Question about Buffalo Technology (WLI-TX4-G54HP) (WLITX4G54HP) 802.11g/b Wireless Adapter
Pc link My router just stopped working for no apparent reason. Power is on, but when I connect the ethernet from modem to router the PC Link on the modem never lights up. If I connect directly to my computer it works - so I know the modem is working properly. Suggestions??? I have had this for about 1 year and have not had any issues. I've had power surges (due to storms) so not sure if there is something that may have gotten tweaked. It is plugged into a power surge protector however. Thanks.
There is reset button on the bottom of the router .... hold it unless a red light (dont know what its called) on the front led panel appears
Posted on Aug 04, 2008
  • 137 Answers
Try bypassing the surge protector after turning everything OFF and then power on modem then router, without being connected to computer.
Posted on Jul 03, 2008
A friend of mine has this D-Link DSL-2750U router & is trying to connect his cable internet to the router but failing to do so. We suspect it is a purely ADSL router & does not support ethernet connection...
You need a router which connects to ethernet..ADSL is connected by RJ45(Telephone connection) ... Many cable companies include a router in the Modem (Verizon) others need a router to do wireless which gets connected between the PC and the Modem . the DSL-2750U is well over $2000.00.. a normal wireless router is $50-$100... a regular router gets connected by ethernet to Modem and router ,, then has 4 other connectors .. ehternet to PC.. Also requires power supply. .. wireless has to be setup for the software.
Oct 28, 2013 | D-Link Computers & Internet
When I connect my modem to my laptop, all the lights come on except the pc link light. I have already unplugged it and reset it and it still doesn't work. What more can I do?
If the ONLY light not illuminated is your PC link light then that generally indicates a physical disconnect between the modem and the laptop. If you can get the PC link light to light up when connecting to any other device (computer, router, anything), then you are most likely looking at the ethernet jack on the laptop being burnt out. Otherwise, try swapping the ethernet cord. If a different ethernet cord does not resolve the issue and the PC link light does not come on no matter what the modem is plugged into, you are looking at a faulty ethernet jack on the modem.
Aug 17, 2011 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
I installed my D-Link DI-784 six days ago. It's connected to a Dell 8100 running Windows 7. It worked fine until an hour ago, when it stopped broadcasting. The router is connected to a DSL modem. If...
It is possible that a neighbor purchased a wireless access point that it on the same channel and they are competing. Change your wireless channel. You could also try a hard reset. Instructions at D-Link's website. Good luck!
Apr 08, 2011 | D-Link (DI-784) Wireless Router
I can not make my D Link DIR-615 work with Hughes HN9000 modem. The D Link is located at the PC and Hughes modem location so I can wire 1 PC but need the laptop to connect wireless. I tried both an...
If you connect Modem to your laptop, can you go online?
If you are able to go online like that then log onto www.hnetworking.com and we can take the remote access of your computer and try help you out.
Feb 28, 2011 | D-Link DIR-615 Wireless Router
Router stopped working.
As long as the power light stays solid, then the router is fine. You need to reconfigure the router for it to receive internet connection from the modem.
May 17, 2010 | Linksys Wireless-G Broadband Router
After losing power I lost network conaction
Try to power cycle the whole network and make sure that everything connected properly. Turn of the pc then the router and lastly the modem. Wait for 5 minutes then turn on the modem then router and pc. Modem should be connected to the internet port on the router and pc to the ethernet ports.
Jun 29, 2009 | D-Link DI-624 Air Plus XtremeG Wireless...
Vista desktop won't connect to internet cable modem eithernet
power down cable modem, router, and computer. Connect ethernet cable from modem to router/ and connect ethernet cable from router to PC. Power up cable modem first, after modem shows connectivity, plug in router. After router shows internet connectivity, start computer. Be sure that you LAN card operable
Apr 15, 2009 | Acer Computers & Internet
Problem setting up home network with d-link des-1105. Windows Vista on main PC & Windows XP on laptop. Presently, I have ethernet cable connected on main PC to d-link and usb cable connected to laptop & to...
A router is basically a mini-computer that splits up one internet connections to 4 (or whatever # of ports you have).
Basic Connections to a router:
A Router requires a internet connections, so your broadband modem must connect to the WAN port (theres only one) of the router DIRECTLY. Then Ethernet cables go from the router to the computers on the LAN ports. Don't do something weird like connecting your internet to your computer then your computer to the routers WAN port, it'll most likely mess up.
Once you have connected your router like this, it should work.
If your modem only has a usb port, I have no idea how to make that work out. Sorry. Try getting a new modem from your ISP, or check if your modem does have a ethernet port, if it does just connnect that to the routers wan port.
Also computers should not interconnect with each other with use of a router. Thats what the router is for. Everything gets connected and split up at the router, nothing connects to anything else but the router, basically.
Feb 26, 2009 | D-Link DIR-625 (790069292637) Wireless...
D link wireless router dir 300. connecting to modem and pc and system tells me that the ethernet connection is not correctly connected ... tried over and over again ... and it just does not work.. thanks...
If the problem is on the side of the modem, the best bet is to unplug your router, reset your modem (through power cycle or reset button), then plug the ethernet cable from the modem into your router, then plug your router back in.
Jul 26, 2008 | Computers & Internet
Need Ethernet port on PC
If you have a wireless router then the ethernet cable will go between the modem and the router. Then you need a wireless LAN card to connect the PC to the router
What model router and modem do you have?
PC wireless card
Jul 03, 2008 | D-Link DFE-530TX+ Fast Ethernet PCI...
Buffalo Technology (WLI-TX4-G54HP) (WLITX4G54HP) 802.11g/b Wireless Adapter Logo
Top Buffalo Technology Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Buffalo Technology Computer and Internet Expert? Answer questions, earn points and help others
