sit on the ignotor assmebly or the high limit termistat is not working properly the coils are little black circle coils that sit in the ignitor assmly should have a metal braket across the top of them holding them in you can check resistance on these coils if you have an meter
Mar 22, 2008 | Kenmore 72802 Gas Dryer
Kenmore 70 Series
hello,
i have a kenmore series 70's gas dryer that will not heat up when it is turned on and i am now smelling gas when i do try to dry my clothing. it was working yesterday but now this is happening? please help.
thank you,
tina
Jan 05, 2008 | Kenmore 74602 Gas Dryer
Dryers Logo
91 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
